Author |
johnsmith222 |
johnsmith222 World Chat Champion
Posted: 17:28 - 27 Aug 2014 Post subject: RXS100 - Leaky Carb and Oil Fouled Plugs. |
Hi guys.
A quick question just to ask whether or not a carb which overflows would also cause a sparkplug to become oil fouled?
I am having these two issues, and I have tried to sort the carb multiple times, but I guess maybe it just keeps getting corroded, or stuff blocks the needle valve and causes this problem.
Just making sure that sorting the carb is likely to sort my fouling problem.
Thanks again. |
Back to top |
bladerunner |
Back to top |
johnsmith222 |
Posted: 13:46 - 28 Aug 2014 Post subject: |
Thanks bladerunner. I think I've identified the true source of the problem. My tank is far too rusty inside and is transferring that mess down into the carb. I believe this is clogging the float valve and causing problems where it isn't closing correctly.
The carb has been dismantled and cleaned multiple times, but it always gets into a terrible mess.
There is a fuel filter present, but this doesn't seem to prevent the rust from getting to the carb. It is this kind of fuel filter:
https://i.ebayimg.com/00/s/OTYwWDEyODA=/$(KGrHqN,!n8E63WLoHU1BPDfOou-Cw~~60_35.JPG
Tbh part of me thinks the tank is bin fodder, but then it does't leak yet so maybe something can be done to sort the problem. |
Back to top |
N cee thirty |
N cee thirty Banned
Back to top |
johnsmith222 |
Back to top |
bladerunner |
Back to top |
N cee thirty |
N cee thirty Banned
Back to top |
Robby |
Robby Dirty Old Man
Posted: 09:44 - 29 Aug 2014 Post subject: |
If the tank is rusty, it needs to be de-rusted. Don't use a sealer, get rid of the rust instead. This guide is the one I like to follow, most effective one that I've come across.
https://www.realclassic.co.uk/techfiles/petrol_tank_cleaning_and_rust_removal.html
Just bear in mind that acid will attack aluminium alloy, so don't leave any alloy parts like the fuel tap or cap fitted. |
Back to top |
johnsmith222 |
Posted: 20:32 - 01 Sep 2014 Post subject: |
Thanks for the help guys.
I have decided to go ahead and de-rust my tank using caustic soda and electrolysis. I have ordered the stuff that I need and I have the tank off and drained.
Thanks for the tips robby. It's been helpful as your post has made me decide to do this process, although I'm going to give the acids a miss as I don't fancy dealing with the fumes etc.
What are peoples opinion of the fuel filters for the RXS100, as they seem to let the powdered rust through. I will need a new one anyway, but are there more effective ones that I could use which trap all the powdered rust?
The RXS100 uses this filter type:
https://images.wemoto.com/full/FUEL_FILTER/10047598.jpg
But I know my kawasakis use this type (but also know they have a fuel pump)
https://images.wemoto.com/full/FUEL/10003116.jpg
My plan is to do the tank electrolysis and then seal the tank using POR15. I can just buy the POR15 because I read that this method makes a good key for it to seal (in practical sportsbikes magazine).
Hopefully this will solve my problem and get my RXS running reliably. |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
mudcow007 |
mudcow007 World Chat Champion
Back to top |
The last post was made 9 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
