Author |
t121anf |
t121anf World Chat Champion
Back to top |
Fawbish |
Fawbish World Chat Champion
Back to top |
t121anf |
Back to top |
Fawbish |
Posted: 13:10 - 18 Aug 2009 Post subject: |
6mm 2core+earth should suffice tbh. Off top of my head, it'll handle upto around 32 amps, so nothing should really be pushing that much. 20 amp MCB should cover it. However, if you want a proper house sparkies advice, Sparks! on here will know better than I.
Theres a big debate over whether you should have an RCD/mCB in the house or at the shed, but that really rests on legalities etc. as long as youre terminating safely and you've got a breaker before the (assumed) sockets etc, should be fine.
____________________ "Oh....it looks like Average Joe's is forfeiting the match!" - "Yeah, its a risky strategy but lets see if it pays off for 'em Cotton." |
Back to top |
t121anf |
Back to top |
tatters |
tatters Exxon Valdez
Posted: 17:21 - 18 Aug 2009 Post subject: |
Fawbish wrote: | 6mm 2core+earth should suffice tbh. Off top of my head, it'll handle upto around 32 amps, so nothing should really be pushing that much. 20 amp MCB should cover it. However, if you want a proper house sparkies advice, Sparks! on here will know better than I.
6mm!!! He wants power to a shed not a electric cooker
2.5mm 3 core SWA buried between the house and shed, 20 amp RCD from the house then gland straight into a twin 13 amp socket at the shed.
theres loads of guides about online how to do it properly and old posts on here if you search for them ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
Back to top |
Sparks! |
Sparks! Sir Tart-a-lot
Posted: 22:42 - 18 Aug 2009 Post subject: |
tatters wrote: | Fawbish wrote: | 6mm 2core+earth should suffice tbh. Off top of my head, it'll handle upto around 32 amps, so nothing should really be pushing that much. 20 amp MCB should cover it. However, if you want a proper house sparkies advice, Sparks! on here will know better than I.
theres loads of guides about online how to do it properly and old posts on here if you search for them |
As above really, for a simple shed install of 1 socket 1 light.
2.5mm SWA buried, it's quite a thin cable so 25mm ducting should be fine as long as theres no crazy bends in it. Should lay some warning tape over the duct too before filling the hole back in..
Gland direct into a socket and then put a fuse spur in for the light... or gland into an isolator then go out to the socket/spur if you really want.
You shouldn't really use a fuse spur as a light switch but to be perfectly honest, in a shed, I would ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Back to top |
t121anf |
Back to top |
Fawbish |
Posted: 11:09 - 19 Aug 2009 Post subject: |
Apologies. We run allsorts in our garage, often a few compressors, lighting, and bench tools at the same time, so I immedietely assumed the worst.
I did say people would know better though. ____________________ "Oh....it looks like Average Joe's is forfeiting the match!" - "Yeah, its a risky strategy but lets see if it pays off for 'em Cotton." |
Back to top |
map |
map Mr Calendar
Posted: 13:22 - 19 Aug 2009 Post subject: |
As said above the 2.5mm solid core.
Ideally you will need it buried.
If you bury it you will also need armoured cable (helps stop things chewing it and also if someone tries to put a spade through it). ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger? |
Back to top |
t121anf |
Back to top |
map |
map Mr Calendar
Back to top |
tutton |
tutton World Chat Champion
Back to top |
Kickstart |
Kickstart The Oracle
Back to top |
nick606 |
nick606 World Chat Champion
Back to top |
nick606 |
Back to top |
Mike_GSi16v |
Mike_GSi16v Derestricted Danger
Back to top |
Sparks! |
Back to top |
Sparks! |
Back to top |
tutton |
Back to top |
Sparks! |
Back to top |
tutton |
Back to top |
Sparks! |
Back to top |
t121anf |
Back to top |
Sparks! |
Back to top |
The last post was made 14 years, 285 days ago. Instead of replying here, would creating a new thread be more useful? |
