Author |
gavcarter |
gavcarter Could Be A Chat Bot
Posted: 17:15 - 17 Jun 2014 Post subject: |
Id be tempted to bag all the brown stuff and post back to sender |
Back to top |
wots |
wots World Chat Champion
Back to top |
SQL |
SQL World Chat Champion
Posted: 17:39 - 17 Jun 2014 Post subject: |
Back to top |
dannymassive |
dannymassive Brolly Dolly
Back to top |
STONEY! |
STONEY! Brolly Dolly
Back to top |
wots |
Posted: 15:32 - 05 Jul 2014 Post subject: |
Sounds about right, have replaced the carbs and they seem as perfect as possible. Came from a running bike. Today replaced the CDI with an OEM one. It had suspected CDI failure previously, an aftermarket CDI has been fitted (brand new). It seems like an electrical breakdown now, as it runs beautifully at high revs if it gets there and is more usable than it ever has been before.
I'd had the pickup suggested previously, so I think that's where I'm going next. As there is actually very little left. Coils are brand new. It now starts easily and will rev up to 4K albeit with a little stutter. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
Back to top |
wots |
Back to top |
wots |
Posted: 17:24 - 13 Jul 2014 Post subject: |
It runs. Carbs need adjusting as they have been fiddled with many times. So sometimes bogs a little initially, but once above 2-3K it flies.
I think in all honesty it needed a cdi and a generator/pickup. I have replaced carbs (not needed, actually suspect the originals were fine) and the above two items.
Now just to sort the annoying sidelight problem, will wire to an ignition live for the MOT. I know it's not the switch as used another, I'll figure it out. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
wots |
Posted: 11:29 - 14 Jul 2014 Post subject: |
Carbs are fine, just need resetting. No leaks, new rubber gaskets fitted on the manifold etc. Has been sprayed to death with easy start and it doesn't change the revs, whereas initially it was leaking from the mating gasket on the inlet and revving.
Just needs mixture right. I think 2 turns is the default and will work from there. I actually don't know where it's at right now, after getting it running, felt elated, had a BBQ so left it there.
After my experience with this so far, I am NOT touching the carb internals again. Clearances, noted. But this thing has only done 8K. Once past that initial bogging, it really flies, well for a heavy 250 anyway. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
Back to top |
wots |
Posted: 22:30 - 19 Jul 2014 Post subject: |
MOT passed, on a proper ride managed to get 70 without too much pain, wouldn't want to run at that constantly. Still have a problem with the initial part of the throttle, sometimes needing to flick it in a particular way. Once above 3K it's fine and is never a problem, revs to the redline too. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
Back to top |
Bunny Lingus |
Bunny Lingus Traffic Copper
Back to top |
wots |
Back to top |
sabian92 |
sabian92 World Chat Champion
Posted: 21:17 - 20 Jul 2014 Post subject: |
Back to top |
Bunny Lingus |
Back to top |
wots |
Posted: 22:27 - 20 Jul 2014 Post subject: |
I've spent about £200 on MOT and getting it running, as it needed a new rear tyre, the last 4 years worth of MOT's had advisories for tyre cracks it couldn't pass another. Going to dare to take it to work tomorrow, 30 mile round trip through a mixture of all roads and traffic volumes. Should be fun, wish me luck. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
Back to top |
-Monty- |
-Monty- World Chat Champion
Back to top |
pepperami |
pepperami Super Spammer
Posted: 13:36 - 23 Jul 2014 Post subject: |
This thread has to stop right now! : it`s making me feel guilty about not getting the bits for mine to put it back on the road ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Back to top |
wots |
monteme0 wrote: | How did the ride to work go Wots? | RIDES! Been using all week, it's fabulous, chuck it about and have a bit of fun. Keeps up with the traffic on my commute (and occasionally pass some) which the 125 never could and on the 3 lane section of the A3, which is supposed to be 50, I was a sitting duck. It undulates too which didn't help. This is great, got to 75 which was getting near screaming point so didn't give it anymore. 60-65 is fine with just enough in reserve. Even not quite running right, it's not using fuel. Sitting at traffic lights with 3K idle is hilarious though.
Changed the oil last night, got rid of the acrid tar like stuff in there and put some fresh Motul oil in. Plan to take the carbs off at the weekend and clean the pilot jet. Didn't realise they can block at the very bottom, I just blindly bathed them in carb cleaner thinking it was fine that it was spraying out the sides. Will check that and reset the carbs to two turns.
Front brake is laughable, passed MOT but it's not exactly inspiring. It came with some brand new EBC pads, so I'll clean the caliper, replace the fluid and fit the new pads. The back brake actually performs better and is more predictable. So tend to 50/50 whereas I'd usually be 80-90% front biased. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
Back to top |
Bunny Lingus |
Posted: 14:57 - 23 Jul 2014 Post subject: |
____________________ Bunny Lingus & The Flipside Faggots |
Back to top |
wots |
Back to top |
Bunny Lingus |
Back to top |
wots |
Back to top |
wots |
Posted: 20:57 - 27 Jul 2014 Post subject: |
Cleaned all the jets out, I got myself one of those carb cleaner things, that looks a bit like a set of feeler gauges. Did the job brilliantly. Now idles just fine, but you do need to still give it a bit of throttle to set off, but it always revs up, whereas before it need a number of flicks of the throttle to get the revs up.
Unfortunately, the floats are giving me grief now (I didn't touch them), if I leave the tap on it just pees through. So they'll have to come off again.
Monkey bike front brake and new braided line much better than last week, although new Master Cylinder on the way. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
Back to top |
The last post was made 9 years, 272 days ago. Instead of replying here, would creating a new thread be more useful? |
