Square Piston 2 Stroke
PostPosted: 22:58 - 27 Nov 2009    Post subject: Square Piston 2 Stroke Reply with quote
Clicky
Thought this was quite interesting.
The Artist
PostPosted: 23:00 - 27 Nov 2009    Post subject: Re: Square Piston 2 Stroke Reply with quote
ms51ves3 wrote:
Clicky
You would, it only has 2 strokes Laughing
But yeh, pretty interesting.
PostPosted: 23:02 - 27 Nov 2009    Post subject: Re: Square Piston 2 Stroke Reply with quote
Anything that will keep 2 strokes alive Wink
Just found some more information on it.
Clicky
PostPosted: 00:12 - 28 Nov 2009    Post subject: Re: Square Piston 2 Stroke Reply with quote
The enclosed crank (and thus not needing petroil lubrication I presume) is interesting, but presumably this could be transferred to a conventional round engine - though sealing would maybe be harder.
For any serious performance I suspect the corners would introduce too many problems.
PostPosted: 09:52 - 28 Nov 2009    Post subject: Re: Square Piston 2 Stroke Reply with quote
Maybe you could use piston rings on the top and bottom of the piston. Only gave it a quick thought though and you'll probably have the issue of oil leaking out of the ports.
Robby
Dirty Old Man
PostPosted: 11:03 - 28 Nov 2009    Post subject: Reply with quote
Interesting idea, very compat. You could make it a flat twin and not make the engine much bigger, which would also overcome any balance problems - just extend the piston down, so you in effect have a rectangular double ended piston with a hole in the middle for the crank to run in.
chrisw
PostPosted: 11:08 - 28 Nov 2009    Post subject: Reply with quote
Interesting idea, almost a piston/wankel hybrid!
colin1
Captain Safety
PostPosted: 01:56 - 29 Nov 2009    Post subject: Reply with quote
He said it's not been used before, but I've seen a diagram of something very similar before.
Possibly a pump rather than an engine.
The last post was made 14 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.87 - MySQL Queries: 17 - Page Size: 57.75 Kb
