Author |
maximilian |
maximilian L Plate Warrior
Posted: 14:14 - 07 Sep 2009 Post subject: Meta Alarm 357T Stuck in sleep mode |
My 2001 CB600 Hornet is fitted with a Meta 357T and I've been having some problems with it.
I have left it for a few weeks and understandably it has gone into sleep mode. However I am unable to wake it up.
According to the instructions i should switch the ignition on and press the fob once to wake it up.
I do this and nothing happens. I have tried holding the fob button down, doing it in all sorts of combinations, ignition off/on lights on/off, cutt-off on/off. No response.
The machine's battery is healthy and had pleanty of charge over the weeks whilst it was in sleep mode.
I have checked all fuses - no problems.
No matter what I do i cannot provoke any reaction from the alarm; The LED does not flash, the siren does not sound, it does not respond to either of the 2 alarm fobs.
I have tried swapping batterys around the fobs (incase one fob is faulty)
As the system is in sleep mode, it cannot be re-programmed as it is totally unresponsive, and the LED is needed to perform most re-programming functions (add new fob etc)
The only glimer of hope is that I left the ignition on for abot 5 mins, whilst reading the instructions, and suddenly the siren sounded for 2-3 seconds, then it returned to sleep mode. This suggests that perhaps the unit itself is functional, it just cannot recognise the fobs any longer.
I presume this is not an isolated incident, as i have read similar stories on other forums.
Has anyone succesfully resolved this problem? Any advice anyone?
Thanks |
Back to top |
maximilian |
Back to top |
num1 |
num1 Borekit Bruiser
Posted: 20:35 - 07 Sep 2009 Post subject: |
i am having the same problem. have been working on it all day and still not working same alarm as well.i think i need a new 1. ____________________ Staffordshire Bull Terriers Breeders L2/Hc Tested Clear
www.mandys-staffs.piczo.com |
Back to top |
maximilian |
Back to top |
That_Hornet |
That_Hornet World Chat Champion
Back to top |
sickpup |
sickpup Old Timer
Back to top |
The last post was made 14 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
