Author |
Pete. |
Posted: 09:01 - 19 Apr 2014 Post subject: How wrong can it go - copy over system files? |
I have a laptop here belonging to a family member. It's an Acer 5250 that had a humongous wad of fluff built up in between the fan and heatsink causing it to over-heat and lock up under load which has resulted in many corrupt system files. I stripped it down and cleaned out the obstruction so now it runs ok except the damage to the file system is such that it still freezes for long periods doing certain things (when opening web browsers, windows explorer etc).
It's got a half-terabyte drive which is half full of vids, music, uni work, plus the operating system. Thankfully, I've managed to create the four re-install DVD's and verified the hardware is working fine by swapping the HDD for a 120GB one that has taken a fresh install successfully.
I don't have anything big enough to back up the 200GB or more of user files on the 500GB drive to perform the same feat so what I want to do is copy the system files form the fresh install across to the old windows folder on the drive installed in a caddy. Which files can I hope to successfully port over to the old installation without royally screwing the installation up?
In short - two hdd's, both built from the same recovery partition, one in 2011 the other today. Can I copy over folders like sytem32 to repair broken files? ____________________ a.k.a 'Geri'
Back to top |
The Artist |
The Artist Super Spammer
Back to top |
Pete. |
Posted: 09:49 - 19 Apr 2014 Post subject: |
I haven't got anything to copy off 200GB onto, that's the problem.
The machine itself is fine. It's currently running half a gig of updates on the spare 120GB drive and hasn't missed a beat. Once the updates are done I'll run a stress test to make sure it doesn't fall over under load but ATM it's good. ____________________ a.k.a 'Geri'
Back to top |
treeno |
treeno Crazy Courier
Back to top |
Pete. |
Posted: 12:17 - 19 Apr 2014 Post subject: |
I ran a chkdisk on the original drive which found a few dozen orphaned files but no bad sectors. I also ran msert coz it's a handy standalone checker which reported no suspicious files. This is when I decided to fit a new drive and run an install, which promptly fell over when starting services which is what caused me to strip the thing down and found that wad of fluff jammed in the fan outlet.
The new install is still running updates ATM - 138 of 'em ____________________ a.k.a 'Geri'
Back to top |
CaNsA |
CaNsA Super Spammer
Back to top |
StormCrow |
StormCrow Scooby Slapper
Posted: 17:12 - 19 Apr 2014 Post subject: |
Minor correction - you need to run 'SFC /scannow'
That will compare all Windows installation files to the files on the drive and replace any that it find that are damaged. Well worth a try before you have to go reinstalling Windows - works probably 7/10 times... |
Back to top |
Pete. |
Posted: 17:14 - 19 Apr 2014 Post subject: |
I'm running it now, currently at 32%. If it works I'll be astounded and grateful in equal measure
EDIT: "Windows Resource Protection could not perform the requested operation"
Running it again with /verifyonly switch
2nd EDIT: got to 32% verifying, crashed and re-started
SFC just copies DLL's from the dllcache folder into system32 right? I'm going to hang this driv off another pc and copy them all over manually. ____________________ a.k.a 'Geri'
Back to top |
Pete. |
Posted: 18:19 - 19 Apr 2014 Post subject: |
Currently have the affected drive hanging off the fresh install in a caddy, running SFC is offline mode with the following command:
sfc /verifyonly /offbootdir=g:\ /offwindir=g:\windows
Using verifyonly first after reading some scare story about someone making their drive un-bootable. ____________________ a.k.a 'Geri'
Back to top |
P. |
P. Red Rocket
Posted: 18:47 - 19 Apr 2014 Post subject: |
If you need a sizeable drive for temp, I have a 500GB sitting here doing nothing, USB one. Can drop round if needed |
Back to top |
Pete. |
Posted: 18:52 - 19 Apr 2014 Post subject: |
Back to top |
Rogerborg |
Rogerborg nimbA
Posted: 19:08 - 19 Apr 2014 Post subject: |
Dat. I've had it with trying to fix OSen in place. If I'm doing volunteer tech support now, I won't touch it until they invest in a backup drive. ____________________ Biking is 1/20th as dangerous as horse riding.
Back to top |
SQL |
SQL World Chat Champion
Posted: 00:33 - 20 Apr 2014 Post subject: |
Was gonna say if you have access to the internets I can give you 1Tb quota to use on my NAS but Paddys with probably be quicker |
Back to top |
Pete. |
Posted: 18:26 - 20 Apr 2014 Post subject: |
Cheers mate but Paddy came through with the loan of a backup portable drive - cheers Paddy!
I got most of the data backed up with many odd stop-starts whilst copying files. It would copy anything from one file to a couple of Gb then just stop on a particular file - or copy it very very slowly. I would have to cancel the copy then un-plug the usb lead for the suspect drive and go from the next file on. Bit of a tedious process but I got most of the data off it until the old drive eventually turned up it's toes. Dunno what killed it - heat from the CPU perhaps or maybe just one of those things.
So the laptop is now running perfectly with a fresh install of Win7 on a 120GB drive I borrowed out of another machine. I just bought another 500GB drive which will be fitted in a few weeks when the guy comes back from Uni.
Cheers for the help! ____________________ a.k.a 'Geri'
Back to top |
P. |
P. Red Rocket
Back to top |
The last post was made 10 years, 8 days ago. Instead of replying here, would creating a new thread be more useful? |
