Grotty Hornet
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
MarkJ
PostPosted: 19:31 - 05 Feb 2013    Post subject: Reply with quote
It's been a while since the last update but I have been busy, even though the progress doesn't look much - it's been fiddly jobs.
I changed the head bearings. If anyone comes to change Hornet head bearings, the bottom race sits on a rounded lip which doesn't give enough space to manoeuvre a normal drift past:
https://i47.photobucket.com/albums/f186/markjackson13/DSC00918_s.jpg
So I had to file a notch out of my drift like so
https://i47.photobucket.com/albums/f186/markjackson13/DSC00922_s.jpg
Fitted the taper roller bearing on the bottom race, also sanded off the powder coat from inside the yokes with a dremel:
https://i47.photobucket.com/albums/f186/markjackson13/DSC00925_s.jpg
I fitted some worn out Pilot Road 2 tyres to my wheels so I can have a rolling chassis. These will be replaced when the bike is complete:
https://i47.photobucket.com/albums/f186/markjackson13/DSC00924_s.jpg
Put the forks back together with new bushes, seals and 15wt oil:
https://i47.photobucket.com/albums/f186/markjackson13/DSC00926_s.jpg
The rear shock is pretty grubby, but as with all Hornet shocks it has eventually turned into a bouncy castle suspension component. Supposedly getting them re-done is pretty difficult and the shock goes off eventually so I'm going to see if I can get my hands on a second hand Nitron/Hagon/Ohlins jobby. In the mean time I didn't want to look at the grubby shock, so being a tight arse I made myself a shock sock out of some neoprene sheet off ebay Very Happy
https://i47.photobucket.com/albums/f186/markjackson13/DSC00927_s.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSC00928_s.jpg
Turn it inside out, pop some holes in for the string and:
https://i47.photobucket.com/albums/f186/markjackson13/DSC00929_s.jpg
Finally I fitted it all together to get my rolling chassis Mr. Green
https://i47.photobucket.com/albums/f186/markjackson13/DSC00930_s.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSC00931_s.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSC00932_s.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSC00933_s.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSC00934_s.jpg
Next job will probably be to re-do the paint on the underside of the engine, blank off the PAIR inlets, check valve clearances then fit it in the frame.
TUG
PostPosted: 21:38 - 05 Feb 2013    Post subject: Reply with quote
Swing arm sticks out a bit don't ya reckon? Laughing
Amazing work though, can't fault you on anything else really, your determination is commendable.
Haz ER-5, innit!
salty21
PostPosted: 22:06 - 05 Feb 2013    Post subject: Reply with quote
quite liking the silver and black theme, starting to look like a bike again Thumbs Up .
you planning on getting the rusty bits plated/replaced or does that enter into Tim... territory Laughing
MarkJ
PostPosted: 23:26 - 05 Feb 2013    Post subject: Reply with quote
I know Sad I didn't want to powder coat the swingarm because the bearings were silly money, and I couldn't find the bearing numbers on the net anywhere to just get some from a bearing supplier so decided not to do the swingarm. It was only once I got all the bits back that I thought I'd perhaps gone overboard with the black Laughing
The pegs are still silver, as is the exhaust shield so there will be a bit more silver at the back. The clocks are plastic chrome too, so if I can get a silver headlight I can probably redress the balance Laughing
I definitely need to do something with them. There's a fastners place down the road from me so might end up just replacing them. I've wire wheel'd a few but they still look pants Laughing
MarkJ
PostPosted: 00:30 - 13 Feb 2013    Post subject: Reply with quote
Small update: re-painted the front of the engine.
These speckly bits were where it was lifting:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1885Copy.jpg
It was only like this on the underside of the engine - must have been crap that I hadn't cleaned off when I painted it the first time as everywhere else on the engine was fine. I used a tiny dremel wire wheel last time which wasn't much cop, used a big wire brush attachment for my drill this time:
https://www.alltradetools.com/catalog/644-668-large/410374-1-wire-brush-attachment.jpg
Before:
https://i47.photobucket.com/albums/f186/markjackson13/DSC00935_s.jpg
After:
https://i47.photobucket.com/albums/f186/markjackson13/DSC00936_s.jpg
MarkJ
PostPosted: 22:19 - 19 Feb 2013    Post subject: Reply with quote
Finished the PAIR blanking plates - I cut a chunk of aluminium out of my numberplate bracket to make the plates out of. Just mole grip'd the aluminium to an old bracket and ground it down with a cutting wheel till they were the same shape.
They just need cleaning up and deburring and they're finished.
https://i47.photobucket.com/albums/f186/markjackson13/DSC00939_s.jpg
Poorly focussed comparison:
https://i47.photobucket.com/albums/f186/markjackson13/DSC00938_s.jpg
salty21
PostPosted: 23:46 - 19 Feb 2013    Post subject: Reply with quote
regarding the swingarm bearings, this site is pretty usefull for finding bearing codes for hondas. I normally use hondapartshouse in the US but they dont show any hornets on their database.
they show codes/sizes for all swingarm bearings apart from the left side needle bearings. for those i would just measure the diameter of the spindle for the i.d and the bearing shell for the o.d and width
https://www.lingshondaparts.com/honda_motorcycle_parts_selection_pfk.php?block_01=13MBZ2I1&block_02=F__2200&block_03=1791
Mikey3
PostPosted: 12:50 - 20 Feb 2013    Post subject: Reply with quote
That's pretty awesome man. Like it!
I'm doing mine up but having no spare transport means that things such as engine paint and frame powdercoating makes mine a pain in the arse!
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
Shinigami
PostPosted: 14:02 - 20 Feb 2013    Post subject: Reply with quote
fancy cleaning mine up when you're done? Laughing
GrumpyGuts
PostPosted: 00:26 - 21 Feb 2013    Post subject: Reply with quote
...and mine, bitch.
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
MarkJ
PostPosted: 00:57 - 21 Feb 2013    Post subject: Reply with quote
Pfft, I've all on cleaning my own!
Thanks salty, I've used Lings before but never noticed the bearing dimensions, cheers.
Redoko
PostPosted: 13:38 - 08 Mar 2013    Post subject: Reply with quote
Anymore progress?
MarkJ
PostPosted: 19:05 - 08 Mar 2013    Post subject: Reply with quote
Yeah but not much, had a hectic few weeks so haven't had much time to do anything!
The valve clearances are all fine, but didn't think it warranted a new post. I'm off all next week so expect progress then, hoping to have the engine in by then Thumbs Up
suzukirider19...
PostPosted: 20:19 - 08 Mar 2013    Post subject: Reply with quote
looks sweet! as the theme is black/chrome/siver i would polish the lip on the wheels think it would realy tie everything in
husky sm610
R1AL
PostPosted: 22:43 - 10 Mar 2013    Post subject: Reply with quote
Excellent thread...you're doing a great job mate.
There is a gap of 1 year, 42 days between these two posts...
MarkJ
PostPosted: 22:40 - 22 Apr 2014    Post subject: Reply with quote
Me again.
Can't believe this has been going on for nearly three years now. I've changed jobs internally at work and potentially might be having to do some reasonable miles on a bike (might be commuting into Leeds centre) so could do with having this finished soon.
The rolling chassis in the last update didn't have the head bearings greased, and all the bolts were just nipped up, so I tightened them all up to the correct torque and greased the head bearings.
I then took the wheels and forks off, and lowered the frame onto the engine to fit it in. Ended up with this:
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC00999.jpg
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01000.jpg
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01001.jpg
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01002.jpg
The carbs were an absolute bastard to get back on. Eventually had to wrap a ratchet strap around the engine and carbs and tighten that. Then head the inlet rubbers with a hairdryer and they eventually popped in with me practically hanging off one end of the strap to make it tighter.
Going to leave the removable bits of the engine (water pump, CCT, starter etc.) unpainted as a contrast to the black, if it looks daft I'll take them off and repaint
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01003.jpg
I was going to paint the oil cooler, but the muck is really ground in and I can't be bothered to spend ages wire wheel-ing it only for the paint to come off anyway. It looks fairly dark now anyway:
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01004.jpg
That's going on in the next few days, I can't find the bolts for that so had to order some off the internet.
After that is the undertray and loom which I'm not looking forward to:
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01005.jpg
Then the overflow tank after it's been cleaned:
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01006.jpg
And that's where I'm up to. Hopefully the only awkward job after the loom will be the coolant pipework and routing all the cables again. I have some pictures of everything before I took it apart so hopefully that'll make the process easier.
Dean-J
PostPosted: 23:06 - 22 Apr 2014    Post subject: Reply with quote
wow, i remember reading this yonks ago, had completely forgotten about it until just now!!
Fair play to ya, the bike was in a hell of a state when you started, i have literally broken better bikes down for spares! Laughing
Looks a million times better now though man, really coming along, gonna look good when your finished!!
Current: 99 Yamaha Thuundercat
Previous: K7 GSXR 1000 K4 GSXR 600 roadbike, CBR 600 Steelie Track bike, 2005 SV1000Sz, 2004 FZ6 Streetfighter,2003 Yamaha Thundercat, 2002 SV650, 1989 Yamaha DT125R
TUG
PostPosted: 00:20 - 23 Apr 2014    Post subject: Reply with quote
This thread is epic and I hope my ER5 resembles the same condition when I'm done with it as it currently sits in the same condition as this started off as.
You've done an amazing job Mark!
Haz ER-5, innit!
Llama-Farmer
PostPosted: 02:21 - 23 Apr 2014    Post subject: Reply with quote
Nice transformation, be nice to see the finished product.
Peanut butter will improve the look of the old rubber pipes... rub it in with a cloth, a bit like a polishing paste. I'd go for black Samco ones to replace the 3-pc coolant hoses and just tart up the old ones for the rest of the hoses/breather pipes etc.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
MarkJ
PostPosted: 22:12 - 23 Apr 2014    Post subject: Reply with quote
Thanks for the compliments Thumbs Up
Not had much time tonight, so quickly put the loom in. Didn't have a chance to look at the photos for correct routing so some bits will probably need moving, but I wanted to get another thing on the bike.
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01007.jpg
.Bishbash.
PostPosted: 22:31 - 23 Apr 2014    Post subject: Reply with quote
Dude, that's looking GOOD!!
Current bike - GSX-R1000 k8
garth
PostPosted: 17:26 - 24 Apr 2014    Post subject: Reply with quote
Those sprocket bolts offend me.
MarkJ
PostPosted: 21:06 - 24 Apr 2014    Post subject: Reply with quote
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01009.jpg
Suck it, bitch Very Happy
Cleaning them can be my next job, ok flower? Razz
MarkJ
PostPosted: 21:59 - 26 Apr 2014    Post subject: Reply with quote
Not as much progress today as I'd have liked. The bolts I'd ordered for the oil cooler ended up being about 10mm too long as I'd measured the thread hole to be 19mm, however it was only threaded for about 10mm so had to spend a while chopping the bolts down.
Anyway, to appease garth the sprocket bolts were cleaned with a wire wheel and vinegar
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01013.jpg
Shiny bolts
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01014.jpg
Fitted the lock with the new bolts
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01017.jpg
And finally, the oil cooler fitted
https://i47.photobucket.com/albums/f186/markjackson13/hornet/DSC01018.jpg
The last post was made 10 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Page 5 of 7
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.34 - MySQL Queries: 16 - Page Size: 142.32 Kb
