chain tensioning on side stand
Cheerfulgrin
PostPosted: 21:50 - 06 Mar 2012    Post subject: chain tensioning on side stand Reply with quote
is it possible to adjust the chain on my bike whilst its on the side stand or do i need to get a paddock stand?
the owners manual says jack it up or put it on a block then loosen the rear axle.
any advice would be appreciated, as i dont have a paddock stand or jack, cant see where i could lift the bike on one either.
Thanks
--Current Bike: '98 Hornet CB600F
--Previous Bikes 2012 Hyo GT250R - 2010 YBR125 - Back in '91:Suzuki 50cc moped & Honda CB125T Superdream Laughing
--CBT -Feb '11, Theory -Nov '11, Mod 1 -Jan '12, Mod 2 Feb '12
Taught2BCauti...
PostPosted: 23:00 - 06 Mar 2012    Post subject: Reply with quote
Not impossible, but could be dangerous as it might be possible to accidentally knock the bike off the side-stand whilst working at the rear..
Ideally, you need to rotate the back wheel a few times whilst making adjustments, to make sure you have no tight spots in the chain, and that the alignment is good.
It's a lot easier with the bike upright, with the rear wheel off the ground - but if available for your model, a permanently fitted centre stand might be an alternative for a paddock stand.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Frost
PostPosted: 23:02 - 06 Mar 2012    Post subject: Reply with quote
I've done it a bunch of times. If the bike leans loads on the side stand you can always stand it up against a wall, or get someone to hold it upright for you.
Cheerfulgrin
PostPosted: 23:09 - 06 Mar 2012    Post subject: Reply with quote
i took the plunge and did it, using the marks on the swingarm to make sure its straight and only turning each adjuster a 1/4 turn each alternately.... to be on the safe side.
not easy lubing the chain either, may have to invest in a paddock stand in the long run.
thanks for the advice Smile
PostPosted: 23:26 - 06 Mar 2012    Post subject: Reply with quote
Generally advisable to ignore the marks on the swinging arm.
Once the wheel is inline (whether done with a piece of string, a couple of straight edges or some flash laser tool), if you turn each adjuster the same number of flats it will stay in line.
Cheerfulgrin
PostPosted: 00:02 - 07 Mar 2012    Post subject: Reply with quote
I'd heard the marks werent the most reliable measure, i'll have to check with the string when i can find someone to hold the bike up straight.
thanks
Taught2BCauti...
PostPosted: 00:18 - 07 Mar 2012    Post subject: Reply with quote
Have you considered the Loobman Chain Oiler?
Less than £20 and easy to fit.
Walloper
PostPosted: 10:27 - 07 Mar 2012    Post subject: Reply with quote
thanks
Awe..... Billy no pals..... Crying or Very sad Crying or Very sad Crying or Very sad
If you can get axle stands (at lowest setting) under the rider's foot pegs it can work.
But look at a rear paddock stand (as an investment). You need to lube the chain every month anyway. And they are indispensable for washing the machine (or 'detailing' if you're gay)
Ebay £30 or there-aboots.
https://www.passionauto.co.uk/products/biketek-motorbike-rear-wheel-red-paddock-stand.html
I even did the google-ing fer ye.
R1AL
PostPosted: 23:10 - 08 Mar 2012    Post subject: Reply with quote
Pop round mine for a brew Rob and you can use my paddock stand if you like Wink
Al
Walloper
PostPosted: 23:28 - 08 Mar 2012    Post subject: Reply with quote
Al
I'd keep an eye on him whilst you service your chain.
He could be lubing something up too...
Shifty
Sako
PostPosted: 00:21 - 09 Mar 2012    Post subject: Reply with quote
always found any auto chain lube device a bad idea - it causes people to just let crud and crap build up on their chains in the belief that the auto lubing is keeping everything good.
i've always found it important to have a good clean and examination of your chain every few rides to spot any issues.
Cheerfulgrin
PostPosted: 00:54 - 09 Mar 2012    Post subject: Reply with quote
Walloper wrote:
Al
Shifty
Ha ha ha Laughing
Cheers Al,
Should defo come over sometime, hope your on the road again soon too.
Won't be Saturday though off to criccieth for fishing, not on the bike! Lol
R1AL
PostPosted: 01:06 - 09 Mar 2012    Post subject: Reply with quote
Hope you catch something...me and my Dad are going to either Llyn y gors or Vicks in the next few weeks. Lets hope the carp are starting to wake up!
Al
Alpha-9
PostPosted: 11:07 - 09 Mar 2012    Post subject: Reply with quote
Really?
I just put mine on the centre stand in first so the back wheel starts spinning slowly and drip the lube on the chain
Right?
Fzr-600 1999
Walloper
PostPosted: 12:02 - 09 Mar 2012    Post subject: Reply with quote
Not necessarily so.
I have two bikes with Scottoilers fitted and I check the chain/s regularly.Every ride (as I do with the tyres). It's always clean and always lubricated.
The idea of having an oiler is to keep it clean and lubed.
There is no system that is fit and forget. It's the reliability of the system that encourages some to forget though. Very Happy
Walloper
PostPosted: 12:33 - 09 Mar 2012    Post subject: Reply with quote
Alpha-9 wrote:
Really?
Right?
Shake hands with danger.
How many folk lose fingers/bikes/sheds in this manner.
Paddock stands are much cheaper than unnecessary hassle.
bazza
PostPosted: 00:32 - 10 Mar 2012    Post subject: Reply with quote
If you don't have a centre stand, sure.
The last post was made 12 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 17 - Page Size: 102.94 Kb
