EmacD L Plate Warrior
Casper World Chat Champion
Posted: 12:16 - 26 May 2012 Post subject: |
It also looks the same as the GPz ones. I would say as long as your not going to use a smaller one you should be fine. Try and get the part number from this site
https://www.cmsnl.com/
And look at the part number for the 750 and the gpz550/750 or the zephyr 550/750. You can look at the ZR7 but that may be slightly larger. |
Posted: 12:18 - 26 May 2012 Post subject: |
Just had a look at your location. You must be close to Braking point in Aberdeen. Im sure they will sort you out cheap.
https://www.breakingpoint.co.uk/ |
Posted: 15:10 - 26 May 2012 Post subject: |
Thanks for the reply. My experience with breaking point has not been good. I have had them do work on my bike in the past, and it has been less than sterling service! So out of principle I will not had any more money to them!
I have looked at the GPZ and the fitting looks similar, but on the GT750 it looks like the mounting holes are slightly different. the ZR7 would be a good one as well, but requires a bit of customisation to mount.
I have a cooler (in really good condition) from a Honda CB750 in good condition, but it uses Flange mounts rather than JIC type ! ____________________ Thanks |
Posted: 15:23 - 26 May 2012 Post subject: |
The GPZ and the GT have the same part number on the Dutch site, so that opens up my possibilities! (i.e. 39061) ____________________ Thanks |
