Project "minty" stunt bike... NOW UPDATED
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3  Next
st3v3
PostPosted: 22:02 - 18 Apr 2008    Post subject: Reply with quote
I take were not talking Terminator series here?
Where can I get a copy? I'm guessing it's stunty related being in a Sparks thread...?.
Scouse
PostPosted: 09:18 - 19 Apr 2008    Post subject: Reply with quote
*Huh-Hmm*.... T0rr3nt-s... Razz
McGee
O RLY?
PostPosted: 11:51 - 19 Apr 2008    Post subject: Reply with quote
Only 3 and 4 are on torrent Wink
I'm in the process of making the Adrenalin Crew 2 dvd an avi to torrent and upload.
I must say no where near as good as the first one.
Its pronounced Jixxer!
Sparks!
Sir Tart-a-lot
PostPosted: 21:01 - 19 Apr 2008    Post subject: Reply with quote
Project minty is going to be renamed as Project Tarts Handbag I think.
I want something that stands out, something that looks like a tarty bike and will suprise people when I leave scraping the tail. Wink
So, compressor and spray set sorted, wheels, frame, swingarm being sprayed gloss black with a candy red flake Embarassed rims being polished.
Vinyl wrapped undertray going on Wink
Watch this space. It's going to be subtle but tarty. IT won't stay mint for long but it should turn heads, and will still be recognisable as a CBR 600 F Sport which is what I want.
McGee
O RLY?
PostPosted: 21:45 - 19 Apr 2008    Post subject: Reply with quote
Sounds win man.
Rawker
PostPosted: 20:20 - 21 Apr 2008    Post subject: Reply with quote
damn man,
that sounds good!!!
i wanna learn to stunt, might look at getting a bike to work on (not mechanically minded so wouldn't mind learning) then learn to stunt on it so i dont kill my sv.
Sparks!
Sir Tart-a-lot
PostPosted: 19:08 - 24 Apr 2008    Post subject: Reply with quote
I've started revamping my current stunt bike, for a couple of reasons, 1) so its in better condition and looks better when I sell it and 2) so it looks better!!
The side fairings on the crashed project minty are "reasonable" for stunt use, I have a reasonable seat unit and a mint tank too... so...
I stripped my bike down, cleaned it all, then cleaned it again with paraffin and a pressure washer. Fixed and improved a few things too!
I've stripped the radiator off, need to get the mounts re-welded on as they snapped. I'm going to re-spray the frame and swingarm black and clean up a few more bits too... as well as replace the forks.
Used to look like this, rather tired looking and generally dirty/crap looking. (only pic I have, no stationary ones!)
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/normal_sparkshighchair3.jpg
So here it is.... (well, half-done but you get the idea Laughing)
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/stunter-revamp-1.jpg
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/stunter-revamp-2.jpg
Will update this thread with the continuation of project minty and project revamp Laughing
To do:
Arrow Fix, remount and fill radiator
Arrow Spray frame, swingarm and some other bits black
Arrow Replace forks
Arrow Replace and fix front brakes
Arrow Cut tail slightly for round 12 bar and mount up
Arrow Dent tank and spray (dent only)
Arrow Fix some wiring (fell into fan and got chewed up DOH)
Arrow Service (oil, filter, check a few things etc etc!)
Arrow Fix starting problem (battery I *think*)
Sure I'll think of more Wink
Sparks!
Sir Tart-a-lot
PostPosted: 20:00 - 24 Apr 2008    Post subject: Reply with quote
Just bought this
https://i15.ebayimg.com/02/i/000/ec/27/0249_1.JPG
Can't decide which bike to fit it to Twisted Evil
Phil_Norwich
PostPosted: 16:30 - 29 Apr 2008    Post subject: Reply with quote
just noticed this thread. Its looking good Very Happy keep up the good work.
1990 VFR400 NC30 - 1992 Suzuki Goose
Sparks!
Sir Tart-a-lot
PostPosted: 21:28 - 11 May 2008    Post subject: Reply with quote
UPDATE
Progress, anyone say progress!
The undertray was fucked when I got this, I first intended to fit the red aftermarket undertray in a previous post, but turns out that was for the F4 not the F Sport Sad
So... I swapped the undertray off my stunt bike to get this moving along.
Everything removed
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/undertray-removed-1.jpg
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/undertray-removed-2.jpg
Replacement undertray fitted up Smile
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/undertray-fitted-1.jpg
Handlebars fitted up, fairing had to be moved forward slightly to allow clearance but got there in the end. I also had to cut down the upper fairing and screen to meet the line of the clock bracket
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/bars-fitted.jpg
I got to thinking about handbrake clearance issues, then before I knew it I ended up fitting the whole thing and made it all clear fine Mr. Green It has changed since this pic as I found a better way to mount it all, but it looks basically like this... easy pull clutch too Smile
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/handbrake.jpg
Side shot, as you can see I now have a cut down standard can fitted up
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/side-shot-1.jpg
CBR1000RR fireblade throttle and a ducati 748 brembo Drooling Drooling
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/1000rrthrottle.jpg
Here's what I see Wink Before anyone comments...... the left reservoir is tilted forwards so that the res doesn't run dry when wheelying... the right side reservoir tilts back so it doesn't run dry when stoppying Smile
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/controls-view.jpg
I have started on the wheels... here's what I'm going for, they aren't finished yet but it will look like this with red rim stripe, what ya reckon?
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/front-red-wheel-1.jpg
Got to fit indicators, find a replacement rear light that fits, fit new seat unit and round 12 bar and a fair few other things, but it's getting there.
McGee
O RLY?
PostPosted: 21:47 - 11 May 2008    Post subject: Reply with quote
Looking good man.
Wheel looks nice.
quacker_boy
Cuddle Bitch
PostPosted: 23:30 - 11 May 2008    Post subject: Reply with quote
Ok i won't comment on the reservoirs then...but er...what about the killswitch? Wink You have a key....but no killswitch! Razz
highland biker
PostPosted: 18:00 - 12 May 2008    Post subject: Reply with quote
Sweet as man, one fine looking machine, dunno about the wheels but thats just my opinion Thumbs Up
Sparks!
Sir Tart-a-lot
PostPosted: 17:58 - 17 May 2008    Post subject: Reply with quote
Been busy today.
Not so many pictures for you but I've got a lot done to both bikes.
The stunter.. I've sprayed the frame and swingarm, replaced tank, put a flat 12 bar on it and cut the seat unit to fit, also straightened the subframe and tidied all the wiring.... started putting the renthal handlebars back on as well... also rebled the rear brake and removed handbrake (as that's gone on the new bike)
It's starting to take shape and it looks a hell of a lot better than it used to.
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/stunter-revamp-3.jpg
As for Project Minty.
Well, I've put a 16mm brembo on the front brakes, I bled it all up yesterday with a banjo brake light switch for MOT purposes.
Let's just say, you'll be getting a lot of stoppie pictures from me soon! This set up is AWESOME. I was rolling stoppies on cold tyres without even trying..... !
I finished the front wheel too.. but there's a slight issue with this!
I sprayed it up and was really happy, then I got the pinstriping but when I started putting it on I became really unhappy Sad it was too narrow and completely the wrong colour! It's more orange than red.
So I chucked it on quickly without much effort with the view of just getting it MOT'ed and taking it all off later when I can be bothered....
So I start fitting the wheel up..
front off...
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/front-wheel-removed.jpg
the wheel (at this stage I was really unhappy with it and kinda MEH about it all
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/front-wheel.jpg
Anyways, I chuck it on reluctantly, then my neighbour comes down the drive and says how good it looks.!!
I step back for the first time and look at it actually fitted to the bike and I have to say but I really love it... I just need to get some 10mm HONDA RED pinstripe before I'm happy, but the general idea looks really good IMO. Cool
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/red-wheel-fitted-1.jpg
Tomorow I am going to fit the round 12 bar and seat unit and seats...
All that's left is a rear disc, front mudguard and got to do the rear wheel the same as the front (as well as change the pinstriping)
I got some 954 fireblade left switchgear and a start/stop button off a Honda VTR SP-2 so once they turn up I have to custom re-wire the switchgear looms to get them to fit and work then it's down for MOT!!!
Still saving up some cash for the tail saver and crash cage Smile
Louise
PostPosted: 18:16 - 17 May 2008    Post subject: Reply with quote
Oooooo im comming down for a nose - put the kettal on Thumbs Up
Sparks!
Sir Tart-a-lot
PostPosted: 18:20 - 17 May 2008    Post subject: Reply with quote
Are you still naked? Laughing Wink Drooling
Ghost
PostPosted: 18:23 - 17 May 2008    Post subject: Reply with quote
This is looking really good, looking forward to seeing some pictures of it in action. Only thing I really don't like is the cut down screen, was there any way you could have left it standard?
Sparks!
Sir Tart-a-lot
PostPosted: 18:27 - 17 May 2008    Post subject: Reply with quote
Nope not really Sad the bars would clear now I think, but when sitting in high chair etc it would be even more akward as the screen would be too high and it'd put too much pressure on the screen which could snap the upper fairing Sad
Sparks!
Sir Tart-a-lot
PostPosted: 18:18 - 18 May 2008    Post subject: Reply with quote
Not gonna write much today as no one seems to be replying Sad
Anyway here's some pics.. Not finished but almost MOT-able.
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/fully-faired-1.jpg
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/fully-faired-2.jpg
Subtle scrape bar
https://www.sparksfreestyle.co.uk/gallery/albums/userpics/10001/scrape-bar.jpg
highland biker
PostPosted: 18:21 - 18 May 2008    Post subject: Reply with quote
Sweet bike
no rear lights??
Sparks!
Sir Tart-a-lot
PostPosted: 18:30 - 18 May 2008    Post subject: Reply with quote
highland biker wrote:
Sweet bike
no rear lights??
It's on the to-do list, need to get a universal one I think as room is quite tight with that round 12 bar fitted.
Left to do:
Arrow Fit rear disc
Arrow New chain and sprockets (-1 +6)
Arrow Spray rear wheel
Arrow Change rim tape on both wheels to RED not poxy orange.
Arrow Rewire switchgears and get to work on this bike
Arrow Fit rear light of some sort
Arrow tank dent and spray
Arrow Fit crash cage
Arrow Fit tail saver
Arrow Replace rear brake master with the stunt one and bleed up
Hmm still a fair bit to do.
highland biker
PostPosted: 18:33 - 18 May 2008    Post subject: Reply with quote
At least its a smaller list than last time Laughing
Shaane
PostPosted: 18:42 - 18 May 2008    Post subject: Reply with quote
Sorry if you have already said so but what handlebars are they as they look really good?
Previous: 1992 DT125R
Current: ~ 2005 ZX6R C1H
Sparks!
Sir Tart-a-lot
PostPosted: 18:55 - 18 May 2008    Post subject: Reply with quote
They are Harris race clip ons, flipped and swapped (so they angle up rather than down) I also brought them in a bit shorter as they are REALLY long bars...
PostPosted: 19:05 - 18 May 2008    Post subject: Reply with quote
Looking awesome Sparks!. Thumbs Up
The last post was made 16 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.29 - MySQL Queries: 16 - Page Size: 150.9 Kb
