Why is my moped so loud!
skeppy
PostPosted: 00:41 - 13 Feb 2009    Post subject: Why is my moped so loud! Reply with quote
Its a 50 cc piaggio nrg.. its seriously loud what could be causing this.. ? im a novice sorry.
Wise1
PostPosted: 00:42 - 13 Feb 2009    Post subject: Reply with quote
Without stating the obvious does it leak? Put your hand over the end if you can as its a scooter and it should cut out after a few moments. If it does not then its got holes or leaks somewhere.
Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600
skeppy
PostPosted: 01:11 - 13 Feb 2009    Post subject: Reply with quote
could this be because there is no gasket perhaps?
I heard they are quite cheap to buy....?
The Artist
PostPosted: 01:51 - 13 Feb 2009    Post subject: Reply with quote
Just do what he said and tell us what happens. It should cut out after a couple of seconds.
If it does, then it could just be the scooter.
Have you modified it in anyway?
K0rnIsAFAGGOT This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Ant132
PostPosted: 10:51 - 13 Feb 2009    Post subject: Reply with quote
What exhaust has it got? On my old moped the wadding had burnt out. 5 for new wadding and it was quiet again! Simple to do, unbolt the silencer, check the wadding (should be obvious if its burnt) clean it all out in there and wrap some new stuff around the baffle. Thumbs Up
http://i101.photobucket.com/albums/m62/ant-147/DSC01270.jpg
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
skeppy
PostPosted: 12:39 - 13 Feb 2009    Post subject: Reply with quote
Take a look at this basically need to know what im missing
http://img9.imageshack.us/my.php?image=dsc00070tg8.jpg
http://img187.imageshack.us/my.php?image=dsc00071ca9.jpg
http://img9.imageshack.us/my.php?image=dsc00072ey7.jpg
NSR Mick
PostPosted: 12:42 - 13 Feb 2009    Post subject: Reply with quote
Are you reading replies to this thread or not?
Post a video or sound clip.
skeppy
PostPosted: 12:58 - 13 Feb 2009    Post subject: Reply with quote
DanielSON wrote:
Where is the cylinder cover? Bike look's air cooled so get a cylinder cover on there. (If its liquid ignore that).
Your missing a battery, a part of the exhaust bracket and a rear mudguard. Laughing
Have you tried covering the exhaust to see if it cuts out?
nah I got the cylinder cover just took it off, anyway yeah im aware of the battery which im getting sorted soon, how much is an exhaust bracket and mudguard roughly...?
Finglonga
PostPosted: 13:22 - 13 Feb 2009    Post subject: Re: Why is my moped so loud! Reply with quote
Simple answer is it has a non standard loud(as in annoying) exhaust on it.
Andy Sez....
F.Y.Y.F.F.
Ant132
PostPosted: 13:35 - 13 Feb 2009    Post subject: Reply with quote
Looking at the exhaust I refer back to my original post! The silencer is removable (see the two bolts?). Whip it off and check, its an easy solution if it is burnt wadding! Thumbs Up
PostPosted: 15:37 - 13 Feb 2009    Post subject: Reply with quote
Why did you take the cover off?
It needs that to keep cool, otherwise it will overheat.
Ariel Badger
PostPosted: 22:25 - 14 Feb 2009    Post subject: Reply with quote
Go to a bike shop and buy a gasket, they are quite cheap.
veze
PostPosted: 10:06 - 15 Feb 2009    Post subject: Reply with quote
he didnt even answer whether he coverd the end of the exhaust or not. i bet he didnt. Laughing
tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300
Pete.
PostPosted: 15:58 - 15 Feb 2009    Post subject: Reply with quote
I'm with finlonga - the exhaust looks like a noisy aftermarket one. If you want quiet then find an original exhaust.
a.k.a 'Geri'
tutton
PostPosted: 12:27 - 16 Feb 2009    Post subject: Reply with quote
This op is a donk.
hes made about 4 threads on the same thing,
Its quite obvious that as he said the previous seller said it needed a new gasket, the bikes very noisy, and he can smell fuel up from under the bike that the gasket it should have is knackered or non existant?
The last post was made 7 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: discovery (www) - Page Generation Time: 3.38 Sec - Server Load: 1 - MySQL Queries: 16 - CDN Objects: 50 - Page Size: 101.78 Kb
