Project Electric (Push) Bike - Now With Video
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Aff
PostPosted: 20:48 - 10 Jun 2014    Post subject: Reply with quote
Just a quick test to see how this works, let me know what you guys think:
https://www.youtube.com/watch?v=YdP5Yvwp8us&feature=youtu.be
Electric Bike Project
The Artist
PostPosted: 20:54 - 10 Jun 2014    Post subject: Reply with quote
So how long till the police pull you over. Laughing
Looks awesome.
Aff
PostPosted: 20:56 - 10 Jun 2014    Post subject: Reply with quote
Looks awesome.
Don't know what you're talking about. It's a 200W motor sir, I just have very strong, loud, legs.
Aff
PostPosted: 17:32 - 13 Jun 2014    Post subject: Reply with quote
Picked up a few of these, gonna incorporate them into my dash when I get round to building it.
They are cell monitors. Have a really nice clear OLED display on them.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0636_zps5603ca22.jpg
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0637_zps224600d9.jpg
Aff
PostPosted: 07:52 - 14 Jun 2014    Post subject: Reply with quote
A few clips from my ride yesterday evening.
https://www.youtube.com/watch?v=sKzcUVsoEX0&feature=youtu.be
Aff
PostPosted: 18:58 - 16 Jun 2014    Post subject: Reply with quote
My chainring turned up from 'Murica:
https://i1135.photobucket.com/albums/m637/Biles/EBike/20140616_173317_zpsplgr0jdc.jpg
Just about fits on, But the old 44T large chainring doesn't fit in the middle, so I will have to run with 1 gear until I can buy a slightly smaller one.
https://i1135.photobucket.com/albums/m637/Biles/EBike/20140616_182612_zpszivvpmcp.jpg
Aff
PostPosted: 21:25 - 19 Jun 2014    Post subject: Project Electric (Push) Bike - Now With Video Reply with quote
OK so finally got round to the "mystery box".
The last set of packs I made were soldered together. This works but is VERY time consuming and is potentially damaging to the cells.
Large volume packs (laptop batteries, Tesla, etc) are made using Nickel Strip that it is spot welded to the ends of the battery.
Problem is spot welders are many hundreds of pounds, so I thought I might as well try and make my own. Laughing
So how I'm doing it, take a transformer out of a microwave:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0592_zps140c430b.jpg
So this transformer has a 240 turn primary and around a 2000 turn secondary to make it kick out about 2000V @ 0.4A.
I will replace the secondary with 2 turns so that it puts out about 2V @ 1000A.
The windings are epoxied into the core so to remove them you first need to split the core. It is welded together.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0640_zps8f4380ce.jpg
So first you need to grind off the weld.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0641_zps9d2c68ee.jpg
Then you can pry the "I" second of the core from the "E" section.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0642_zps6cc51314.jpg
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0643_zps3a87afc7.jpg
You then need to try to remove the primary coil. This needs to be done very carefully, if you remove the enamel from the magnet wire it can short out the coil and ruin the transformer. I done exactly this the first time I tried so had to buy another transformer.
I found the best was is to pack the gap with paper towels, then use a wide masonry chisel to pack them in, then keep packing more and more in until it comes out.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0644_zps57957af8.jpg
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0645_zps0e869c15.jpg
The secondary you can just pummel out with a hammer because it wont be used again.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0646_zps2f1f69a4.jpg
Which leaves you with the empty core.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0647_zps34123baf.jpg
These are you bits you keep ( and the "I" section of the core)
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0648_zps757667e2.jpg
Wrap in 2 turns of 4AWG wire:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0649_zps1cbf57a2.jpg
Put the shunts back in.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0650_zpsccc5618d.jpg
And the primary:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0651_zpsa0de83a2.jpg
That's the step down transformer complete. I will epoxy or weld the core back together when I finish the design for the welder.
I then cut some MDF:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0652_zps3be4517f.jpg
Mounted the base of the transformer.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0653_zps48969060.jpg
And mounted a 240V fan to help keep things cool.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0654_zps70b3dd47.jpg
Will get more done when I get some more time.
I would like to add that my knowledge of Electronics/Electrical stuff is extremely limited, I am Mechanical Design Engineer by trade so this magic electrical pixie stuff is all new to me. I know the fundamentals but please point out if I am about to kill myself. Laughing
trisers
PostPosted: 01:05 - 21 Jun 2014    Post subject: Reply with quote
How are you going to control the output current?
PostPosted: 06:40 - 21 Jun 2014    Post subject: Reply with quote
I'd insulate the sharp corners on the 2-turns with mylar or something, or it might end up shorting if it get's hot enough to soften the insulation.
Also, be careful messing with microwaves, or this might happen:
https://www.youtube.com/watch?v=Wa07Mqpr32E
Aff
PostPosted: 17:29 - 22 Jun 2014    Post subject: Reply with quote
Not going to control the current. The shunts in there should limit it to a reasonable amount. I'm going to need to control the weld time though.
Because I suck at electronics, my attempts to make a Monostable 555 pulse generator have failed miserably, so I think I'm going to use an Arduino board, I've had some mild success with them in the past. Laughing
Aff
PostPosted: 21:25 - 27 Jun 2014    Post subject: Reply with quote
Started to model up a few bits a pieces.
18650 cell:
https://i1135.photobucket.com/albums/m637/Biles/EBike/18650_zpsabd343d8.png
Temp Gauge:
https://i1135.photobucket.com/albums/m637/Biles/EBike/TEMPDISP_zps18f7c273.png
Battery Spacer:
https://i1135.photobucket.com/albums/m637/Biles/EBike/BATTSPACER_zpsf6b61df0.png
24V 25Ah pack laid out how my original pack was:
https://i1135.photobucket.com/albums/m637/Biles/EBike/BPACK1_zps8a8b9c1a.png
Still undecided on the battery layout. I will be able to make a more informed decision when I have the frame modelled up.
PostPosted: 13:01 - 30 Jun 2014    Post subject: Reply with quote
Would you consider to start doing kits? i.e. proving the charger controller and battery pack.
How much would it be?
Aff
PostPosted: 14:07 - 30 Jun 2014    Post subject: Reply with quote
How it is at the moment is definitely not "plug and play", so wouldn't really be suitable to sell.
However if you are interested I would be more than willing to help you with design, sourcing the parts, etc.
PostPosted: 16:46 - 30 Jun 2014    Post subject: Reply with quote
Cheers I'll have a think, I definitely don't need one but it looks cool!
I happy to put it all together but all the electrics is over myhead.
Aff
PostPosted: 17:33 - 20 Jul 2014    Post subject: Reply with quote
Progress.
The Arduino arrived. My shitty programming skills are even more shitty than I remember them being. Took me bloody ages to get some code that worked.
All I wanted was a single ~100ms pulse when I hit a switch, with no repeat.
Here is what I came up with in the end. If anyone has a better solution, please let me know:
Code:
int gatePin = 12;
int buttonPin = 2;
long interval = 150;
byte CurrButtonState,PrevButtonState;
unsigned long gateTime;
void setup()
pinMode(gatePin, OUTPUT);
pinMode(buttonPin, INPUT);
void loop()
CurrButtonState = digitalRead(buttonPin);
if (CurrButtonState == HIGH && PrevButtonState==LOW)
  gateTime = millis();
  digitalWrite(gatePin, HIGH);
if (millis()-gateTime >= interval)
  digitalWrite(gatePin, LOW);
PrevButtonState = CurrButtonState;
Put the Arduino on the spot welder and wired up.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0667_zpsc8022966.jpg
Added a foot pedal:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0668_zpsc7cbac1a.jpg
Some clamps on the ends of the wires:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0669_zps77e8f355.jpg
Bought some "solid copper rods" which I ground down to points. Turns out they are only copper plated though, which is a pain.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0670_zps143fed26.jpg
Fitted in the clamp:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0671_zpsbc087cb8.jpg
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0672_zps6792b060.jpg
And it works!
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0673_zps0af78b97.jpg
Just some tweaking needed now on the weld time to get stronger welds. Also need to find some solid copper rod, as at the moment it's just as likely to weld the electrode to the strip as it is the weld the strip to itself.
Aff
PostPosted: 18:26 - 23 Aug 2014    Post subject: Reply with quote
Well I found some time to play around with the welders settings and we have success!
To start with I swapped the stupid Copper Plated Steel electrodes out for some solid Copper ones and profiled the ends.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_20140813_183423_zps8e858ddd.jpg
I then started trying to dial in the welding time. The welder is kicking out about 450-500A and I found a weld time of 127ms to give the best results.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0734_zpsa4ab87d1.jpg
When trying to rip the 2 pieces apart the welded metal stays where it is and the strip tears off around it, which is very good (better than some of the factory ones I found on the laptop cells).
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0735_zpsfc3d943f.jpg
My first weld onto a cell:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0736_zpsa4588b53.jpg
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0738_zps11060f0a.jpg
Worked nicely, and there was virtually no heat transfer, which is the main aim of this. Welds were cool to the touch instantly after welding.
So I put together my fist little pack:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0739_zpsdaea7ea1.jpg
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0740_zps0c204728.jpg
It's extremely strong. It would be very hard to pull this apart with your bare hands, and would probably just damage the cells instead.
I also done a test fit of the batteries on the bike:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_20140813_180501_zps50169de4.jpg
hmmmnz
PostPosted: 09:53 - 24 Aug 2014    Post subject: Reply with quote
that looks awesome, are you going to cover the batteries??
perspex might be the go,
keep up the good work
the humans are dead
I kick arse for the lord
Aff
PostPosted: 10:21 - 24 Aug 2014    Post subject: Reply with quote
Yep, just need to figure out how I can get it all in the frame, along with some vibration dampening.
Some sort of plastic would probably be best. When I have it figured I was going to shoot N.E a message to see if he could laser cut me something.
Aff
PostPosted: 21:19 - 25 Aug 2014    Post subject: Reply with quote
Got around to laying it all out properly. Managed to fit 180 cells in there, so just over 1.5kWh Very Happy .
Getting the configuration right hurt my brain a bit. Embarassed
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0750_zps05134787.jpg
First welds done. Only a few thousand left Shocked .
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0746_zps82095a7d.jpg
First side connected up. This is 18 lots of 10P packs.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0748_zpse304802c.jpg
Both sides done.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0751_zpsc8ad7412.jpg
And all the packs connected in series. Will come hot of the charger at about 75V. Took about 6 hours to do all the welding. I dread to think how long it would have taken to solder it all Laughing .
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0753_zpseaa945ab.jpg
So now just need to add 21 balance leads, 6 power leads and some temp sensors, then figure out how to mount it in the frame. Very Happy
PostPosted: 11:43 - 09 Oct 2014    Post subject: Reply with quote
You are either nuts or a genius. The balls it takes to hack apart a microwave, turn it into a spot welder then use it on batteries is huge IMO. The only thing I would have been unsure of, had I done it would be what would kill me first. Electrocution or explosion.
The Artist
PostPosted: 13:02 - 09 Oct 2014    Post subject: Reply with quote
This is glorious. Thumbs Up
Matt B
PostPosted: 16:13 - 09 Oct 2014    Post subject: Reply with quote
He is both...
https://meetville.com/images/quotes/Quotation-E-B-White-genius-intelligence-Meetville-Quotes-182617.jpg
And we need a "this post is pure insanity" button Karma
PostPosted: 17:14 - 09 Oct 2014    Post subject: Reply with quote
How much does that thing weigh? Laughing
Aff
PostPosted: 18:59 - 09 Oct 2014    Post subject: Reply with quote
Forgot to update this. I have been doing a few bits and pieces when I get time.
Started to lay out the balance wire routing, It gets a bit cramped when you have to route this many:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0758_zps22763fef.jpg
While doing this, the mechanical relay on the welder gave up, giving about 50 welds to the top of one cell. Laughing This eneded in a Lithiumey mess, no 'splosions though.
I replaced the mechanical relay with a solid state one:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0772_zps3c61b039.jpg
Then glued the balance wires in their final positions:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0773_zps12321e6b.jpg
And added the connectors:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0774_zps464732d0.jpg
I have started to add the main power wires, still need to figure out where they will all go. I'm using 10 gauge high flex silicone wire:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0775_zpsda0c6d54.jpg
Ste, weight is pretty good:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0776_zps31cfb9b0.jpg
bladerunner
PostPosted: 17:49 - 12 Oct 2014    Post subject: Reply with quote
Be jeezus .....have you seen the film "fastest Indian"? This is like the modern day version Wink looking very neat I must say Thumbs Up Thumbs Up
The last post was made 9 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Page 7 of 9
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.58 - MySQL Queries: 17 - Page Size: 158.79 Kb
