Author |
Mark65 |
Mark65 World Chat Champion
Posted: 10:23 - 22 Feb 2011 Post subject: YBR125 Clutch Judder Sorted |
Hi all
Well i finally cured my slight cluth judder from starting off in a hot engine, this was an old post a while back as the bike was very low milage at the time, i had tried 2-4 different grades of oil and really put it down to notched clutch basket from the previous owner, any way at xmas when i did nmy chain and sprocket change and swingarm service i lubed the clutch cable and after a day or two the judder was less noticable, so i ordered a new cable and installed it over the weekend, wow a fair bit of difference, it is so light now and no judder even with hot engine, the clutch must be so ligt on these that the slightest bit of friction in the cable is enough to make it stick. I cut the nipple off the old cable and it was still smooth with a few tiny bits of somthing in there, i assume the outer cable has worn and that caused the inner to get stuck a tad in use.
So there we go more knowledge gained, im sure others suggested the cable could be the problem in my original post all that time ago and if they did my apologies for not looking into it as at the time the bike had hardly any milage so i didnt think it could have been the cable.
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
Back to top |
Swim41 |
Swim41 Trackday Trickster
Posted: 20:53 - 22 Feb 2011 Post subject: |
Thanks for posting that, my YBR125 does this, a sort of roughness just as the clutch is let all the way out. Never occured to me it would be the cable, I'll have look at the weekend.
____________________ Yamaha XJ600N |
Back to top |
neil. |
neil. World Chat Champion
Back to top |
Mark65 |
Posted: 11:42 - 23 Feb 2011 Post subject: |
I lubed it with acf 50, then when it felt better i bought a new cable, but mine only juddered when hot , it was smooth as silk on a cold engine.
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140510265152&ssPageName=STRK:MEWAX:IT
There was only a tiny bit of grit in the old cable, i originally thought notched basket or warped plate(s), but this seems to have cured mine, although it hasnt done any harm and i have just crossed 13k on it, oh and i had to replace the speedo cable as it just died, that was £12.69 from yamaha, i may even drop down to 10w40 oil from the 15w50 i use, dozy me didnt realise i have been using fully syn oil for the past two years lol. I hope it works for yours too.
Back to top |
chris-red |
Back to top |
The last post was made 13 years, 105 days ago. Instead of replying here, would creating a new thread be more useful? |
