Scooter dies after approx 1 min (NOT SOLVED)
AmirasDaddy
PostPosted: 18:59 - 05 May 2011    Post subject: Scooter dies after approx 1 min (NOT SOLVED) Reply with quote
Hi guys new here after visiting the forum for a while, here is my problem: https://scootdawg.proboards.com/index.cgi?board=2stroke&action=display&thread=38467&page=1 ( yes I know its a scoot, but i have my full licence (due to back problems because of a careless a-hole in a car) and my 2nd baby is on its way this was more about saving money.
Anyway thought I'd post it here to see what other people think it could be.
SpannerMonkey
PostPosted: 19:11 - 05 May 2011    Post subject: Reply with quote
Might have something to do with all the black oily stuff all over your engine there Wink
My bike? A YX140 powered one-off Monkey Bike, something a little different!
AmirasDaddy
PostPosted: 19:14 - 05 May 2011    Post subject: Reply with quote
durr.... I'm asking how do I fix the problem
SpannerMonkey
PostPosted: 19:25 - 05 May 2011    Post subject: Reply with quote
I was joking I was joking Wink
Is your plug firing okay?
AmirasDaddy
PostPosted: 19:30 - 05 May 2011    Post subject: Reply with quote
I know that so was I lol, yes as i have stated in the link, it starts ok ive had to change it/file/sand it down a few time, any idea as to why there is oil over the block?
        SpannerMonkey
        PostPosted: 19:34 - 05 May 2011    Post subject: Reply with quote
        Possible blown head gasket. Just think of all the ways that oil can get access that particular spot. It's hard to say without being there...
        Also my head isnt particularly with it =(
        SpannerMonkey
        PostPosted: 19:36 - 05 May 2011    Post subject: Reply with quote
        Also, maybe a crack in the cylinder head?
        EDIT: is that pic of the engine from above? I'm stuggling to gather the orientation of it for some reason haha! cause it looks like your filter is pretty knackered and gunked up. Check for split hoses....
        AmirasDaddy
        PostPosted: 19:40 - 05 May 2011    Post subject: Reply with quote
        doesnt seem to be any cracks, I will purchase some gaskets tonight off fleabay and replace them. anything I should look for while removing?
        I can't see it being the spark plug being too loose, It was slightly tighter than hand tight.
        AmirasDaddy
        PostPosted: 19:41 - 05 May 2011    Post subject: Reply with quote
        yes from above, filter looked clear to me can see oil in it :S sorry im sort of new to the bike repair world I can clean carbs etc so bear with me please, I really do appreciate your help.
        Brian
        SpannerMonkey
        PostPosted: 19:43 - 05 May 2011    Post subject: Reply with quote
        Just basically keep an eye out for cracks and any obvious signs of leaks.
        Can I just ask the obvious... That IS fuel running through that filter... isnt it? and also, the fuel line either side of the filter is coated in something shiny... this to me says there's some sort of leak around there...
        PostPosted: 19:46 - 05 May 2011    Post subject: Reply with quote
        Sounds like fuel starvation. Either a blocked fuel line/tap or blocked fuel tank breather. Take the fuel line off the carb and check that fuel flows freely for a good 30 seconds.
        AmirasDaddy
        PostPosted: 19:47 - 05 May 2011    Post subject: Reply with quote
        It's the oil filter, no petrol mate, yeah the previous owner had crashed the bike re sprayed bits of it silver, i've done the body work and front wheel as you can see still have bits to do but stupid things keep cropping up.
        SpannerMonkey
        PostPosted: 19:48 - 05 May 2011    Post subject: Reply with quote
        Oil filter? I've never heard of an oil filter on a 2 stroke... This may not be helping your issue.... =/
        AmirasDaddy
        PostPosted: 19:53 - 05 May 2011    Post subject: Reply with quote
        I've took the hoses off the fuel tap and nothing... i.e no petrol coming out and there's a lot in there... Is it possible for it to be a suction system, i.e when the engine is on suction causes the petrol to come through.
        tho the previous owner has re sprayed the tap for some reason,.
        AmirasDaddy
        PostPosted: 19:54 - 05 May 2011    Post subject: Reply with quote
        its coming from the oil tank to the engine, just below the throttle cable.
        MattWadz
        Right, firstly i would test your fueling, im not sure if that peugeot is a gravity fed or vacuum, if its a vacuum then keep the vacuum line on the carb and pull the fuel line off and then turn the engine over and see if it pumps fuel out. if it doesnt then theres your problem, if it does, then it might not be getting past the carb, so clean the carb, if it is clean and its still the same, then its not your carb or fueling, i had a problem like this on my Aerox a while back, it would start, then when i rev it would die/splutter rich and then just cut out and backfire, i changed the plug, and the air filter foam it ran fine. also check if theres a min max on your 2t tank, im not sure but it may be overflowing into the filter idk.
        1. Check Fueling
        2. Clean Carb
        3. New Plug
        Then give it a go and it should start, theres not many reasons it shouldnt run after doing that.
        Get back to me with the results
        Matt
        Hope i helped
        Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R
        PostPosted: 19:57 - 05 May 2011    Post subject: Reply with quote
        Yes it's possible. Follow the fuel line back to the fuel tap. If there is another smaller pipe on the tap, pull that off the other end and suck on it - fuel should now flow. If no fuel flows then you have found your fault.
        AmirasDaddy
        PostPosted: 20:01 - 05 May 2011    Post subject: Reply with quote
        1. Check Fueling
        2. Clean Carb
        3. New Plug
        Matt
        Hope i helped
        Yip its suction based, carb is clean as it was checked firstly, could do with a new plug I guess but it starts fine the problem is it dies, and can hear it back firing sometimes when starting it after it dies, Also what about the oil over the top of the head? (started the engine and petrol came out)
        PostPosted: 20:08 - 05 May 2011    Post subject: Reply with quote
        ...it starts fine the problem is it dies, and can hear it back firing sometimes when starting it after it dies,.....
        Sounds more and more like fuel starvation. Low fuel level is causing a lean condition hence the backfires.
        The fact that it will tick over fine but stops under load says that a small amount of fuel is getting through. Post a photo of your fuel tap. Many have gauze filters inside them that can get blocked.
        AmirasDaddy
        PostPosted: 20:33 - 05 May 2011    Post subject: Reply with quote
        there is a gauze filter inside it and it was clean when i checked earlier.
        forgot to add it can sit and idle for ages, just after a min or two it completely dies, and have to turn they ignition key off and on, sometimes the ignition button does nothing i.e no noise from the starter motor or anything.
        PostPosted: 20:45 - 05 May 2011    Post subject: Reply with quote
        Did you remove it and check the other side?
        It sounds like you've followed a good troubleshooting process TBH. You still need to confirm that you get fuel flowing freely from the tap to the carb.
        AmirasDaddy
        PostPosted: 20:47 - 05 May 2011    Post subject: Reply with quote
        I meant a min or two of riding
        The gauze side, yes I did, I blew through the petrol end to empty the little petrol that was in it.
        really appreciate the help guys Smile
        MattWadz
        PostPosted: 22:01 - 05 May 2011    Post subject: Reply with quote
        Check / Replace your fuel filter? could be blocked.
        Teflon-Mike
        tl;dr
        PostPosted: 22:15 - 05 May 2011    Post subject: Reply with quote
        Is this thing a two stroke?
        If so, could the oil feed pipe from auto lube pump to carburettor have come off / split?
        Would explain oil all over engine.
        would also explain dying under load.
        If the pipe has come off, under load, possibly dragging air through oil port, weakening mixture, but lack of lube, likely to be nipping up.
        MattWadz
        PostPosted: 22:29 - 05 May 2011    Post subject: Reply with quote
        yeah, good point, could be that, if not then id get a new plug, you said you could do with one, so its worth the fiver before doing anything else
        Matt
        The last post was made 12 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
        Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.36 - MySQL Queries: 17 - Page Size: 138.43 Kb
