Which way do my piston rings go on the piston?
kcnw9
PostPosted: 17:53 - 11 Jul 2007    Post subject: Which way do my piston rings go on the piston? Reply with quote
Hi, i need help on which way the piston rings go on my piston. Both of the piston rings say R and 1.25(the oversize) near the gap of the rings and thats all they say. one of the rings is wider than the other, does this one go on top or bottom Question Also which way do they go on. They both have a little slant when the rings gap, like shown in this little picture:P
https://i143.photobucket.com/albums/r130/kcnw9/untitled.jpg
Is it the top or bottom way?
thanks
kcnw9
kcnw9
PostPosted: 18:00 - 11 Jul 2007    Post subject: Reply with quote
In the picture of the rings, i put the piston there so that it shows that th rings will go down on the piston(Don't think i make sense Laughing )
kcnw9
beans
PostPosted: 18:18 - 11 Jul 2007    Post subject: Reply with quote
They normally have writing on them saying top or similar. This will be written on the flat edge that doesnt make the seal, if you get what I mean.
If it has no writing on it I would say the lower drawing is right.
Yamaha FS1E- Suzuki RG 125 - Honda CB-1- Ducati Monster - Kawasaki ZX6-R F1- Kawasaki ZX6-R G1- 2003 Yamaha R6
Evo
PostPosted: 18:45 - 11 Jul 2007    Post subject: Reply with quote
Lower.
Mine were installed like "Lower" anyway and it works Thumbs Up
Bikes owned
1989 VFR 400 RR NC30
kcnw9
PostPosted: 18:58 - 11 Jul 2007    Post subject: Reply with quote
i think your both wrong, I just tried the rings the way you sugested and they piston will not fit inside he barrel, but if i do it the other way round then they fit Confused hope this is the correct way then
thanks guys
kcnw9
Evo
PostPosted: 19:04 - 11 Jul 2007    Post subject: Reply with quote
thanks guys
kcnw9
Why ask then ?
Wait for someone who actually knows what they're talking about to respond rather than us two above guessing. Thumbs Up
Bikes owned
PostPosted: 19:18 - 11 Jul 2007    Post subject: Reply with quote
Looks like a 2-stroke piston ring. If so the retaining pin will determine the way up to install them. In any case, the "rule of thumb" is that piston rings are always installed with any writing to the top. I've yet to see it done different (though I don't doubt there must be exceptions)
kcnw9
PostPosted: 19:21 - 11 Jul 2007    Post subject: Reply with quote
Evo wrote:
thanks guys
kcnw9
Why ask then ?
Sorry, i asked becuase i didn't want to put it in the wrong way an i wanted to get some advice from people who might have done it before. Thanks for the help Thumbs Up
kcnw9
Walloper
PostPosted: 19:34 - 11 Jul 2007    Post subject: Reply with quote
here
Walloper
PostPosted: 19:39 - 11 Jul 2007    Post subject: Reply with quote
My drawing is better than someone's at last. Laughing
kcnw9
PostPosted: 19:51 - 11 Jul 2007    Post subject: Reply with quote
thanks, thats strange because i cant get the piston in using the way you said was wrong but i can do it the other way Confused now im really confused, im going to have another go tomorrow.
thanks Thumbs Up
kcnw9
Evo
PostPosted: 20:51 - 11 Jul 2007    Post subject: Reply with quote
So we werent wrong. Found it hard to believe we were wrong above.
And being a new piston, the ring spaces will be tight. Snap your old ring in half and run the sharp bit around the piston ring spaces to run off the burs.
Smile
Bikes owned
PostPosted: 21:08 - 11 Jul 2007    Post subject: Reply with quote
Hmm I took the angled-bits in his drawing to resemble the end-gaps, not the sealing-edge.
kcnw9
PostPosted: 21:51 - 11 Jul 2007    Post subject: Reply with quote
Its not a new piston Confused I was just putting my rings back on my piston. I was really trying to get the piston in but it was having none of it, it went half way over the first ring then stops for no reason Neutral but the other way i goes on without a problem Question
Ill have a look tomorrow
thanks for the help
kcnw9
Walloper
PostPosted: 21:53 - 11 Jul 2007    Post subject: Reply with quote
I have never seen a ring cut like that. They are usualy straight I thought. But I hate strokers so I do not have to worry.
But my drawing is still better than his. Wink
PostPosted: 22:52 - 11 Jul 2007    Post subject: Reply with quote
It sure is. I was assuming that his "sloped" ends in the drawing were actually "scollop" cutouts for the stop-pin.
KCNW9 what bike is this for?
PostPosted: 23:03 - 11 Jul 2007    Post subject: Reply with quote
Check the rings carefully. Check if the top or bottom edge is tapered, similarly if there is a taper to the groove on the piston.
kcnw9
PostPosted: 00:37 - 12 Jul 2007    Post subject: Reply with quote
Hi, its a Yamaha RD125LC Mk2 model. Thanks Keith, ill have a look tomorrow morning Thumbs Up
beans
PostPosted: 16:53 - 12 Jul 2007    Post subject: Reply with quote
Tip for next time, take a picture or take note of little things like this as you disassemble.
I still say the lower drawing is correct.
The last post was made 16 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 17 - Page Size: 107.99 Kb
