| NinjaMonkey |
 NinjaMonkey L Plate Warrior
| Hetzer |
 Hetzer Super Spammer
| NinjaMonkey |
| mudcow007 |
 mudcow007 World Chat Champion
| Turkish |
 Turkish Crazy Courier
| Efes123 |
 Efes123 World Chat Champion
 Posted: 17:53 - 17 May 2013 Post subject: |
As above, it will be like riding with the clutch pulled part way in, permanently slipping. Just adjust it back a bit and see if it runs OK. Then buy yourself a new cable as it sounds like that one has stretched to its limit. ____________________ Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD |
| NinjaMonkey |
| Pete. |
 Pete. Super Spammer
 Posted: 15:02 - 03 Jun 2013 Post subject: |
Money well-spent for you I think. Clutch packs aren't cheap and a too-tight chain can snap and take out your rnginr cases, or knacker the output shaft bearing. ____________________ a.k.a 'Geri'
| smithyithy |
 smithyithy Spanner Monkey
 Posted: 15:30 - 03 Jun 2013 Post subject: |
Can I hijack? I have a very similar problem to the OP's clutch.. Bike is a 1990 CBR400RR.
I had a lot of play / slack in my lever, the clutch engaged fine but with the lever being so loose it wsn't nice to use.
Over the past week or so the clutch has started to slip; when I'm in the mid rev range and accelerate with any amount of gusto, the revs increase more than the engine speed, as if the clutch is half-in.
Riding very gently can avoid this, but it was becoming a problem, so via Haynes manual I adjusted the cable same as the OP did. At the lever and on the engine casing, so the cable and lever now feel fine, next to no play etc. However the clutch doesn't engage any more! I can put it in first, let the clutch out all the way with no throttle and it won't stall, I can only very slightly feel a pull.
My thought initially were to replace the cable. But due to the previous slippage, could there be a bigger issue?
Cheers. |
| Pete. |
 Pete. Super Spammer
 Posted: 16:45 - 03 Jun 2013 Post subject: |
Since your clutch has no clearance adjuster the only thing I can suggest is clean the cable. Disconnect it both ends then take hold of one end and push it in and out. It should be completely free-moving with very little drag. If it's sticky or gummy or downright tight - this can cause the clutch to slip. Flush it out with some degreaser until it moves freely or just buy a new one. ____________________ a.k.a 'Geri'
The last post was made 13 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
