I have a CG...
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5  Next
lilredmachine
PostPosted: 22:10 - 30 Sep 2013    Post subject: Reply with quote
I've always loved small, light bikes. That or massive bikes with huge engines. I don't really do in between. The idea of building something simple, light and aesthetically pleasing makes me go all warm and fuzzy. Building something yourself also means that if you don't like it, you can chop/modify/fix it to look the way you want, rather than wishing the designer of your shiny new bike had the power of telepathy and had known what you wanted.
Anyway, enough waffle. More chopping, cleaning up the base of the frame:
https://img716.imageshack.us/img716/6508/675w.jpg
Messy, lots of stuff we don't need here. Mr. Angle grinder and his mate Mr. 'fuckloads of filing by hand' combine to fix it.
https://img5.imageshack.us/img5/8739/dmnk.jpg
https://img818.imageshack.us/img818/5425/t6rv.jpg
Much better.
Have some poly wheels on the way for the grinder so I can take the frame and tank back to bare metal easily.
Done a bit more on the swingarm too, mainly filing and smoothing. Going to hit the frame with gloss black engine enamel so got to get everything smooth as possible.
lilredmachine
PostPosted: 04:52 - 01 Oct 2013    Post subject: Reply with quote
So, I just woke up at like 2, and can't get back to sleep. Wandering around, I caught sight of my rims and thought 'those spokes are shitty looking' So drastic measures ensued.
https://img812.imageshack.us/img812/8610/56kr.jpg
https://img823.imageshack.us/img823/6710/z2h8.jpg
https://img28.imageshack.us/img28/2108/r0sd.jpg
https://img822.imageshack.us/img822/882/ifhq.jpg
https://img11.imageshack.us/img11/3488/snqa.jpg
I plastidipped a set of spoke rims. It may be a first. I realised that I wasn't going to be able to match the finish on the brake plate with paint... So I plastidipped that too (still slightly wet in the pic). Quite happy with how it all came out. And if I don't like it, I can peel it right off.
lilredmachine
PostPosted: 21:09 - 01 Oct 2013    Post subject: Reply with quote
So why plastidip? Well plastidip peels off as a sheet when thick enough, when applied to spoked rims what you get is a weakspot at the bottom of the spoke where the spoke meets the rim. If you tug the plastidip strongly, it'll tear off leaving the spoke untouched and still covered in plastidip.
Do it on CG rims and what you get is:
https://img826.imageshack.us/img826/700/cnul.jpg
Black hubs, spokes and chrome rims. Boss.
Entertwainer
PostPosted: 08:59 - 02 Oct 2013    Post subject: Reply with quote
how durable is the plastidip? i have a spare rear i wouldnt mind trying this out on.......
also, did you need to prep the hub surface before applying the plastidip?
Honda CG 125 W - Turkish - 1998 - 2015 RIP
lilredmachine
PostPosted: 11:04 - 02 Oct 2013    Post subject: Reply with quote
Plastidip is very durable, resistant to impacts, sound, heat, shock and damp proof. Only prep you need to do is wire wool or sand the surface smooth if you have bubbles of corrosion on the surface as they will still show through the rubber layer. No need for primer, but it can be sprayed over primer. Only thing I found is spraying directly on to chrome, it can be difficult to get the plastidip to stick as it's a shiny smooth surface. I reckon a layer of clear plastic primer would get it to stick though.
Best thing is, if you balls it up, you can just peel it off in a sheet in a second and retry.
Oh, forgot to say, when you mask holes/mating surfaces or anything else off, remove the mask BEFORE the plastidip dries or prepare to get very handy with a scalpel. Removing masking tape will pull the plastidip layer off the rim.
CG Sam
PostPosted: 19:00 - 02 Oct 2013    Post subject: Reply with quote
Those wheels look awesome like that, what exactly is Plastidip?
CG125, SV650S, CBR600F, GSXR600 SRAD
lilredmachine
PostPosted: 19:21 - 02 Oct 2013    Post subject: Reply with quote
It's a sprayable rubber coating that applies like paint and can be built up in layers but when dry forms one mass. There are many colours that can be built up on top of each other and you can get glossifier to make it look like gloss paint, pearlizer to make it look pearlescent...
Rims being plastidipped:
https://www.youtube.com/watch?v=yR14nrlJxZc
Rims having plastidip removed:
https://www.youtube.com/watch?v=vHbXu4R8Zls
It feels like soft touch rubber handled tools to touch.
CG Sam
PostPosted: 20:08 - 02 Oct 2013    Post subject: Reply with quote
I'll definitely give it a go, is that just the black plastidip or did you primer it before?
lilredmachine
PostPosted: 20:32 - 02 Oct 2013    Post subject: Reply with quote
straight black dip, no primer. Thumbs Up
CG Sam
PostPosted: 20:34 - 02 Oct 2013    Post subject: Reply with quote
Awesome thanks! Guessing the whole lot peels off if you use the gloss on top and don't like it? Sorry about all the questions, hadn't even heard of it till this thread!
lilredmachine
PostPosted: 22:49 - 02 Oct 2013    Post subject: Reply with quote
Yes, that's why you use the glossifier rather than a normal clear coat. Normal clearcoat will work, but it makes the dip come off in little pieces which is a pain in the ass. Still easier to remove than paint though.
lilredmachine
PostPosted: 23:17 - 10 Oct 2013    Post subject: Reply with quote
Righto, in progress pics:
Stripping. Painstaking fucking stripping.
https://img138.imageshack.us/img138/9794/k31s.jpg
https://img30.imageshack.us/img30/3127/9p9g.jpg
Bitz:
Rearsets from, er, something.
https://img819.imageshack.us/img819/2124/1cly.jpg
Big ass 'make it run like shit' filter.
https://img42.imageshack.us/img42/5336/l7zc.jpg
The carb is still filthy (though internally clean) but my mate is awaiting delivery of a sonic cleaner so I'm holding out on that.
Forks, tank, swingarm and torque rod have gone down to be vapour blasted to finish off the cleaning process before painting/polishing. Things should move a bit quicker now as the girlfriend was moaning about me spending too much time on it, so she had to go.
lilredmachine
PostPosted: 15:33 - 20 Oct 2013    Post subject: Reply with quote
Have some progress. The frame is now mostly stripped, rather than sort of stripped. Cut a few more unecessary brackets and wire holders off it, filed back smooth by hand. The top and bottom yolks were stripped right back, painted with alloy engine enamel and then baked in the oven to cure along with the brake levers and cable retainer. I have the front end mostly sorted now, am waiting purely on the forks, which are being polished as we speak, some shocks, and the swingarm, which is being vapour blasted to clean any gunk left over off before painting. Once I have this stuff in my posession I can bolt this back together a little bit and get an idea of how the tank and sea unit are going to sit, and also where to mount the rearsets.
https://img834.imageshack.us/img834/1269/wslx.jpg
https://img96.imageshack.us/img96/9872/h99q.jpg
https://img513.imageshack.us/img513/3311/s4jy.jpg
https://img191.imageshack.us/img191/48/0iep.jpg
https://img5.imageshack.us/img5/2182/leum.jpg
https://img407.imageshack.us/img407/2272/ozzr.jpg
https://img5.imageshack.us/img5/1501/spom.jpg
https://img7.imageshack.us/img7/9102/0k5e.jpg
And this is Scamp, my mate's dog. A full size Jack russell from a normal litter, but suffers from dwarfism. Full size head, tiny body. Many rainbows spewing from mouths when he gets him out the car.
https://img39.imageshack.us/img39/8106/fnpa.jpg
https://img29.imageshack.us/img29/438/2b71.jpg
garth
PostPosted: 08:43 - 21 Oct 2013    Post subject: Reply with quote
How long are the shocks you need? I have some very tarty widely coiled chrome units that I believe are 330 or 340mm long. They're these ones...
https://oi43.tinypic.com/2qcgnqs.jpg
Used for under 500 miles.
lilredmachine
PostPosted: 18:54 - 21 Oct 2013    Post subject: Reply with quote
Hmm, think the standard shocks are 330mm and have a top/bottom mount of 12mm. How much would you want, they do look very nice.
https://img545.imageshack.us/img545/8711/a5hb.jpg
Tank stripped. Bit of a clean up and laquer as is I reckon. Looks so, so sweet.
ocatoro
PostPosted: 02:11 - 22 Oct 2013    Post subject: Reply with quote
awesome, can't wait to see this finished Smile
we're moving shortly, and hopefully i'll get a garage/man-hole, or we're not moving! i have an '86 h100sg sitting around idle. i'm going to strip it all down and coat frame etc and build it back up minty fresh just for the enjoyment.
CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None Sad but shed project H100 (first bike Smile )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600
garth
PostPosted: 09:17 - 22 Oct 2013    Post subject: Reply with quote
Dunno, £30? They're too hard for a cub but that only weighs 75kgs or something, look pretty though.
lilredmachine
PostPosted: 20:35 - 22 Oct 2013    Post subject: Reply with quote
Sounds good Garth, I'm kind of hoping the CG won't weigh much more than 85kg when it's done but we'll see. I wet and dried the tank tonight to remove some nasty marks it had, it now looks good, a few little dents and just enough 'patina' to look right but not so crabby it looks shit. These pics are pre polish though, looks a bit shinier now. I'm knee indenting the tank, then laquering it as is.
https://img27.imageshack.us/img27/554/77yt.jpg
https://img51.imageshack.us/img51/9058/6oep.jpg
https://img405.imageshack.us/img405/4932/72h5.jpg
https://img405.imageshack.us/img405/231/daav.jpg
https://img36.imageshack.us/img36/5194/whsm.jpg
https://img841.imageshack.us/img841/3472/igwv.jpg
Entertwainer
PostPosted: 00:09 - 23 Oct 2013    Post subject: Reply with quote
looking like a cracking build thread Smile
any chance of some closer pics of the wheels/spokes with that plasti dip on them? seriously considering it for my own...
lilredmachine
PostPosted: 22:31 - 23 Oct 2013    Post subject: Reply with quote
Cheers. I'll get some in the daylight so you can see without weird lighting.
Robby
Dirty Old Man
PostPosted: 09:12 - 24 Oct 2013    Post subject: Reply with quote
I'm not sure what end result you're after with the fuel tank, I read that bit of the thread days ago. If you want some patina, don't lacquer it, just give it a wipe with an oily rag from time to time.
Also worth hammeriting the underside, road crap get flung up and rusts it.
lilredmachine
PostPosted: 09:17 - 24 Oct 2013    Post subject: Reply with quote
I left the underside painted still, but I probably will underseal it.
https://img823.imageshack.us/img823/401/8v92.jpg
https://img96.imageshack.us/img96/6856/ks3l.jpg
https://img849.imageshack.us/img849/1852/hlmk.jpg
https://img191.imageshack.us/img191/5616/71zf.jpg
They are reasonably good close up, without relacing the rims or spraying them totally, it's a good compromise. They are covered in in paint specks from where I was stripping in my room lol.
mudcow007
PostPosted: 12:21 - 24 Oct 2013    Post subject: Reply with quote
i plasti dipped the side panels an tank on my CG, just for the lolz
i found it rubbed off the tank (by the seat) quite easy
might be ok on the wheels though
colour was really good, an even me got a decent finish with a rattle can
lilredmachine
PostPosted: 21:44 - 08 Nov 2013    Post subject: Reply with quote
https://img853.imageshack.us/img853/1820/5h80.jpg
Summat like that I guess. Still haven't got round to picking up the forks.
KymcoRatChop
PostPosted: 04:53 - 09 Nov 2013    Post subject: Reply with quote
this looks awesome-I'll be watching this...
I might be stealing your plasti-dip idea for my rims;
https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-prn2/1385174_508519225910440_317204500_n.jpg
Took me 13 hours to strip and clean these rims -they've been sat in crud and crap for the past 3 years and not cleaned once lol. I got the rims done to a high standard then couldn't be bothered to do the spokes (all done by hand ya see)
Thumbs Up for a great build thread!
The last post was made 10 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.88 - MySQL Queries: 17 - Page Size: 140.96 Kb
