Bandit 400 Carb Issue - Help Please!
KevKwak
PostPosted: 14:59 - 01 Apr 2009    Post subject: Bandit 400 Carb Issue - Help Please! Reply with quote
Got the bike taxed today and went a wee run. The first 20 mile were ok then it started running on what sounded like 2 cylinders. I thought ok, I'll get new plugs (since i had already replaced two and knew two were a bit so-so).. changed them and it was still the same. Pulled the tank off, plugs out, noticed they were dry so knew fuel wasn't getting through. Took the airbox off and put my hand over each carb and hit the starter.. pulling the fuel up ok on all carbs.
My question is, why aren't the carbs pulling the fuel up?
Bike is running again but begins to stutter above 5k, if under load and i try to give it some it'll just bog down above 5k.
I'm going to pull the carbs apart again and give them an overnight soak in after i've cleaned them just to be sure. Any preference in what to soak them in? And any ideas as to why fuel isn't getting pulled up.
BanditsHigh
Worse than a woman
PostPosted: 15:03 - 01 Apr 2009    Post subject: Reply with quote
Which two cylinders ... could be one of your HT coils is beginning to give up Thumbs Up
KevKwak
PostPosted: 15:09 - 01 Apr 2009    Post subject: Reply with quote
Checked the coils as per haynes manual, resistances on primary and secondary side seem ok (might be a different story under load though)..
I don't think it's the coils though as the plugs were bone dry, definitely wasn't getting fuel.. sa soon as i 'primed' the carbs again it started on the button.
oh, and the bike eventually didnt run at all, just started running on two, then down to nothing.
b-f-c
PostPosted: 15:19 - 01 Apr 2009    Post subject: Reply with quote
I had one of these before.
If its anything like mine was, the tank is very slowly rusting from inside, and the rust is so fine it was making its way into the carbs and choking them up.
A clean out of the carbs, a fuel filter and the possibly a tank treatment might be called for.
KevKwak
PostPosted: 15:35 - 01 Apr 2009    Post subject: Reply with quote
yeah my old tank was rusted. I got a new one, rust freee, cleaned it out, new fuel lines and filter.. carbs have just been cleaned out but they were manky inside! might need another clean.. it's all i can think of.
The needles in the carbs are straight, the tips of them are like new, i couldn't see any faults.. they slide fine.
b-f-c
PostPosted: 15:45 - 01 Apr 2009    Post subject: Reply with quote
Its because they're a grey import. I've never had it on any other bike. The rust is a fine as talc. Air gun through the the lot. Tank, pipes and carbs.
I'd done this half a dozen times before I thought of using a fuel filter Embarassed
Something like POR 15 through the tank will help prevent it re-occuring (remove the fuel tap 1st though)
KevKwak
PostPosted: 15:48 - 01 Apr 2009    Post subject: Reply with quote
aye they are supposed to be quite bad for it rusting. Mine was sitting outside for almost 2 years that's why the original tank was rusted. The new tank however is clean as a nut! and it's all been cleaned out, new fuel lines.. I doubt it's rust but yeah, it probably is crapped up with something.. Laughing
I just bought some carb cleaner so i'm going to strip them again (argh).. crappy job but someones got to do it.
Just wish i knew more about carbs.. bit too late to learn though are they're all friggin FI nowadays,
b-f-c
PostPosted: 15:55 - 01 Apr 2009    Post subject: Reply with quote
Good luck sorting it Thumbs Up
Honestly, it will look shiny and clean, but underneath the shine the bugger is slowly rusting. The mechainc I spoke to at the time said the slight silver/yellow colour I could see in the tank was the rust, there was no other sign.
It was one of the reasons I got rid of mine in the end
CHR15
Turbo nutter bastard
PostPosted: 17:36 - 01 Apr 2009    Post subject: Reply with quote
sounds like the main jet could be blocked, i had this problem on one cylinder of my gs, it would go along fine, but as soon as you reached 5k it would die. cleaned some soil like stuff out of the float bowl and it works fine.
first, just try the drain screws on all the carbs, the main jet is lower down then the others.
Turbocharged Bandit S 1200 / project death weapon / GK73A
junglejim: Fuck you aids head. ///// Cornish: my boobs have been spaffed all over
20:15:10 DOTTYDUCK: lmao aww chris.. marry me... your pics are to cute!
KevKwak
PostPosted: 19:18 - 01 Apr 2009    Post subject: Reply with quote
Stripped the carbs right down (exlcuding seperating them etc obviously), took the jets out, needles, split the floats and checked the needle in them.. carb cleaner, air compressor, should be clean as a whistle.
went out on it, pretty much exaclty the same, starts hesitating at 6k..
could it be anything to do with valve adjustments or anything like that?
CHR15
PostPosted: 20:34 - 01 Apr 2009    Post subject: Reply with quote
shouldnt think so.
quick test, try reving it past 6k in neutral. what happens?
KevKwak
PostPosted: 23:08 - 01 Apr 2009    Post subject: Reply with quote
you can rev it past 6k in neutral (no load) but it's rough and will struggle to get to 9k - 10k, occassionally one or two small backfires and a little black smoke.. If i try give it full throttle it'll bog down, got to give it part throttle to get the revs to rise.
CHR15
PostPosted: 09:28 - 02 Apr 2009    Post subject: Reply with quote
well, thats good...in a way,
it rules out an electrical problem, ie coils.
if it bogs when you give it sudden bursts of throttle, i would deffo say it was fuel related, either mixture, split carb rubbers, or somethings missing from the carbs.
try this, give it a handfull of throttle, till it starts to bog, then quickly hit the kill switch. take the plugs out and have a look.
BLUEX5
PostPosted: 10:44 - 02 Apr 2009    Post subject: Reply with quote
Mine was an absolute cvnt for this, it would usually result in it fouling the plugs. Never really solved it untill I had the carbs ultrasonically cleaned, apparently the main problem was a blocked pilot circuit.
21:07:08 nowhere.elysium: yeah this place seems to swing between neo-nazi dogma, rapeman, and http://www.youtube.com/watch?v=itvJybdcYbI
KevKwak
PostPosted: 20:18 - 02 Apr 2009    Post subject: Reply with quote
Stripped the down again today, bathed the bodies in carb cleaner (got a 5 litre bottle today) scrubbed everything with a toothbrush etc.. all the usual, compressed air, carb cleaner spray. Nothing is blocked!.. Still the same result though, perhaps mildly better but not by much. Checked the float bowl heights and jet sizes as per manual and all are ok.
I'll pull the plugs tomorrow morning, was going to do it tonight but i forgot and put the tank back on Rolling Eyes .
I'm assuming spark gaps wouldn't be out that much out of the box, I haven't checked them yet, I'll do that tomorrow, too.
Failing that i'll try the coils off the other bandit first just in case like Bandtshigh says, they are on their way out.
Thumbs Down Sad
KevKwak
PostPosted: 18:41 - 03 Apr 2009    Post subject: Reply with quote
Got the bandit running fairly well.. it's a bit boggy around town/low revs but no to the extent it stalls.. all good all the way up to bout 10k then you can hear it maybe burbling a bit. Going to have to find a new endcan for it and see if that makes a difference.
baldy
PostPosted: 18:55 - 03 Apr 2009    Post subject: Reply with quote
Have you balanced the carbs? It can cause very strange problems if they aren't balanced.
One day i will rule the world, just not today.
KevKwak
PostPosted: 20:20 - 03 Apr 2009    Post subject: Reply with quote
yup, balanced them again today after fixing the prob.
regarding the poor running at idle, and needing a few revs or a dip of the clutch to get it going from a standstill I think i'll fine tune the pilot screws tomorrow.. then it's on to valve adjustments. It still has some hesitation above 8-9k in the higher gears too.. fun eh?
KevKwak
PostPosted: 16:22 - 04 Apr 2009    Post subject: Reply with quote
Took the carbs off this morning. I checked/adjusted the float heights again. The pilot screws were 2 turns out on each carb, I think the base setting is 1.5 turns?
After sticking the carbs back on I balanced them. I set the pilot screws at 1.5 turns out and tried to fine tune them but it wasn't too 'clear' so I set them all about 1.75 turns out (somewhere in between)
Went a run and I don't think it's as bad around town, although I haven't gone a long enough run to find out. It runs great between 3k - 8k. As it gets to 8k there's a hesitation and that sort of goes up through the rest of the rev range (it's ok in 1st & 2nd gear, 3rd on and it hesitates)
Any carb gurus got any ideas? I've been reading up on carbs and what affects what, float height, pilot screw, needle jet, jet needle, main jet etc etc..
What would cause the hesitation from 8k on (this is at 3/4 - full throttle), going from a lean or good mixture to a rich mixture or vice versa?
Mad_Sunday
PostPosted: 14:26 - 07 Apr 2009    Post subject: Reply with quote
Does it still have the original HT leads? If so take them off and throw them as far as you can. Replace them with nice new stuff and try again.
Just bought a 250 Bandit for my missus so expect to have loads of problems getting it running 100% for her.
Pete
Linux, it's the future..........Computer virus?.........whats that then?
KevKwak
PostPosted: 16:23 - 07 Apr 2009    Post subject: Reply with quote
It's ok, got her running sweet today, sounding much healthier and revving all the way to 12k (never tried any further) in 6th! Cool Idling fine and great around town now! Great on and off the throttle at all positions (full-1/2, 0-full, 3/4-1/2, 1/8-full etc etc lol)
Dance! Dance! Dance! Chequered Flag
I take it you can just take the HT lead out from the coils? just unscrew like you do on the plug caps? Was going to but a length of lead today and do that but I wasn't sure whether they come away from the coils ok or not. Might just replace them for the sake of it anyway.
Good luck getting the 250 running nice.. quite rare those ones eh? still quite nippy from what I hear.
Mad_Sunday
PostPosted: 16:48 - 07 Apr 2009    Post subject: Reply with quote
They are probably "fixed" into the coils, I just rip them out and then glue new ones in. Don't worry about being able to connect them to the internal wires, a spark will jump 6mm if it needs to. Just get the copper as near as possible (both the same distance) and you should be OK.
The 250 looks wicked, it's a sort of apple green which looked kind of weird. I thought it was a strange colour for someone to choose for a re-paint, then discovered its the original colour! It has grown on us!
I'll get a photo of it on here soon.
Pete
chillyman0
PostPosted: 18:05 - 07 Apr 2009    Post subject: Reply with quote
yeah will be intersting to see the 250 too Smile
got some bad problems with one cyclinder on my bandit 4 really dont know if its carb or cyclinder problems.... fancy coming all the way down south here to have a look at it for me KeV6?? Razz
got some updated pics in my thread btw
KevKwak
PostPosted: 18:51 - 07 Apr 2009    Post subject: Reply with quote
I've had enough tinkering with these bikes lol.. other one decided to run on 3 just before it went for its mot, just cleaned up the plug (slightly fouled with being idling etc and not been a run)
What are your plugs like anyway? Might tell you a lot about what's happening.
baldy
PostPosted: 19:18 - 07 Apr 2009    Post subject: Reply with quote
WTF? Shocked
I'm glad that you're not fixing my bikes. The wires are joined for a reason. When the spark has to jump a gap it takes a lot of energy and a little bit longer to do, so by the time the spark is at the plug the timing will be late and the spark low on power. Plus it's also possible that the spark won't jump the gap at all.
The last post was made 4 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
You can download files in this forum
Debug Mode: ON - Server: peanuts - Page Generation Time: 0.06 Sec - Server Load: 0.24 - MySQL Queries: 16 - CDN Objects: 56 - Page Size: 141.03 Kb
