GK73A
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3 ... , 12, 13, 14  Next
CHR15
Turbo nutter bastard
PostPosted: 20:05 - 11 Jun 2013    Post subject: Reply with quote
use a bandit 400 rear wheel instead.
lihp
PostPosted: 20:08 - 11 Jun 2013    Post subject: Reply with quote
I need a 4.5" wide and 17" diameter rim so I can get a 160/60/17 on it, normal rim is 4" so will need I reckon to space out front sprocket 1/4"
But can't be certain till I have them
CHR15
PostPosted: 20:10 - 11 Jun 2013    Post subject: Reply with quote
use a bandit 400 wheel.
lihp
PostPosted: 20:16 - 11 Jun 2013    Post subject: Reply with quote
Seems as though a 160/60/17 does fit on a 4" rim. Awesome!
CHR15
PostPosted: 19:29 - 15 Oct 2013    Post subject: Reply with quote
been to look at the engine today.
the whole thing has been vapor blasted.
is now being masked up and 2pac'd in as close as possible to the original colour
Noxious89123
PostPosted: 21:16 - 15 Oct 2013    Post subject: Reply with quote
Pictures of the aforementioned engine porn are required. Drooling
CHR15
PostPosted: 21:41 - 15 Oct 2013    Post subject: Reply with quote
im debating whether or not to play with this engine or just build it up as stock.
its going to look stock on the outside. i might end up doing a bit of blueprinting and taking some weight off the crank and clutch primary gear.
RhynoCZ
PostPosted: 22:09 - 15 Oct 2013    Post subject: Reply with quote
I went through the thread and I'm thinking of taking my ZX7R apart. Very inspirational thread, thanks for sharing. Thumbs Up
Now, I'm fixing the exhaust, the crack on it was welded the other day, I sandpapered it, today gave it the first layer of paint and I think I'm not done yet. New f/r wheel and swing arm bearings are next on my list. Smile
CHR15
PostPosted: 20:45 - 22 Nov 2013    Post subject: Reply with quote
engine back from paint.
https://scontent-a-lhr.xx.fbcdn.net/hphotos-ash3/1426396_10151765006433365_1495962548_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn1/860411_10151765006443365_831196439_o.jpg
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-ash3/1397567_10151765006438365_346713228_o.jpg
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-prn2/1400403_10151765006448365_2067099548_o.jpg
0l0dom0l0
PostPosted: 14:17 - 23 Nov 2013    Post subject: Reply with quote
Nice.
Will an engine painter paint a non stripped engine?
CHR15
PostPosted: 15:44 - 23 Nov 2013    Post subject: Reply with quote
i have no idea.
dunno how you'd get it clean enough to do a really decent job.
this one was split down to the bare cases, everything soda blasted back to bare metal and then painted, so its all mint.
imagine you'd have some pockets of grime and stuff if you didn't get it properly cleaned before hand. (i know i did when i tried to paint the bandit engine myself)
There is a gap of 281 days between these two posts...
Fazer Tom
PostPosted: 18:34 - 31 Aug 2014    Post subject: Reply with quote
It's been almost a year, you got any further with this?
(CBT 01/07/11. Theory, 21/05/12. MOD 1, 01/06/12. MOD 2, 3/08/12)
Past: (1981 CG125) (1992 ZZR250 x2) (1976 KZ400) (1993 400 Superfour) (2002 Triumph TT600) (1998 Fazer) (2001 CCM 636) (2000 CCM 604) (2007 Kawasaki Z750) (2005 Husqvarna SM450R) Current: (1989 Bandit 400)
CHR15
PostPosted: 20:45 - 01 Sep 2014    Post subject: Reply with quote
lol no.
well, i took all the engine bits out the bubble wrap and placed them together and it looked nice.
then i put them back in the bubble wrap and in the loft.
i'll do it at some point, im just really busy with work and racing and stuff.
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
There is a gap of 187 days between these two posts...
CHR15
PostPosted: 17:52 - 08 Mar 2015    Post subject: Reply with quote
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-xpf1/v/t1.0-9/16468_10152707341743365_3362405648060312864_n.jpg?oh=96e10279b0b113f2491917fb03517a98&oe=5577BD6E&__gda__=1435614127_8c90aa365f635b6992204b0e9b3674bd
picked up a lifetime supply of engine bits.
theres about 3 engines worth of bits, all stripped.
i have the decent painted crankcases i had done a few years ago, so i'll probably rob the best of these internals to build a totally stock motor in the painted cases and then build a 'development' motor (442 kit, knife edged crank, ported head, timed cams ect... ) using all the bits i've just picked up.
CHR15
PostPosted: 20:28 - 09 Mar 2015    Post subject: Reply with quote
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-xap1/v/t1.0-9/s720x720/11041726_10152709555778365_1438821294839051707_n.jpg?oh=51a896cd8ba0c6de0991f6dc49922714&oe=55BD0F7A&__gda__=1434287809_136283349b5001c83e4fa7a8b73c0888
wow.
such frame.
many mounts.
much attached.
CHR15
PostPosted: 21:30 - 21 Mar 2015    Post subject: Reply with quote
so yeah.
i cant be arsed re typing all this so i'll just paste it.
tl;dr decided to build a 5mm stroker engine with 3mm over bore giving 494 cc
using a mix of 71b (first gen gsxr400) and 73a (third gen gsxr400) parts.
71b camchain is a different type to 73a, so 71b cam sprockets will be needed.
73a conrods fit onto 71b crank.
71b crank counterbalance webs on 2+3 foul on the oil filter casting inside the 73a cases. just need a very small dish grinding into the crankcase.
believe that the 73a sprag clutch and ignition rotor will fit onto the 71b crank, with a little bit of machine work.
fitting the k5 generator rotor to the 71b crank will be somewhat more difficult. need to think about it.
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-xfp1/v/t1.0-9/s720x720/10570304_10152732594018365_9147892163272480959_n.jpg?oh=9d4f720dec3a30323a715cc988b1864d&oe=55BDE1F5&__gda__=1433437196_1b46463266fea7849bcf14197a07fee5
https://scontent-lhr.xx.fbcdn.net/hphotos-xfp1/v/t1.0-9/p180x540/11081492_10152732593998365_550393320276563879_n.jpg?oh=e902461e543033020d03483a2e521fbf&oe=55AD122C
https://scontent-lhr.xx.fbcdn.net/hphotos-xpf1/v/t1.0-9/p180x540/10430884_10152732594008365_7173726519602590170_n.jpg?oh=b9ca5f58900454576b35f8bb280aad28&oe=55834480
the above pictures are a 71b crank fitted with 73a rods in a set of 73a cases.
i need a 71b outer clutch basket before i can go any further.
the gear profile on the 71b/73a is the same, however the 73a clutch gear is too big (diameter) when using a 71b crank.
i believe the below spec will be what i end up using;
73a cases
71b crank
73a rods
73a barrels (possibly with fzr 600 3he liners)
fzr600 3he pistons
73a head
73a cams (with 71b sprockets)
73a clutch (with 71b primary gear reworked to fit)
73a gearbox
73a sprag clutch and ing rotor
gsxr 1000 k5 rotor / stator
katana 400 clutch cover with adapter to suit k5 stator
all liners pressed out of the 73a block and soda blasted
https://scontent-lhr.xx.fbcdn.net/hphotos-xpf1/v/t1.0-9/s720x720/10307392_10152734950603365_8129360779556636909_n.jpg?oh=a563e0f4d7c00b65813bb8bf5df57404&oe=557329D6
all liners pressed out the 3he block and modified to suit the 73a cases
https://scontent-lhr.xx.fbcdn.net/hphotos-xfa1/v/t1.0-9/s720x720/11025231_10152734950633365_1346147524783198279_n.jpg?oh=3a76a271ffd9953cec7dbbb48842926c&oe=5579CDB2
3he pistons just need soda blasting and then valve pockets doing once i've done a dry build to work it all out.
https://scontent-lhr.xx.fbcdn.net/hphotos-xpf1/v/t1.0-9/q81/s720x720/11068395_10152734950593365_6222864364154627650_n.jpg?oh=940bf632aa1bf6a47141028766975817&oe=5571CA90
will drop the block and liners off next week to get them fitted together. just need to re machine the spigot counterbores in the block first.
its pretty much a piece of piss, apart from a little bit of machining to the crank and cases.
also, none of the gsxr 400 (71b, 71f, 73a, 76a or rf400 or any bandit 400) clutch basket primary gears will fit with my combination of crank and cases.
so will need to work out what gear i need and call in a favor to get it cut into a blank. will then machine the rest so it just fits the back of a 73a clutch basket.
CHR15
PostPosted: 17:24 - 22 Mar 2015    Post subject: Reply with quote
block clocked up to open out the flange counterbores.
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-xpf1/v/t1.0-9/11014810_10152736539123365_8130130273615708929_n.jpg?oh=0342e46b82dbc237b76d78ecae850999&oe=55BA5599&__gda__=1433701094_9dc6f167e9adc0d28325ee0687ab0b09
new liners fitted in.
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-xfp1/v/t1.0-9/10428540_10152736539133365_3546070465029867336_n.jpg?oh=e2108d23a8c25e64ce5225b71378f7f8&oe=55757F09&__gda__=1433404268_0936917f929aa9931fd49c077c4e0bf2
this is an issue. i'll get around it by using gsxr 1100 head dowels which are a solid D, rather than the original hollow circular ones.
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-xfp1/v/t1.0-9/11071926_10152736539113365_792739541109867273_n.jpg?oh=63b75fec49e44dddebe5852a5eabba6e&oe=55B25603&__gda__=1437810515_c7d1d8228bad40743d941cca2b87e1ee
CHR15
PostPosted: 21:21 - 26 Mar 2015    Post subject: Reply with quote
3he liners fitted into the 73a barrels and decked by 25 thou.
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-xfp1/v/t1.0-9/p180x540/11066785_10152744701258365_7940599232140421588_n.jpg?oh=4b63f8a9b9d6f057e290970903b299ec&oe=5574BBD8&__gda__=1437555233_f953331bceb9b4ac3ce436aa86c34a90
might have a day off this weekend and do a dry build of the topend.
b422063
PostPosted: 08:52 - 27 Mar 2015    Post subject: Reply with quote
Worst "look at me, I drive a BMW" picture ever. Wink
PostPosted: 09:48 - 27 Mar 2015    Post subject: Reply with quote
CHR15 wrote:
I'd quite like Jade or Amy to give me a Semi. Wink
Alpha-9
PostPosted: 19:11 - 27 Mar 2015    Post subject: Reply with quote
MarJay wrote:
Only £25 for a finish off Thumbs Up
Fzr-600 1999
The last post was made 9 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Page 13 of 14
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.68 - MySQL Queries: 17 - Page Size: 153.42 Kb
