Author |
1cyl |
1cyl World Chat Champion
Posted: 23:12 - 20 Feb 2012 Post subject: Any tips for drilling rivetts |
Its just not happening, i've got the head off it but just can't sink it, its not spinning but cobolt bit with cutting agent is useless, i think its all stainless steel: rivett and surroundings.
contemplating taking it all off and getting it under pillar drill? but thats a mission just for one poxy rivett.
any tips?
any tits?
Cheers ____________________ Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable |
Back to top |
mattsprattuk |
mattsprattuk Super Spammer
Posted: 23:15 - 20 Feb 2012 Post subject: |
chisel the head off and knock it through with a punch if you need to. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
Back to top |
kevotore_75 |
kevotore_75 Borekit Bruiser
Back to top |
Fairies attack |
Fairies attack Banned
Posted: 01:55 - 21 Feb 2012 Post subject: |
If it is stainless, just hammering it on full speed will only heat it up and then you are in a word of trouble.
Get a decent bit, and only pulse the trigger, so the drill is spinning slowly. This way you will avoid heating it up, and kill the bit plus hardening the rivet.
Generally rivets are a quick 5minute thing, with drill the head and then it falls off and the peice comes off with a bit of force. If you can't get through the head then you have a blunt bit.
Doesn't matter what they are made from of they are blunt, then you might as well be using a feather duster. Quick way to check them if not crude a hell. Put the bit cutting edge down in the palm of your hand. Then turn it, if it is sharp you should feel it picking up your skin and grip tight. If not, it is blunt, and then it is time for the grind stone.
Most people get sharpening drill bits wrong, but a easy way to do it is, get 2 nuts and put them together, the angle between them is what you are aiming for, and also do part of one side, then do the other and keep checking it is the same edge each way. If not the drill will vibrate rather horribly and make a mess of your piece.
Quick tip:
If you start to see blue swarf then your too hot. |
Back to top |
Vincent |
Vincent Banned
Posted: 03:01 - 21 Feb 2012 Post subject: |
Drill going the wrong direction? Done that a few times, soon realise tho. I watched my neighbour the other day trying to drill some wood in his garden with the drill going the wrong way. Made my week Bloody idiot uses a petrol chainsaw to trim his hedge ____________________ Space Is Deep |
Back to top |
mattsprattuk |
Posted: 07:45 - 21 Feb 2012 Post subject: |
On second thoughts, have you knocked the pin through before drilling? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
Back to top |
1cyl |
Back to top |
Walloper |
Walloper Super Spammer
Back to top |
Vincent |
Vincent Banned
Posted: 16:02 - 21 Feb 2012 Post subject: |
Back to top |
Walloper |
Posted: 17:16 - 21 Feb 2012 Post subject: |
Back to top |
1cyl |
Posted: 19:22 - 21 Feb 2012 Post subject: |
[quote="mattsprattuk" knock it through with a punch if you need to.[/quote]
Result!, found my letter punch/stamp set and the impact tool worked a beaut!
Cheers Y'all ____________________ Chase my Witch up, Catch my Snitch up.
Back to top |
The last post was made 12 years, 68 days ago. Instead of replying here, would creating a new thread be more useful? |
