Author |
_Iain_ |
_Iain_ Banned
Back to top |
MC |
MC Banned
Back to top |
_Iain_ |
_Iain_ Banned
Posted: 09:21 - 15 Sep 2014 Post subject: |
32 inches between the floor under my heel and my bollocks.
Lowering kit availible to drop the seat height by 25mm too looking at my parts catalouge....combine that with some MX boots to raise you up a bit...
It's a lot shorter than the CR and we did manage to get Doovy on that ____________________ Please be aware that the above post may be full of complete nonsense.
Back to top |
P. |
P. Red Rocket
Back to top |
_Iain_ |
_Iain_ Banned
Back to top |
SQL |
SQL World Chat Champion
Posted: 12:25 - 15 Sep 2014 Post subject: |
What tunnel was that? |
Back to top |
_Iain_ |
_Iain_ Banned
Back to top |
_Iain_ |
_Iain_ Banned
Posted: 00:33 - 18 Sep 2014 Post subject: |
So, now I have 2" cores in my exhaust it flows a lot better. It did feel noticeably more responsive sub 4k, however it still wasn't quite right.
After a bit of research these went in the spares box.
https://i.imgur.com/QUjPxlt.jpg
This allowed it to breathe better & the 170 main (+5) got it running reasonably well. Took it out for a run and was well impressed, flat out it was pulling 95-100 on stretches it struggled to touch 90 before. Binning the airbox lid is proven to give the dukes more power, KTM offered a mesh lid as an offical powerpart, however the dyno shows better results with no cover at all. Reccomended jetting is 170-175 main. My 172.5 & 175 jets are on back order & will no doubt be useful when it finally goes on Slipstreams dyno.
Then I found out about "Electronic Power Control"
Cracking little system. You pin it & a computer decides how much throttle you actually get by bleeding air into the diaphragm cap on the top of the carb, causing the slide to drop.
https://creeper.smugmug.com/photos/53298961-O.jpg
You need the following parts to remove it from a US version which diddn't have the system;
K58031005000 - CLAMP YDNAC 10128 12MM £0.40+VAT
K57931001010 - PLUG CAP FOR EPC CONNECTION £0.45+VAT
Pop fuel tank off, remove this hose on the very top of the carburettor & fit the blanking plug. Ought to be fairly simples.
https://www.monomaniacs.nl/images/tnt/KTM-Duke-II/Remove-the-EPS/before2.jpg
Homemade plugs have also been used in the past (pictured below), but a proper KTM one for around £1? C'mon - you know it makes sense
https://www.monomaniacs.nl/images/tnt/KTM-Duke-II/Remove-the-EPS/carb-top.jpg
Pull this lot off;
https://i.imgur.com/5RfB0VR.jpg
Pull the filter off the bottom of the T piece & attach this to the other hose coming from the airbox side of the carb (the hose that would attach to the white T piece. Filter shown below on the left.
The only thing left after that is to hide the plug up out of the way under the tank, plug shown on the right.
https://www.monomaniacs.nl/images/tnt/KTM-Duke-II/Remove-the-EPS/before1.jpg
It now feels a completely different bike sub 4k, throttle response is much better. I still need to drill the slide, chop the spring, swap the pilot jet over & then reset the idle mix screw but it's progress for sure!
The exhaust mod cost a bottle of wine, and £10 for tubing on eBay, the airbox mod/rejet cost £4 and removal of EPC was free. Not bad for a £20 spend at all
Have also ordered the stuff to blank the emissions crap off on the cylinder - KTM actually make the blanking plugs & a r/h exhaust stub without the bracketry on it...only cost a tenner. Will see if this helps it. ____________________ Please be aware that the above post may be full of complete nonsense.
Back to top |
stevo as b4 |
Back to top |
_Iain_ |
_Iain_ Banned
Back to top |
P. |
P. Red Rocket
Posted: 12:02 - 19 Sep 2014 Post subject: |
Running downgeared however will just up the revs in the long run, having geared for 105 but only doing 90 is a little safer on the motor than geared for 90 and doing 80.
See TTR
Do some 2nd and 3rd gear clutch ups, get comfy with it and then we can have wheelie races |
Back to top |
_Iain_ |
_Iain_ Banned
Posted: 12:53 - 19 Sep 2014 Post subject: |
I've basicly sacrificed 5-10mph top speed & gained a much more responsive bike through 3rd & 4th gear.
1st was too close for tight roundabouts, and 2nd was too long so you either jerked it in first or chugged the motor in 2nd and it got annoying! With the downgear 2nd is then perfect for all that round town stuff & filtering.
Thing is, the bike gets unstable and gets a headshaker on at about 80-85mph, so I tend to blast up to about that on the dual carridgeways then roll off to around 70ish anyway as its a bit sketch taking my hand off the bars when you know that the slightest little bump is going to set it off. It revs about 500rpm higher than it previously did at normal cruising speeds so realy isnt too bad to live with. I did get it to touch just over a ton on a downhill stretch, and it was sat about 1250rpm-1500rpm off the redline which is plenty safe margin I reckon.
I think KTM massively over-geared it from the factory - the sprocket/swingarm clearance is so so tiny on a standard 17t that pattern sprockets don't even fit on the bike KTM's genuine part has a slightly shorter tooth which clears it by 1-1.5mm
Take it out & lemme know what you reckon, it's a lot nicer round town & twisty backlanes which is really where it's best suited anyway ____________________ Please be aware that the above post may be full of complete nonsense.
Back to top |
P. |
P. Red Rocket
Posted: 13:06 - 19 Sep 2014 Post subject: |
In all honesty, I'm not keen taking a single past 70ish anyway, high revs are not my friend in that respect but yeah I'll give it a whirl |
Back to top |
G |
G The Voice of Reason
Back to top |
Fladdem |
Fladdem World Chat Champion
Posted: 20:57 - 19 Sep 2014 Post subject: |
Sorry Iain,
G, do you have any pics of your 690 Enduro? There's a bloke opposite that commutes on one and I like the idea of a bodged rallye fairing stuffed on it... ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
Back to top |
_Iain_ |
_Iain_ Banned
Back to top |
G |
Back to top |
The last post was made 9 years, 219 days ago. Instead of replying here, would creating a new thread be more useful? |
