Author |
Stew |
![](images/spacer.gif) Stew If it's good enough for top race teams...
![](images/avatars/506741549426faa6465260.gif)
Joined: 03 Feb 2002 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_9.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 18:26 - 11 Jun 2003 Post subject: How to Fit Braided Brake hoses. |
![](images/spacer.gif) |
Fitting Braided hoses.
First thing are to do are make your decisions. Do you need braided hoses? Well most people fit them because they make you stop quicker. Some people fit them because they have been advised that their original rubber hoses have deteriorated and are out of shape. Other people fit them ‘coz they look good’. Next thing you have to choose is the brand and colour you are going to use. I chose Goodridge braided hoses in tarty red shrink wrap (thank you Busters-accessories). I also went with stainless steel fittings although they are available in other offerings such as anodised aluminium or chromed. (warning- mixing alloy and steel fittings can cause corrosion). If your original banjo bolts are in good condition you can still use these however you MUST use brand new copper crush washers (should really come with the brake line kit).
https://mysite.freeserve.com/crotchrockets3/brakes/brake1.JPG
1. First thing to do when fitting new lines is to make sure you protect your paintwork wherever you think there may be a risk off dripping any brake fluid as most people will know it is quite nasty and strips paint quite well.
2. Bleed original brake lines. I did mine by connecting a clear plastic hose to the calliper nipple and undoing the nipple.
https://mysite.freeserve.com/crotchrockets3/brakes/brake2.JPG
https://i48.photobucket.com/albums/f216/stinkwheel/stewbrakes/brake2_zps89e8f30e.jpg
https://mysite.freeserve.com/crotchrockets3/brakes/brake3.JPG
https://i48.photobucket.com/albums/f216/stinkwheel/stewbrakes/brake3_zps67a48cef.jpg
When they have finished draining tighten the nipple up again, disconnect the hoses from the calipers and stuff some rag into the banjo to stop it dripping everywhere
https://mysite.freeserve.com/crotchrockets3/brakes/brake4.JPG.
https://i48.photobucket.com/albums/f216/stinkwheel/stewbrakes/brake4_zpsdac932e1.jpg
Some people may syringe the fluid out from the master cylinder then just undo the caliper banjo bolt and catch any remaining fluid (make a note of how the banjos look at this point, there should be one that is slightly bent). Don’t know if it makes any difference but I was advised to do the left hand caliper first (thanks Robby) as it is furthest away from the master cylinder and if you are doing it with the bike on its sidestand then this is the lowest caliper.
3. Undo all little clips holding the hoses in place. Undo the banjo bolt from the master cylinder (you still have your rag there?) and remove the original hoses making sure you don’t drip brake fluid everywhere.
https://mysite.freeserve.com/crotchrockets3/brakes/brake5.JPG
https://i48.photobucket.com/albums/f216/stinkwheel/stewbrakes/brake5_zps53013b08.jpg
4. Loosely put your banjo bolts on to your braided hoses and put the hoses into place (longest hose goes to left caliper). Now attach the banjos to the banjo bolts in the calipers. Put a copper crush washer on each side of the banjo and thread bolt into caliper.
https://mysite.freeserve.com/crotchrockets3/brakes/brake6.JPG
https://i48.photobucket.com/albums/f216/stinkwheel/stewbrakes/brake6_zps2f802bc6.jpg
5. Now attach the other end of the hoses to the double banjo bolt into the master brake cylinder. Now check that the hoses run into all their appropriate fasteners and nothing snags (new banjos don’t hit clocks or fairing do they?)
https://mysite.freeserve.com/crotchrockets3/brakes/brake7.JPG
https://i48.photobucket.com/albums/f216/stinkwheel/stewbrakes/brake7_zpsd1f30db3.jpg
If everything is ok then tighten up all banjo fastenings to the hose, to the calipers, and to the master cylinder.
6. Now the boring bit. Fill the master cylinder up with fresh brake fluid, Dot4 is common for road bikes, (you still got that rag?). Starting with the left caliper attach your clear hose to the bleed nipple and undo half a turn, a small amount of fluid should come through. Now tighten up again, squeeze the brake lever in. Undo the nipple half a turn, you should see fluid come through the clear pipe and the lever pressure will drop
https://mysite.freeserve.com/crotchrockets3/brakes/brake8.JPG
https://i48.photobucket.com/albums/f216/stinkwheel/stewbrakes/brake8_zpsdbdf4fd8.jpg
Tighten nipple again, release lever. Repeat this sequence of lever in, nipple open, nipple close, lever out, until the brake fluid coming through the clear tube is free of air bubbles. Now do the same on the right hand caliper. *remember to keep topping the master cylinder if it needs it!
7. Your hoses should now be full of nice fresh fluid. Make sure you have the correct amount of fluid in your master cylinder and put the top back on it.
8. Pump the lever hard and check all connections for leaks. Check your steering and suspension travel and make sure nothing snags. Everything okay? Jobs a good ‘un.
https://mysite.freeserve.com/crotchrockets3/brakes/brake10.JPG
https://i48.photobucket.com/albums/f216/stinkwheel/stewbrakes/brake10_zpsf6335690.jpg
Take the bike for a little test run, being cautious with your new sharp front brakes.
Little Cheat.
This is a little something that makes the initial part of bleeding the hoses a bit easier. Ideally you connect a syringe to the clear pipe which is connected to the caliper nipple and create a vacuum to pull the fluid through the new hoses. However I didn’t have a spare syringe lying about, so I made a simple device to create the vacuum using a squeezy ketchup bottle with an extra hole in it. Connect clear hose to ‘normal’ hole in the cap. Squeeze bottle. Cover ‘newly made’ hole with your thumb. Let the bottle return to normal shape and this should create a vacuum. It may not be a massive vacuum that it causes but it is certainly enough to draw the brake fluid through. So now the sequence becomes, create vacuum, undo caliper nipple, watch the fluid come though the clear pipe, tighten nipple. I used this method at the beginning of the bleeding process but finished off the job in the more standard way using the brake lever.
https://mysite.freeserve.com/crotchrockets3/brakes/brake9.JPG
https://i48.photobucket.com/albums/f216/stinkwheel/stewbrakes/brake9_zpsef9714ab.jpg ____________________ "Unlike public school you don't need to have your arse up and your head down to go a long way...." |
Back to top |
You must be logged in to rate posts![](images/spacer.gif) |
![](/images/spider_left.gif) |
There is a gap of 4 years, 331 days between these two posts... |
![](/images/spider_right.gif) |
rc211v |
![](images/spacer.gif) rc211v Nitrous Nuisance
![](images/avatars/190469822491d5fea541fc.jpg)
Joined: 08 Oct 2007 Karma : ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_1.gif)
Back to top |
![](templates/standard/images/spacer.gif) |
Shay HTFC |
![](images/spacer.gif) Shay HTFC World Chat Champion
![](images/avatars/1375937917480a71da1dafc.jpg)
Joined: 18 Mar 2007 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_8.gif)
Back to top |
Tristan. |
![](images/spacer.gif) Tristan. World Chat Champion
![](images/avatars/1034949927517ea523d605c.jpg)
Joined: 26 May 2007 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_9.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 01:27 - 08 May 2008 Post subject: |
Did mine last week, keep burning my hand on my disk when locking the bike up quick idiot tip, if you take off your front mudguard to protect it from fluid remember to put it back on before you go for a test run, otherwise you'll complete your lap of the block missing the shrink wrap on one side of your hose .
www.mc-sp.co.uk is a great place for hel lines, couldnt ask for a quicker and more personal service (if he hasnt got your bikes hoses on ebay email him through ebay or PM sickpup on here) |
Back to top |
Jockey |
![](images/spacer.gif) Jockey Scooby Slapper
![](images/avatars/135178788947c09b531b10e.gif)
Joined: 23 Sep 2007 Karma : ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_8.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 16:41 - 17 May 2008 Post subject: |
Read this thread about a week ago and thought it was first class, i really thought you`d have had more responses, do keep doing them, you have a great insight into mechanical things. -Jockey. ____________________ Current bike VFR 400 R NC30, others now gone. |
Back to top |
Stew |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 23:19 - 18 May 2008 Post subject: |
Lol, I like how this has re-appeared after such a long time. ![Very Happy](images/smiles/icon_biggrin.gif) ____________________ "Unlike public school you don't need to have your arse up and your head down to go a long way...." |
Back to top |
Steve H |
![](images/spacer.gif) Steve H World Chat Champion
![](images/avatars/116344591849609aef4cbcb.jpg)
Joined: 18 Oct 2003 Karma : ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 06:31 - 19 May 2008 Post subject: |
Back to top |
Tony corner |
![](images/spacer.gif) Tony corner Two Stroke Sniffer
![](images/avatars/11634459184835803a25bf8.jpg)
Joined: 22 May 2008 Karma : ![Good Karma (Level 2)](/images/karma/green_9.gif) ![Good Karma (Level 2)](/images/karma/green_9.gif) ![Good Karma (Level 2)](/images/karma/green_8.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 11:03 - 22 May 2008 Post subject: |
Fantastic write up.
Did mine but replaced with dot 5.
Tried not using the bleeding kit at first too, not a good idea.
A good tip is to keep one of the standard lines at the caliper end and cut the tube about an inch from the crimp.
Now when your calipers pistons are stuck or need cleaning, take the caliper off and use the old end you kept on the caliper.
Use an air line or battery air pump with the air bed attachment on it and push it into the brake line, presto piston pops out.
Done this a couple of times with seized pistons, but man do they pop out , so watch your fingers. Oh and a bit of fiddling with clamps you can take the pistons out in turn ____________________ All your motorcycle security all in on place.....
https://www.elitesecuritysupplies.com/
https://security-chains.com |
Back to top |
There is a gap of 4 years, 148 days between these two posts... |
icantakeittob... |
![](images/spacer.gif) icantakeittob... L Plate Warrior
Joined: 17 Sep 2012 Karma : ![Good Karma (Level 1)](/images/karma/green_9.gif) ![Good Karma (Level 1)](/images/karma/green_3.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 21:35 - 16 Oct 2012 Post subject: Missing images |
All the images are gone ![Sad](images/smiles/icon_sad.gif) |
Back to top |
U_W v2.0 |
![](images/spacer.gif) U_W v2.0 World Chat Champion
![](images/avatars/1070986924fb6cc37f3da0.jpg)
Joined: 07 May 2012 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_3.gif)
Back to top |
_Iain_ |
![](images/spacer.gif) _Iain_ Banned
![](images/avatars/125235041853eb29080a4d6.jpg)
Joined: 01 Feb 2012 Karma : ![Appaling Karma](/images/karma/black_9.gif) ![Appaling Karma](/images/karma/black_9.gif) ![Appaling Karma](/images/karma/black_9.gif) ![Appaling Karma](/images/karma/black_9.gif) ![Appaling Karma](/images/karma/black_9.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 00:54 - 17 Oct 2012 Post subject: |
Nine years later, and your suprised why exactly?
Y U DIG UP ANCIENT THREAD & MAKE USELESS POST?! ____________________ Please be aware that the above post may be full of complete nonsense.
Back to top |
icantakeittob... |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 21:49 - 03 Nov 2012 Post subject: |
Because it's in the The Workshops guides sticky - https://www.bikechatforums.com/viewtopic.php?t=33116. It's the 3rd link a the top of the page! Not exactly digging up.
The guides page needs updated if the stuff on it is out of date. |
Back to top |
There is a gap of 1 year, 281 days between these two posts... |
sqarider |
![](images/spacer.gif) sqarider Derestricted Danger
Joined: 12 Aug 2014 Karma : ![Good Karma (Level 2)](/images/karma/green_9.gif) ![Good Karma (Level 2)](/images/karma/green_9.gif) ![Good Karma (Level 2)](/images/karma/green_7.gif)
Back to top |
ripzay |
![](images/spacer.gif) ripzay Nitrous Nuisance
Joined: 01 Dec 2008 Karma : ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_6.gif)
Back to top |
Ste |
![](images/spacer.gif) Ste Not Work Safe
![](images/avatars/12289216435ee0c5ffddaaf.jpg)
Joined: 01 Sep 2002 Karma : ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_1.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 20:05 - 12 Aug 2014 Post subject: |
Welcome to BCF history. ![Mr. Green](images/smiles/icon_mrgreen.gif) |
Back to top |
sqarider |
Back to top |
Wafer_Thin_Ham |
![](images/spacer.gif) Wafer_Thin_Ham Super Spammer
![](images/avatars/11634459184861e627e1b8d.jpg)
Joined: 18 Nov 2005 Karma : ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_4.gif)
Back to top |
sqarider |
Back to top |
virus |
![](images/spacer.gif) virus World Chat Champion
![](images/avatars/14981294165b7c8e98abfa1.jpg)
Joined: 17 Aug 2006 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_6.gif)
Back to top |
sqarider |
Back to top |
Rowey |
![](images/spacer.gif) Rowey World Chat Champion
![](images/avatars/1904698224965f4941223e.jpg)
Joined: 07 Oct 2007 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_0.gif)
Back to top |
Ste |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 11:27 - 13 Aug 2014 Post subject: |
Which reply hasn't been helpful? ![Confused](images/smiles/icon_confused.gif) |
Back to top |
chris-red |
![](images/spacer.gif) chris-red Have you considered a TDM?
![](images/avatars/87601472557ad6e373068.jpg)
Joined: 21 Sep 2005 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_2.gif)
Back to top |
lihp |
![](images/spacer.gif) lihp World Chat Champion
Joined: 22 Sep 2010 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_7.gif)
Back to top |
temeluchus |
![](images/spacer.gif) temeluchus World Chat Champion
![](images/avatars/14286187745175e544b7c61.jpg)
Joined: 01 Oct 2008 Karma : ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_1.gif)
Back to top |
The last post was made 9 years, 310 days ago. Instead of replying here, would creating a new thread be more useful? |
