TZR250 Fix Up (AKA Proud Owner of...) 2015 Thread Revival!
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3 ... 13, 14, 15
 Topic moved: from General Bike Pictures to Show & Tell by Kickstart (12 Aug 2015 - 21:28)
GSF Jamie 600
PostPosted: 23:15 - 06 Feb 2010    Post subject: Reply with quote
I'm going doing the usual run tomorrow if the weather is decent, do you want me to knock on?
PostPosted: 23:36 - 06 Feb 2010    Post subject: Reply with quote
I'm busy Jamster. The weather forecast isn't great anyway.
GSF Jamie 600
PostPosted: 23:40 - 06 Feb 2010    Post subject: Reply with quote
No worries Thumbs Up
I no i wanted to get out today but was at work Sick
Gonna try n get out but knowing my look there will be terrential floods Surprised
PostPosted: 20:10 - 13 Feb 2010    Post subject: Reply with quote
Did a little touch up on the tank repair with my sister's nail varnish Shhh! I've also touched up the lower fairing with some as well. It's turned out quite well. I'll be mock fitting the lower fairing tomorrow.
Before:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1434-1.jpg
After:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1439-1.jpg
And just another picture as I cleaned it a little today:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1445-1-1.jpg
m3-paul
PostPosted: 12:23 - 18 Feb 2010    Post subject: Reply with quote
You are really getting somewhere with your bike. Very jealous of the price you paid for that front disk as I need a new one and don't want to stump up somewhere north of £130. My fuel tap lets fuel pass when the engine is off so i am just about to go and turn the tap 180 degrees so i can force it off and then give the old girl a wash - got to love these old TZR250s Cool .
PostPosted: 16:17 - 21 Feb 2010    Post subject: Reply with quote
Just did a test fitting of my lower fairings but it was a disaster. They simply do not fit. Nothing lines up.
Lines up at the top fairing on the left side:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1495.jpg
But not lining up at the top fairing on the right side:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1497.jpg
And not lining up at the frame on the left side:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1496.jpg
Or the right side:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1498.jpg
And if you do get the right side frame mount to line up, the exhaust touches the fairing at the bottom:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1501.jpg
The V piece is touching the exhausts too:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1499.jpg
Disaster:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1500.jpg
I'm thinking part of the problem is probably because of the bent headlight bracket which I bent back. It may need some more bending Rolling Eyes
So the fairing is back in the place it's been for the past year: Behind me Thumbs Down
st3v3
PostPosted: 16:25 - 21 Feb 2010    Post subject: Reply with quote
That's unlucky.
Do you plan keeping the front indy's?
PostPosted: 16:27 - 21 Feb 2010    Post subject: Reply with quote
st3v3 wrote:
That's unlucky.
Yes, do you have a problem with their size?
PostPosted: 15:48 - 30 Mar 2010    Post subject: Reply with quote
Think I've figured out why the lower fairings don't fit.
https://i15.photobucket.com/albums/a376/ms51ves3/Wirral%20Egg%20Run%202010/DSCF1786-1.jpg
https://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250%2085%20%201.jpg
Can anybody else see the problem?
Dr. DaveJPS
PostPosted: 17:11 - 30 Mar 2010    Post subject: Reply with quote
your headlights/ top fairing is mounted too low?
www.davejps.com
BenR
PostPosted: 17:35 - 30 Mar 2010    Post subject: Reply with quote
Your lower fairings are off an RD350?
PostPosted: 19:31 - 30 Mar 2010    Post subject: Reply with quote
Yes, it's pointing towards the floor.
No Laughing I would have noticed that.
TUG
PostPosted: 19:59 - 30 Mar 2010    Post subject: Reply with quote
Lmfao Do you think? Thumbs Up Laughing Noted for when i prep my SRAD for its sale.
Haz ER-5, innit!
rodeobob
PostPosted: 14:50 - 02 Aug 2010    Post subject: Reply with quote
How did you get on???
Thanks for the pictures of the fairingless TZR. I have been trying to work out how close the TZR and FZR upper fairings are to matching each other, now i have some pictures to compare.
Cheers, Bob.
DT200R '91
DT175 '91
Various IT/DT175 engines for 'projects'
rodeobob
PostPosted: 16:00 - 02 Aug 2010    Post subject: Reply with quote
ms51ves3 wrote:
XlonewolfX wrote:
You wasted money on tape! You should solo key it like i've done with every bike i've owned the most i've had on a key ring is the little advert ribbon for the bike shop and my key for the ignition! Laughing
I have three keys though, one for my lock that slots behind the reg plate, one for the ignition and one for the seat. I can't be bothered having the other two on a different keyring, it would drive me mad having to find it in my pocket.
The tape was free for me anyway because my dad bought it Wink
Are they all the same Yamaha key?? make it one key.
https://www.yamahait.com.au/forum/index.php/topic,7172.0.html
Thought that might be of interest to a young fella like yourself whos up for having a go. You might need a few spare random yamaha lock barrels for the spare sprags.
Ive read through the whole thread and gone ive got the answer for that and then too late you have worked it out or someone has helped out. Good work.
PV issues sorted???
Undo the pulley off the cylinder end, take it off. That will tell you if its seized up in the cylinders or a cable or burnt out motor.
I bought myself these the other night, the pair $400
https://a.imageshack.us/img697/1486/rgrz008.jpg
Maybe i win that game earlier in the thread??
RZ250 and an RG250.
RZ is a bit bent, one carb is seized up but im pretty sure it will run.
The RG has a busted kick starter shaft. Just bought one off eBay.
Not sure what i am doing yet. Ive got a Rolling 2KR FZR250 frame in the shed as well.
Cheers, Bob.
DT200R '91
DT175 '91
There is a gap of 1 year, 23 days between these two posts...
Carlosaurus
PostPosted: 23:20 - 25 Aug 2011    Post subject: Reply with quote
I've read this all the way through, what a thread. I'm loving the look of this 2T! Do you still have the bike?
Great looking bike Thumbs Up
Edit: Just realised I was trawling through old threads and commented on this one not knowing it's almost a year old :/. My bad.
2008 TMEC 125CC SM.
There is a gap of 3 years, 352 days between these two posts...
PostPosted: 00:42 - 12 Aug 2015    Post subject: Reply with quote
I'm back working on the TZR. Sold my Blackbird a couple of weeks ago so I'm down to just this and the old Chaly now (which has not progressed at all, still engineless). I've decided to ride the TZR again because insurance is only £100 so I can't afford not to really.
At the moment I've got fuel leak issues from everything fuel related: carbs, fuel tap and tank. Probably going to get rebuild kits for the first two and then the tank I've just posted about in the workshop section.
Clicky
The hole has grown a bit Neutral
I've got a couple of days free in the next week but then I'm off to India for a month so updates will stop for a bit. Plan is to get it M.O.Ted late September before I head back to university.
Going to try and keep this thread alive with plenty of pictures so stay tuned.
On a non-bike note, could an admin move this thread to Show & Tell please? Never realised it was in this section.
PostPosted: 18:43 - 30 Sep 2015    Post subject: Reply with quote
Small update.
Carbs no longer leak after a quick clean. There was some dirt/rust between the needle and seat stopping it sealing properly.
Fuel tap has been dismantled, got a couple of O rings ordered that should fix it, otherwise I'll buy a full rebuild kit for £35.
Been working on the tank today. Ordered the POR-15 yesterday and it arrived this morning so I've cleaned out the tank, done the metal prep and patched the hole.
https://i.imgur.com/AfhHCuJl.jpg
It'll take 4 days for that to dry and in the meantime my tank will also be drying out from the clean. I'll do the sealing coat on Monday.
PostPosted: 18:50 - 30 Sep 2015    Post subject: Reply with quote
If I remember correctly from when there was a decent TZR forum, the rebuild kits don't kit. Was a few years ago so there might be useful ones out there now though.
K
PostPosted: 19:01 - 30 Sep 2015    Post subject: Reply with quote
K
Yeah, NRP now make their own with the correct 4 holed rubber washer rather than the 5 that came in all the other kits.
Clicky
Sean.S
PostPosted: 19:48 - 01 Oct 2015    Post subject: Reply with quote
subbed for updates.
its always interesting looking through these in depth threads, nice work Smile
The last post was made 8 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Page 15 of 15
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.63 - MySQL Queries: 20 - Page Size: 122.43 Kb
