derbi senda not idling
charrington96
PostPosted: 22:08 - 17 Nov 2013    Post subject: derbi senda not idling Reply with quote
I have a derbi sends 50cc 2 stroke 02 plate... Today I have removed the air filter and replaced it with the original air box cause it was causing problems...
When I put it on I started my bike, but it won't idle, I can put revs into it and it won't cut out, but if I leave it it slowly starts to cut out
Any ideas?
nathan k
PostPosted: 22:22 - 17 Nov 2013    Post subject: Reply with quote
Idle screw..my guess is the airfilter caused it to run lean, so the previous owner turned the idle down.
charrington96
PostPosted: 22:40 - 17 Nov 2013    Post subject: Reply with quote
Where's the idle screw, and how much shall I turn it, I dont like fiddling with things on bikes
nathan k
PostPosted: 00:14 - 18 Nov 2013    Post subject: Reply with quote
It's normally the middle screw on the carb. There's a screw you'll need a screwdriver to adjust, don't touch that. I'd google the model of your carb for a breakdown.
charrington96
PostPosted: 08:34 - 18 Nov 2013    Post subject: Reply with quote
Alright thanks Smile
temeluchus
PostPosted: 09:27 - 18 Nov 2013    Post subject: Reply with quote
https://i.ebayimg.com/00/s/NDc3WDM5Ng==/z/ZBcAAOxyYYlRpPGQ/$%28KGrHqF,!lcFGZDy9EDtBRpPGO0hgw~~60_35.JPG?set_id=8800005007
The big silver screw that sticks out quite a ways (look at the right side of the image above).
Turn it in (clockwise) half a turn at a time and try and start the bike. If you end up screwing it in a lot and the bike still refuses to idle you have a problem elsewhere.
charrington96
PostPosted: 10:50 - 18 Nov 2013    Post subject: Reply with quote
Thanks... As I turn the screw it gets better but still cuts off and about 30 seconds... Would that be the jet needle inside? I'll get bike shop to do it if it is
charrington96
PostPosted: 12:07 - 18 Nov 2013    Post subject: Reply with quote
Got it working, adjusted the idle screw and it was just too cold and where the carb was being moved about... Cheers
The last post was made 10 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 17 - Page Size: 56.03 Kb
