Author |
d1t2y3 |
d1t2y3 L Plate Warrior
Back to top |
cheekythomas |
cheekythomas Crazy Courier
Posted: 20:53 - 17 Nov 2007 Post subject: |
The Fuse is near the battery... but if some electrics are working it must be fine... so its nothing that simple... keep looking. |
Back to top |
yambabe |
yambabe World Chat Champion
Posted: 21:31 - 17 Nov 2007 Post subject: |
OK, this may be a bit long-winded and I'm typing what someone else is telling me so bear with me.
Assuming that there's fuel in it and the battery is well-charged, you need to check that the engine has compression. In the NRG you do this by looking inside the seat bucket, there is a little box-like cover. Take this off. Hopefully the airbox is still on and it should have a sticky-up thing a bit like a trumpet on top. Put your finger over this, open the throttle and crank it over. You should feel the suction on your finger if it has compression.
If it sucks, keep your finger over the airbox bit, open the throttle again, start it up and keep cranking it for a count of 10 then take your finger off the airbox while still cranking it and it should catch.
If this doesn't work let us know. ____________________ Sod falling in love, I wanna fall in chocolate. |
Back to top |
d1t2y3 |
Posted: 13:08 - 25 Nov 2007 Post subject: Electrics |
Back to top |
d1t2y3 |
Posted: 13:21 - 25 Nov 2007 Post subject: |
babyyam wrote: | OK, this may be a bit long-winded and I'm typing what someone else is telling me so bear with me.
If this doesn't work let us know. |
I think i found it, there were two parts with finger sized holes, one was a rubber tube, the other was mostly hidden behind plastic but fitted your description i think. Anyway I tried what you said with both and neither have suction however, although I don't know wheather or not htis is relevant, i can feel the exhaust blowing out air. I have added an attatchment of the view underneith the seat well. Sorry the reply took so long, the weather's been crap and I'm working outside whenever I have the chance. |
Back to top |
The last post was made 16 years, 158 days ago. Instead of replying here, would creating a new thread be more useful? |
