Author |
ray 316 |
ray 316 Two Stroke Sniffer
Posted: 15:37 - 22 Dec 2009 Post subject: vacuum fuel tap |
Can someone explain how these work because of the info l'm getting off here and elsewhere they seem to think the honda vision might have a vacuum fuel trap and this may be the cause of the petrol leak l have when the bike is stationary.
If it works like a on/off tap for fuel and l find that the vacuum fuel trap is faulty could l take it off and just put on a on/off tap.
Also if it works on vacuum when the bike is running and should shut off when its standing.....Say it is faulty and petrol is going through would'nt the carb float value shut off the petrol at a certain height so why would it leak petrol still... |
Back to top |
temeluchus |
Posted: 15:54 - 22 Dec 2009 Post subject: |
take a look at this
https://www.gpzzone.co.uk/gpzzone/technical/fueltap.jpg
you have a plunger (I) that blocks off the fuel supply until it is pulled back by vacuum supplied by the engine, via a vacuum pipe from the carbs or throttle bodies to the far side of plate K. When the engine stops spring J pushes the plunger back into the tap body (G) shutting off fuel supply. The PRIME position manually pushes the plunger back and allows fuel to flow. ____________________ Some shite cruiser. Now with guns and FREEDOM! |
Back to top |
finpos |
finpos World Chat Champion
Back to top |
finpos |
Back to top |
ray 316 |
Back to top |
finpos |
Back to top |
finpos |
Back to top |
ray 316 |
Back to top |
yen_powell |
Back to top |
finpos |
Back to top |
lisalin |
lisalin Banned
Posted: 02:46 - 23 Dec 2009 Post subject: |
wow
thanks for your sharing !!
___________________
Both house md dvd and p90x dvd are my fav . |
Back to top |
ray 316 |
Back to top |
ray 316 |
Posted: 08:27 - 24 Dec 2009 Post subject: |
Had a inspection of the fuel line coming from the tank down to the carb without taking the side panel off as l dont know how to get the seat lock barrel off. Anyway l could see up inside the panel and saw the fuel line with the vacuum trap right near the tank and l still had some petrol left in the tank but no leak coming from the vacuum trap or fuel line. l started the bike up and left it running for a minute then switched off but no leak from the area near the air filter So if the carb is dirty/needs cleaning if sticking l need to get the panel off, l'm just going to have to work out how to get the lock barrel off. l can see it has a clip on the inside of the panel holding the barrel and a bar from the barrel to the lock mechanism but l cannot work out what how to get the bar dismantled from the lock mechanism... |
Back to top |
27cows |
27cows World Chat Champion
Back to top |
The last post was made 14 years, 154 days ago. Instead of replying here, would creating a new thread be more useful? |
