It's the little bits..
st3v3
PostPosted: 17:30 - 30 Jun 2007    Post subject: It's the little bits.. Reply with quote
Since the second *sorry, third* crash Embarassed Laughing The fairing was slightly bent, so after getting some new bit's off here I have decided to put other finishing touches on Smile Thumbs Up , and I've also moved the number plate further up the mount, so it's right between the rear indicators as a posed to an inch or 3 down the mount.
st3v3
PostPosted: 19:35 - 05 Aug 2007    Post subject: Reply with quote
Well, she's of the road Till about next weekend now, the rear sprocket has seen better days, re-painting the wheel rims is harder than I thought(back to shiny white) and the home-made wiring loom is going to be started tomorrow.
Nb
PostPosted: 21:58 - 05 Aug 2007    Post subject: Reply with quote
Shocked Shocked At the sprocket.
st3v3
PostPosted: 21:59 - 05 Aug 2007    Post subject: Reply with quote
Laughing Just won a new one on Ebay so.. Cool
Welshd1k
PostPosted: 22:10 - 05 Aug 2007    Post subject: Reply with quote
dude wtf man Very Happy
if u need any bits im sure i can find soem in my box full of shit Very Happy
PostPosted: 22:29 - 05 Aug 2007    Post subject: Reply with quote
You so need to remove that NSR sticker. Your bike is an NS125R...
Its like putting a CBR sticker on a FZR or something.
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
st3v3
PostPosted: 13:23 - 06 Aug 2007    Post subject: Reply with quote
Meh it's something I never got round to, then forgot Laughing I'm not sure of any bits I need now, There probably is, but me remebering them..... Embarassed Cool
*maybe I'll replace it with NS125?*..(instead of nsr)
virus
PostPosted: 20:01 - 06 Aug 2007    Post subject: Reply with quote
still got 3000 miles left on that sprocket Wink Laughing
own: 81 xs1100g...
Evo
PostPosted: 20:20 - 06 Aug 2007    Post subject: Reply with quote
Cut the R off Laughing
And nice sprocket Shocked
You spraying the wheels yourself ?
I found spraying panels very hard to achieve a professional finish, Wheels are harder to do with the contours and angles. Don't use aerosol lacquer on them as it's turns out piss poor. If you do, test your spray on something else first. Also remember you need to allow to paint to harden before putting them back on the bike. In sprayshops they put them in the Oven for about an hour. But using environment temperatures i think it will be a few days depending on humidity.
Bikes owned
1989 VFR 400 RR NC30
st3v3
PostPosted: 20:23 - 06 Aug 2007    Post subject: Reply with quote
Where can I get a carb that would fit? It has a "Dellorto" one on, not sure of size etc, but it has a flat spot which I think is the jet(s) so maybe a new carb for the Jets would sort it?
Evo
PostPosted: 20:26 - 06 Aug 2007    Post subject: Reply with quote
I have a spare Dellorto PHBH28 carb. Don't know what jets are in, havnt looked.
Measure your port on your carb, engine side.
Bikes owned
st3v3
PostPosted: 23:11 - 08 Aug 2007    Post subject: Reply with quote
Will do tomorrow, got the new sprocket today, and painted the rear wheel bright white so re-fitting tomorrow, then to start on the front wheel, hoping to have it all done by Sunday. Evo, sorry I couldn't reply to your text, out of credit again Rolling Eyes Laughing should be up & running sunday. will measure the carb tomorrow and post.
st3v3
PostPosted: 21:27 - 11 Aug 2007    Post subject: Reply with quote
Well, been an eventful day.
Got the wheels finished off as best as I can with some white hammerite and a paint brush, then me and my dad got to work on the wiring loom(mainly him) which we thought was fecked, turns out nothing worked because the most important bulbs had blown, not too dodgy a wiring Laughing
Bulbs had blown because of a dodgy battery, still not sure what's wrong with it, but I'll get a replacement one with bulbs tomorrow or payday. Thumbs Up
So, bike's still in bits, wheels sorted, wiring fine but in need of bulbs so tomorrow I can start to bolt it together. I so can't wait to get on and ragg it around for an hour or two even though it has been only a week of no use. Embarassed Twisted Evil
Evo, the outside of the carb(engine side) measure's 44.5mm on the most outside part of the metal hole on the outside of the carb where the petrol etc goes in the engine. HTH. Thumbs Up
Evo
PostPosted: 09:27 - 12 Aug 2007    Post subject: Reply with quote
Is the battery same as NSR one ?
Model: CT5L-BS
Bought a new one couple of months ago to rule out a battery problem, it was a wiring fault so still got a spare working battery.
Bikes owned
st3v3
PostPosted: 12:27 - 12 Aug 2007    Post subject: Reply with quote
Not sure if the connectors are the same..... Cable ties round terminals FTW! Laughing Thumbs Up
Evo
PostPosted: 16:42 - 12 Aug 2007    Post subject: Reply with quote
No wonder you think your batteries fucked if your using cable ties to connect the terminals. You need the best contact you can on the battery. Usually they use small metal blocks with threads in them, they slot inside the battery terminal then a screw goes through the wires through the battery terminal into thread. Cable ties arent exactly a great conductor and also flex.
You need to get that sorted lol.
You really are Mr.Bodge Wink
Bikes owned
st3v3
PostPosted: 17:21 - 12 Aug 2007    Post subject: Reply with quote
Well, wheels back on, fairing brace on and half tightened, can't do much for this fecking drizzle. wheels painted white but not too good although better than I expected for a brush and tin of white hammerite. Thumbs Up electrics all sorted, even killswitch works so can test for backfiring later. Twisted Evil
[Edit] Evo, I know about the terminals, they were complete when I got the battery, and are around somewhere Laughing but there's no point unscrewing time again, might as well bodge it for now, then screw it back up later when I find the screws and blocks. Cool Mr. Green
st3v3
PostPosted: 21:30 - 13 Aug 2007    Post subject: Reply with quote
Well, she's back on the road, runs as she did and looks that bit better.
will get piccies tomorrow, forgot when I gave her a run out tonight. Embarassed Laughing
Evo
PostPosted: 17:41 - 14 Aug 2007    Post subject: Reply with quote
st3v3 wrote:
Well, she's back on the road, runs as she did.
50mph top speed then ? Surprised
My Rs50 did 62mph hehe but indeed 8-10 years newer.
Bikes owned
owdamer
PostPosted: 20:38 - 14 Aug 2007    Post subject: Reply with quote
Did you just paint over the corrosion on the wheels then?
st3v3
PostPosted: 15:09 - 15 Aug 2007    Post subject: Reply with quote
Evo you cheeky Evil or Very Mad Laughing No, it does minimum 60 when I feel adventurous Mr. Green
Owdamer, I sanded the rims back to the shiny metal, then painted onto that. Thumbs Up
MattHirst
PostPosted: 22:48 - 15 Aug 2007    Post subject: Reply with quote
Lol Steve, you are such just a bodge Very Happy
And i thought my bike was falling apart Razz
PostPosted: 22:57 - 15 Aug 2007    Post subject: Reply with quote
Stock carb is a 26mm dellorto. Jets can be got from https://www.dellorto.co.uk . The flat spot is most likely due to the exhaust you have on it. Try playing with the needle position.
st3v3
PostPosted: 20:35 - 16 Aug 2007    Post subject: Reply with quote
As it happens, I noticed yesterday the exhaust gasket is qickly dis-appearing and the down pipe has two pinholes in due corrosion, tried exhaust bandage and it simply melts off, am I going to have to look for a new micron can/system? (I so hope not)
Evo, just found https://i9.ebayimg.com/04/i/000/af/51/99e2_1.JPG these on ebay dead cheap(due to seller typo) so I'll try them first... Thumbs Up
Evo
PostPosted: 20:48 - 16 Aug 2007    Post subject: Reply with quote
Good stuff your sorted with the carb then.
And you sure its the exhaust gasket as gaskets are easily replaceable. 60p jobby ect..
Bikes owned
The last post was made 16 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.27 - MySQL Queries: 16 - Page Size: 138.27 Kb
