Author |
bobby1289 |
bobby1289 L Plate Warrior
Posted: 09:21 - 30 Sep 2014 Post subject: Yamaha YBR 07 Ignition |
Hey Everyone.
New to the forum sorry if this sounds dumb.
The ignition on my YBR 07 is faulty. When the key is turned to the On position there is no power, however if I turn the key back to between the On and Off position the power comes on.
I have taken the ignition out and its looks like there is some corrosion on the wiring in the ignition. I want to replace the ignition with a new one but the problem is, I can't find the one for my model anywhere. The ignition on mine connects via a '4 spade' connector block. All the ignitions I can find have 3 wires going into the connector block and the fourth wire separate.
Heres what I can find.
https://www.ebay.co.uk/itm/Yamaha-YBR125-2005-2006-Lock-Set-inc-Ignition-Switch-Fuel-Cap-Seat-Lock-Keys-/350955950570?pt=UK_Motorcycle_Parts_13&hash=item51b69ad1ea
Is there anywhere I can find the correct ignition, I've looked all over. Or is there a way to make the ignition I have found work with my model.
Thanks. |
Back to top |
Rogerborg |
Rogerborg nimbA
Posted: 10:38 - 30 Sep 2014 Post subject: |
Where's the corrosion showing?
That sounds more like an issue with the barrel than the wiring though.
Have you tried cleaning it out? Blow through it, put some alcohol down it, or WD-40 I suppose if you've got nothing better to hand. Graphite powder is the dogs for locks though. ____________________ Biking is 1/20th as dangerous as horse riding.
Back to top |
bobby1289 |
Back to top |
Rogerborg |
Rogerborg nimbA
Posted: 11:21 - 30 Sep 2014 Post subject: |
Sounds like.
I wouldn't recommend this, but I have rescued a shonky lock by simply packing it out with grease.
If it's past saving though, are the wire colours the same on that replacement, and it's just the connectors that are different? If so, chop off the blocks and solder your 4-spade block on to the new wires? ____________________ Biking is 1/20th as dangerous as horse riding.
Back to top |
Tamsin |
Tamsin World Chat Champion
Back to top |
Taught2BCauti... |
Taught2BCauti... World Chat Champion
Posted: 17:03 - 30 Sep 2014 Post subject: |
Soaking the connectors in vinegar will remove the corrosion, but don't leave them soaking for too long at a time (repeat until mended) - and wash thoroughly with water, dry completely, and treat with WD40 after.
Just a thought - has this recently happened? Could some tow-rag have been fiddling with it?
Another thought - could the previous owner have tried to bodge a repair, leaving it with a non-standard connector now? ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
Back to top |
Val |
Val World Chat Champion
Posted: 20:04 - 30 Sep 2014 Post subject: Re: Yamaha YBR 07 Ignition |
bobby1289 wrote: |
Thanks. |
Yes there is a place you can find it. No need to be creative and chop or reroute blocks
Go to Yamaha parts finder, find your exact part, print the part number, go to your nearest Yamaha dealer and they will supply you the correct part.
https://www.yamaha-motor.eu/uk/services/online-parts-catalogue/index.aspx
And no you do not clean electrical contacts with WD-40
You use electrical contacts cleaner for ignition and other electricals:
https://www.halfords.com/motoring/engine-oils-fluids/lubricating-penetrating-oil/halfords-electrical-contact-cleaner-400ml
Finally if you need to lubricate any lock including your bike ignition lock, use dry graphite lubricant:
https://www.tesco.com/direct/graphite-lock-lubricant/302-5712.prd?pageLevel=&skuId=302-5712&ui=mercury&sc_cmp=pcp_GSF_Car_302-5712kpid=302-5712&sc_cmp=tp1_ppc_g__&kpid=302-5712&gclid=CjwKEAjwqamhBRDeyKKuuYztxwQSJAA1luvG0yYPf4RLyD5GvX3ksdKYI5Uve4OfAOaNa-9gdzl6oRoCdGHw_wcB ____________________ Adrian Monk: Unless I'm wrong, which, you know, I'm not...
Yamaha Fazer FZS 600, MT09, XSR 900 |
Back to top |
The last post was made 9 years, 209 days ago. Instead of replying here, would creating a new thread be more useful? |
