Author |
0l0dom0l0 |
0l0dom0l0 World Chat Champion
Posted: 00:49 - 03 Jun 2013 Post subject: Bought a TL1000R Project. Going to be fun this! |
A good friend of mine 'inherited' this bike from his brother in law after it developed a fault with the fuel system which was never diagnosed. 3 years has passed since it was last on the road and I offered to take it off his hands to keep myself busy over the 4 months off uni I have over the summer. If it's a runner and it all sounds good I'm going to hopefully fully rebuild it and restore it to it's former glory and have it as my 'hoon' bike, if it doesn't this thread is going to be rather short and it will probably end up getting broken for spares, but we don't want that to happen so I'm going to do my best!
This is no ordinary TL though. It's an R that's been street-fightered with a custom twin under seat exhaust and some other bits. Looks sick if you ask me!
First things first and that was to get it the 3 hours home. All loaded in the van and ready to go:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_1317282.jpg
Unloaded the other end. Can see more what we're dealing with here. Looking a bit sorry for itself too where it's been stood so long:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_181304.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_181316.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_181327.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_181342.jpg
Engine casing looks pretty bad:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_181352.jpg
Chain and sprockets are fucked lol:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_181404.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_181422.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_181436.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_181442.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_181446.jpg
Quick clean, because cleaning stuff makes bikes easier to work on ...... Not come up to bad actually, most of the corrosion is just on the surface and wipes off which is good. Some of the bolts and fittings are gone though:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_211328.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_211331.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_211347.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_211351.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_211355.jpg
So the next job was to start stripping stuff off and trying to get the bike running. There was a problem with the choke cable getting stuck and not returning so I firstly decided to tackle that and get to the mechanism to free it all off. Tank off:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_213943.jpg
Bit shitty under here:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_213947.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_213954.jpg
Then I took the airbox off to see what was going on underneath that and was greeted with this mess:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_215301.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_215309.jpg
Bikes certainly seen better days, but if it runs I'm going to strip all this off and probably get it re-coated.
Managed to free the choke off nicely and lubes all the throttle mechanism up as well so that's working nicely! Next job was to get the plugs out and drop some oil down the bores as it hasn't been run in so long. Came out with minimal effort, the rear was easy to get to, the front not to much, but I just undid all the radiator bolts and moved the rads out the way. In the process I noticed it's got no coolant in, which isn't ideal, but I'll get some tomorrow and I was going to replace it anyway, just means the block as been left exposed for a while.
So old plug out:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_220522.jpg
Next way to change the suspected faulty relay. Weather its fucked or not I don't know, but the state of the connector didn't fill me with confidence:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130602_223752.jpg
Cleaned that up and put the new relay on.
The decided to drain the oil and change the oil filter. Oil filter was stuck on like a bitch, I bent my tool trying to get it off but it wasn't budging. Then resorted to the old fashioned way of doing it and hammered a screw driver through which, with some persuasion managed to free it off. Didn't get any photo's as I was covered in oil, but I'll add some tomorrow.
Tomorrows plan is to put the new filter on, fill with oil and coolant and then attach the new tank as the old tank is pretty rusty, so I bought a new one with the hope that it will be better. Then attach everything back together, hope that the battery holds it's charge and turn everything on.
I'll know straight away if it's working as the pump will prime up, but I'll also check to see if it's still throwing the fuel circuit fault code on the dash. If the codes gone, it's hit the started and see if she runs!
That's all for now, but I'll update tomorrow with the new progress. It should be running by the end of tomorrow I hope!
Hope you like so far ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Back to top |
garth |
garth World Chat Champion
Back to top |
0l0dom0l0 |
Back to top |
Eddie Hitler |
Eddie Hitler World Chat Champion
Posted: 09:20 - 03 Jun 2013 Post subject: |
Looks like you will be alright with that , good idea with the tank, that was my first thought looking at the rusty filler cap . £250 for a big v-twin, bargain! |
Back to top |
CarlosCBR |
CarlosCBR World Chat Champion
Back to top |
Supermoto_Fan |
Supermoto_Fan World Chat Champion
Back to top |
evoboy |
evoboy World Chat Champion
Posted: 10:38 - 03 Jun 2013 Post subject: |
Lol at the first time you open the taps with that bar setup
Please record it.
A friend of mine put Renthal UltraLows on his TLS with the lowest risers he could fit. It was evil for wheelies.
Looks alright for £250, id just ride it, then flog it on. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
Back to top |
UnspeedySam |
UnspeedySam World Chat Champion
Back to top |
Furrybiker |
Furrybiker Trackday Trickster
Back to top |
stoke-gaz |
stoke-gaz Renault 5 Driver
Back to top |
0l0dom0l0 |
Posted: 20:46 - 03 Jun 2013 Post subject: |
Just going to leave this here .
https://www.youtube.com/watch?v=ArB3J5W5DVw&feature=youtube_gdata_player
Will update more later! ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
Back to top |
Aff |
Aff World Chat Champion
Posted: 20:53 - 03 Jun 2013 Post subject: |
Back to top |
0l0dom0l0 |
Back to top |
Aff |
Posted: 21:55 - 03 Jun 2013 Post subject: |
Back to top |
0l0dom0l0 |
Posted: 23:44 - 03 Jun 2013 Post subject: |
So, if you haven't watched the video, do! It's a runner. Has 11k on the clocks for anyone that's interested.
First thing I did this morning was put the new oil filter on and fill the bike with oil. Luckily I had just enough to fill the bike which was good.
Out with the old:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130603_091112.jpg
After checking the batteryI pulled out of it which I left on charge over night, it was showing 6.5V ie fucked, so I took a trip to halfords to buy a new battery and some de-ionised water to act as coolant for now.
The old tank was pretty rusty and has certainly seen better days, I managed to pick up a half decent tank on ebay for £45 posted which you can't complain at. It's got a couple of small dents but nothing that a bit of filler wont sort and a re-spray. So I unpacked this out the box:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130603_094048.jpg
The fuel pump works if you connect it directly to a battery, so I was hopeful that it was working nice. I ordered a new gasket set as these are prone to failure and so using the bolts out of it attached the pump to the new tank. I didn't use the new gasket though as the fuel pump will be coming out again and there wasn't really any point. It did leak but it was nothing to worry about just to see if the bike would run. Pump all hooked back up:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130603_095803.jpg
Then I wanted to flush the coolant out. It was evident when I checked it was low. Where it's gone I have no idea but never mind, so I took of the drain bolt and made it go for a wee wee:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/20130603_095753.jpg
After filling it with the de-ionised water I connected up the new battery. The next challenge was trying to turn the bloody thing on, as there are 3 keys with it. 1 for the ignition, one for the tank and one for the seat unit, so it was a bit of a lottery . Especially with the fact the barrel was seized up . With some oil down the barrel and a bit of wigging I managed to turn the ignition on.
So turned the ignition on and the thing threw me the same error code as before. Hmmmm problem here me thinks. I'd left the fuel pipe disconnected to see if the pump was actually going to work, so I had a little brain wave and wondered if that was something to do with it. Connected that up which was a pain in the ass and turned the bike on with the kill switch off. Seems that by turning the kill switch off it resets everything and didn't chuck me any error codes so I flicked the kill switch and sure enough the fuel pump starts whurrring away!
Gave it a bit of choke (old fashioned this thing) and cranked it over. Nothing really happened so I turned it off and on a few times to get the pump to keep priming and increase the pressure in the fuel rail. Eventually there was a fart and with a combination of choke and throttle it fired up and started running. Left it to tick over on choke at about 1750 rpm to get a bit of oil pressure and topped up the coolant.
Ran it for a few mins then I took the video above! Runs lovely .
So the plan now is to start stripping it down and replacing all the stuff that's fucked. I'll probably clean up all the metal and might get it zinc'd if it's not silly money.
Will keep the progress updates coming! ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Back to top |
Fazer Tom |
Fazer Tom Spanner Monkey
Back to top |
0l0dom0l0 |
Posted: 00:03 - 04 Jun 2013 Post subject: |
Superfour Tom wrote: | Great stuff. I love these bikes, Not sure though, is this the one that's supposed to have the full fairing? |
Yeah, it's been streetfightered obviously. It needs a few modifications to finish the look off which I will do, like moving the battery box and sorting the wiring out and then it won't look so out of place. I'm not sure on the headlights yet either. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Back to top |
Fisty |
Fisty Super Spammer
Back to top |
0l0dom0l0 |
Posted: 09:16 - 04 Jun 2013 Post subject: |
Fisty wrote: | It's not a choke, just a fast Idle!!
Haynes do a manual for the TL, its actually quite helpful. I have a full rear tail unit and hump that would match that tank...... |
I'm not a big fan of the yellow, I don't think it looks right. Going to spray it matt black I think, what you reckon? ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Back to top |
mysterious_rider |
mysterious_rider World Chat Champion
Back to top |
Wafer_Thin_Ham |
Wafer_Thin_Ham Super Spammer
Posted: 15:46 - 04 Jun 2013 Post subject: |
Typical street fighter, exhaust is hideous, as is the purple anodised steering damper, headlights are making me sad just looking at it.
Apart from that, good darts.
What's your plan for it? ____________________ My Flickr |
Back to top |
Dreadnought |
Dreadnought L Plate Warrior
Posted: 17:27 - 04 Jun 2013 Post subject: |
The steering damper is purple 'cause it's an older Hyperpro, purple is kinda their thing, if it was an Öhlins no one would moan about it being gold.
The headlights are butt ugly though, but the exhausts aren't too bad IMO. ____________________ Past Bikes - Ducati Diavel Carbon, Suzuki GSX750f, Yamaha Thundercat, Suzuki TL1000r
Current Bikes - Kawazaki ZZR1400, Suzuki GSF1200, Honda VF1000f |
Back to top |
P. |
P. Red Rocket
Posted: 17:29 - 04 Jun 2013 Post subject: |
Gold and black goes
I have a blue damper, gonna remove it when I get a chance, does shit all for me |
Back to top |
Dreadnought |
Posted: 18:41 - 04 Jun 2013 Post subject: |
This is true, purple is a bizarre colour choice for a performance parts manufacturer. ____________________ Past Bikes - Ducati Diavel Carbon, Suzuki GSX750f, Yamaha Thundercat, Suzuki TL1000r
Back to top |
Fisty |
Fisty Super Spammer
Back to top |
The last post was made 11 years, 5 days ago. Instead of replying here, would creating a new thread be more useful? |
