 JAS-N-JACK L Plate Warrior
 Sparks! Sir Tart-a-lot
 Posted: 23:15 - 22 Jun 2007 Post subject: |
Seat off
Tank off
Airbox off
Carbs off (pain in the arse if I remember rightly)
Once that lot is off you will be left with the inlet ports, there is a rubber thing bolted onto each one.. under the rubber thing is the restrictor plates.. unbolt each of the rubber bits, remove the plate and then put the rubber bit back on.
https://www.bikechatforums.com/files/pic_0008.jpg
You can see the plates under the carbs in this pic.
Rebuild bike and enjoy!
If I remember rightly, it wasn't hard to do, but getting the carbs on and off was a bit of a pain. ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
