What affects the rate at which an indicator blinks?
firg
PostPosted: 01:47 - 25 May 2007    Post subject: What affects the rate at which an indicator blinks? Reply with quote
I bought a second bandit today, and I noticed on the way back the the indicators blink at about half the speed of the first bandit - a single blink per second (thats pretty slow when you actually time it out).
What causes different speeds of blinking? (Especially on the same model. The only difference between them is that one has an alarm fitted).
Is this a symptom of something else, or is there a reasonable explaination?
thanks,
Loz
Ex-'96 Bandit 600S -> '99 Bandit 600 -> K7 V-Strom 650
Rookie
PostPosted: 01:48 - 25 May 2007    Post subject: Reply with quote
Will be the relay, have you checked all the indicators are actually working?
firg
PostPosted: 01:49 - 25 May 2007    Post subject: Reply with quote
Yep theyre all working. Also, when an indicator blows, i thought they went faster than normal, not slower.
What is the relay, and is there any way i can test its working properly?
edit: actually there is 3 years difference between them. Maybe they used a different relay whatsit.
Rookie
PostPosted: 02:01 - 25 May 2007    Post subject: Reply with quote
Rolling Eyes That's a very good point, but it's late. Razz
I'll go and hide in the corner before I say something silly. Embarassed
firg
PostPosted: 02:21 - 25 May 2007    Post subject: Reply with quote
Since it flashes faster when theres less load on the electrics (e.g. bulb gone), would the extra load of an alarm maybe make it go slower? Or is that all bollocks? I'm not too hot with electrics.
willi
PostPosted: 02:58 - 25 May 2007    Post subject: Reply with quote
less wattage bulbs, will make it flash faster. the more watts the slower.
wat goes around comes around.
firg
PostPosted: 10:37 - 25 May 2007    Post subject: Reply with quote
Eh fair enough. He didnt mention putting brighter bulbs in, but then again I guess you wouldnt.
Finglonga
PostPosted: 10:55 - 25 May 2007    Post subject: Reply with quote
Yea, the higher the resistance in the circuit the slower the flash rate. If you check the wattage of all the bulbs you may find they are not all the same. Drop the wattage to speed things up.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 15:04 - 25 May 2007    Post subject: Reply with quote
You are allowed between 60 and 120 flashes per minute to be road legal.
firg
PostPosted: 18:43 - 25 May 2007    Post subject: Reply with quote
Thanks Thumbs Up
tpsutton
PostPosted: 20:46 - 25 May 2007    Post subject: Reply with quote
I had the same thing on my 1998 bandit, found in the end that it had a loose connection causing an earth fault so i would check all connections.
firg
PostPosted: 23:59 - 25 May 2007    Post subject: Reply with quote
*cough* I'm shit at electrics - how would I find out if something was causing an earth fault? And how did you find exactly which conection was loose? (or was it obvious by looking at it?)
tpsutton
PostPosted: 20:03 - 27 May 2007    Post subject: Reply with quote
quite simple really i took tank, seat and plastics of and simply pushed every connection i could see or get to, earth fault just means that the indicators are earthing out when they shouldn't
hope that helps
The last post was made 16 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1 - MySQL Queries: 17 - Page Size: 80.38 Kb
