Improving Headlights
Graham88
PostPosted: 03:42 - 08 Nov 2006    Post subject: Improving Headlights Reply with quote
I want to improve my headlights, as I don't really find I get enough light from mine.
Have been looking at Xenon Headlights, which look to improve headlights quite alot. Unfortunately the only picture I can find is on a car!
https://img380.imageshack.us/img380/9529/imag0027qc8.jpg
Would I be able to go into somewhere like Halfords with a headlight bulb, and match up an Xenon bulb to use instead?
Ichy
PostPosted: 07:57 - 08 Nov 2006    Post subject: Reply with quote
Auto express did a test and one of the best standard fitment bulbs was the Osram Silverstar 50%. Costs between £12 and £20 for a pair. Supposed to give off 50% extra light for the same power rating. The Philips Vision Plus was supposed to be the best but costs about £12 for one bulb.
Plently of places you can get them, loads on the net, including Ebay. Or just try the local car shops.
tsmith
PostPosted: 07:59 - 08 Nov 2006    Post subject: Reply with quote
have a look at the size and power rating of your bulb
get either an Osram Silverstar or Philips Vision Plus equivalent
sorted Thumbs Up
feef
Energiser Bunny
PostPosted: 09:58 - 08 Nov 2006    Post subject: Reply with quote
don't confuse Xenon bulbs, with HID Xenon systems.
Xenon bulbs just use Xenon gas in a regular halogen bulb to make the light whiter.
Xenon HID systems use a Xenon gas filled chamber, within which a small electric arc is fired continuously. HID systems produce SHITLOADS more light than a halogen bulb, and also only consume about 35w of power (compared to 55/100w for halogen bulbs) You can get HID kits that just plug in, but you need to find somewhere to store the balasts and starters, so if you've got a naked bike, it cant be tricky to make it look good.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
beatnck
PostPosted: 12:42 - 08 Nov 2006    Post subject: Reply with quote
i had this prob on my rs, so i went to halfords and picked up a xenon bulb for a tenner and its made a world of difference Smile
Arfdog
PostPosted: 12:47 - 08 Nov 2006    Post subject: Reply with quote
If you've got 6V electrics (as I have on my RXS100), you can find some bulbs here:
https://www.norbsa02.freeuk.com/goffybulbs.htm
I can't figure out which ones I need though, so my lights are still old and dim..
I'm a lover, not a fighter.
Graham88
PostPosted: 01:39 - 09 Nov 2006    Post subject: Reply with quote
I went there but they only do it in 55W, I need 35W. Mad
Finglonga
PostPosted: 13:12 - 09 Nov 2006    Post subject: Reply with quote
The Bulbs are a factor but more of a factor is the reflector. You also have to consider the wiring and the material the reflector is made from if you up the wattage.
Wiring will melt if pushed too hard as will a reflector if subjected to too much heat.
The 'coated' bulbs life is considerably shorter also. I don't rate the philips bulbs, had them for the car and the bike.
Andy Sez....
F.Y.Y.F.F.
Zimbo
PostPosted: 13:19 - 09 Nov 2006    Post subject: Reply with quote
A bulb upgrade is a good first tsep, I recommend Philips Vision Plus - better beam pattern and more light.
phatstorage
PostPosted: 13:31 - 09 Nov 2006    Post subject: Reply with quote
https://www.hids4u.co.uk/products.asp?cat=13
his name is Ian and he's da man.
Arfdog
PostPosted: 13:37 - 09 Nov 2006    Post subject: Reply with quote
£269.99 ?!?!?!?!
That's about twice what my BIKE costs!!
Ichy
PostPosted: 14:40 - 09 Nov 2006    Post subject: Reply with quote
Arfdog wrote:
£269.99 ?!?!?!?!
....and about four times more than its worth Laughing It will make it go much faster though.
Try this place, seems to have a good choice for 6v, price seems okish.
Might be worth emailing the bloke for his opinion :norbsa02@aol.com
Arfdog
PostPosted: 14:54 - 09 Nov 2006    Post subject: Reply with quote
Ohhh I dunno about making it go any faster..
I would have thought the increased number of photons being emitted forward out the headlamp would cancel out the 2.5 metric catpower I gained by cutting power slots in my chain.
Maybe if I had a high power brakelight, but then, that would just give me that little boost at the very instant I wanted to stop.
feef
Energiser Bunny
PostPosted: 15:11 - 09 Nov 2006    Post subject: Reply with quote
ahbut.. remember HID lights only consume 35w of power, compared to 55/100w for a halogen bulb.. that's 35w more you can put down thru the back tyre (after losses have been taken into account of course Wink )
a
phatstorage
PostPosted: 16:26 - 09 Nov 2006    Post subject: Reply with quote
so how many cats to one horse Arf?
i think you may be right about the brake light and am thinking of maybe getting a 35watt hid indicator system for added fun on bends Thumbs Up Laughing
BTW: didn't realise the H4 was that much, that's alot of penny sweets, i was looking into the H11 which is more reachable.
eddclarke
PostPosted: 16:39 - 09 Nov 2006    Post subject: Reply with quote
I just fitted a halogen bulb to my bike (xr125) its the same wattage as the old one. The headlight unit has 2 bulbs in it one for main and then the dipped light that is always on. Before i changed the bulb, both bulbs used to be on all the time and then when on full beam they both got brighter. but now i have fitted the new one only the little bulb works on dipped, but they both still work on high beam
i need to get this sorted for later on as I'm at work and cant drive with full beams on the whole way, ill blind people
Arfdog
PostPosted: 17:07 - 09 Nov 2006    Post subject: Reply with quote
Hi Phat.
By my calculations, one horsepower is 833 and a 1/3 catpower.
Which makes a catpower approximately 894.83 milliWatts.
phatstorage
just a thought mate,
can you plug that bulb in the wrong way round?
if so i think that's what you did.
eddclarke
PostPosted: 17:12 - 09 Nov 2006    Post subject: Reply with quote
no idea ill have to go check
phatstorage
Damnit man, i was expecting the worst but their is no way that could ever power my flux capacitor side stand.
i need 1.21 gorilla watts!
Ichy
PostPosted: 20:58 - 09 Nov 2006    Post subject: Reply with quote
Ahhh.... what your forgetting is that I'm an engineer so I'm right.
The bit you've forgotten is that the higher rated bulb is running hotter. This warms up a small amount of air in front of the bike which then rises and leaves a vaccum. Not only does this mean that your bike is being sucked forward but their is no friction in a vacuum. Therefore the speed of the bike will steadily rise, even if you shut off the throttle.
Better upgrade your brakes.
Finglonga
PostPosted: 21:40 - 09 Nov 2006    Post subject: Reply with quote
Its a bit like Ion drive then, except it pulls instead of pushes.....hmmmm Confused
Andy Sez....
F.Y.Y.F.F.
Ichy
PostPosted: 22:01 - 09 Nov 2006    Post subject: Reply with quote
Nah....... its sucks.
PostPosted: 22:46 - 09 Nov 2006    Post subject: Reply with quote
Arfdog wrote:
£269.99 ?!?!?!?!
Yeah but with the reduced power consumption you could leave the lights on when you park it behind the wife's car Very Happy
The last post was made 17 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.36 - MySQL Queries: 16 - Page Size: 132.01 Kb
