The Life of My GS125
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4  Next
HotdogMcDraw
PostPosted: 00:42 - 05 Oct 2014    Post subject: Reply with quote
I had a similar problem with my carb when the needle was sticking, reaked of fuel every time i started my old bike up.
Having said that, the drain screw is just above the overflow you mentioned, could be a bad screw that might need replacing?
https://www.bikechatforums.com/viewtopic.php?t=284963 - What to expect on a MOD 1 (contains video footage) - Posted by BG5067
Honda Rebel 125 (L Plate Warrior) - Nov 2013 to Aug 2014, BMW G650 GS ABS - Aug 2014 to Current
Knacker
PostPosted: 00:48 - 05 Oct 2014    Post subject: Reply with quote
I posted a Video in May of it running quite happily and haven't touched the engine or carb since so I'm going to whip the carb off tomorrow and give it a clean.
And will also check to see if I have a spark Thumbs Up
Previous: K1 GSXR 1000
Knacker
PostPosted: 18:49 - 05 Oct 2014    Post subject: Reply with quote
Well I cleaned up my old carb swapped them over still nothing, Changed the Coil and Cap still nothing changed the CDI still nothing.
I Jiggled the throttle cable and it fired into life at about 6k rpm then died after about 20 seconds then deaded.
Given up for now before I set fire to it.
Knacker
PostPosted: 12:55 - 09 Oct 2014    Post subject: Reply with quote
Still stuck with a non starter Crying or Very sad
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/th_99281320-131A-4B7D-A80D-983D800BF64E.mp4
Have spark and the plug getting wet so its getting fuel but maybe too much so going to check the float height.
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/th_D8923F5F-B56B-466C-87E7-490DD96AD427.mp4
Doesn't even sound like its trying to start.
PostPosted: 14:11 - 09 Oct 2014    Post subject: Reply with quote
Whats the air intake like? check for leaks etc. Have you had the carb apart and cleaned it?
Knacker
PostPosted: 14:40 - 09 Oct 2014    Post subject: Reply with quote
Iv tried 2 Intakes both look fine not even fine cracks on my 26 Year old 1.
Had both carbs off and cleaned, checked floats operating correctly and they're fine.
Seen some Keihin (I think that's how it's spelt) Carb on eBay Brand new for £49 might buy 1 just to see if that's the issue. As I really can't think of it being anything else.
PostPosted: 14:43 - 09 Oct 2014    Post subject: Reply with quote
Woah, I really wouldn't go splashing £50 on a carb, they are relatively simple things and don't have a lot to go wrong if they are set correctly. What condition is the air filter in? does using the choke make any difference?
Knacker
PostPosted: 14:50 - 09 Oct 2014    Post subject: Reply with quote
Air filter brand new and Choke makes no difference at all, I'm going to bring both carbs into work tomorrow and make sure I have at least 1 fully functional set up Carburettor.
Knacker
PostPosted: 09:39 - 10 Oct 2014    Post subject: Reply with quote
I noticed this morning when I was removing the Carb the throttle cable spring is all a bit squiffy and wondered if this could be the suspect in question.
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/B3650C73-11B6-465A-B40A-5CE06FC62404.jpg
Knacker
PostPosted: 10:56 - 10 Oct 2014    Post subject: Reply with quote
Well Iv cleaned the carb again removed the jets and cleaned them set the fuel mixture screw to Haynes spec and set the float levels at 24.5mm.
Edit: Also sat the main jet in as it all looked a bit bodged so that's now set in properly.
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/imagejpg1-34.jpg
If this doesn't cure it then I really am stumped.
Just_James
PostPosted: 23:41 - 10 Oct 2014    Post subject: Reply with quote
Some squiffiness of the spring is normal and is the tension of the cable just pulling the top to one side, it will sit straight enough once it's back in the carb.
That said, there does seem to be quite a bit of tension on that - have you checked that your cable is adjusted correctly, not got any snags or crimped parts etc that could be putting tension on it? Looking at that pic it seems the cable is heavily adjusted at the carb end - try winding the carb top back upto that lock nut and slackening off the tension.
Failing that, a thought of another possibility of your problem... although I don't know the specifics of that carb' most will only allow the slider to go in one way but others will let you put it in more than one way (i.e. the right way and a wrong way). Do you have full smooth movement of the throttle or does it feel like it's already part open?
I just remember messing with a mates MT50 ( Embarassed ) field bike in my younger days when first getting into bikes and we had a problem with just your symptoms that had us stumped.... turned out we had put the slider in wrong so the alignment slots were in the wrong position and it was trying to start / run on pretty much full throttle Embarassed
Just make sure the slider is going all the way down and that your throttle feels normal, if in doubt try it the other way about and see if its any different Wink
Knacker
PostPosted: 20:14 - 12 Oct 2014    Post subject: Reply with quote
Well thanks to mentalboy who came over and helped me today the bike is up and running again so the project may continue Laughing
Time to order a new caliper Laughing
slowlydoesit
PostPosted: 20:25 - 12 Oct 2014    Post subject: Reply with quote
Sounds good. That carb looked familiar from taking apart the one on my GS125 a couple of decades ago.
What was the problem that mentalboy fixed then?
Kawasaki KMX200 with broken fixed powervalves and a stutter
Knacker
PostPosted: 21:02 - 12 Oct 2014    Post subject: Reply with quote
To be honest the carb was on and off so many times changing the components and double checking earths and throttle cable and choke etc
So glad to be able to get on with it again and it's all thanks to Mark Thumbs Up Karma
impulsive
PostPosted: 21:55 - 13 Oct 2014    Post subject: Reply with quote
you got yours running same time as me Mr. Green
https://vid.me/OLn
Knacker
PostPosted: 19:04 - 16 Oct 2014    Post subject: Reply with quote
Just a quick question, When we got the bike running again it did seem a bit on the noisy side, now Iv got my old engine which used to run as sweet as a nut albeit 5 years ago.
In that time it has mainly sat outside without the inlet or exhaust port covered is it scrap or could it be salvaged?
If the latter would it require a top end rebuild first or at least a strip down?
In the mean time here's a picture of an Air Filter
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/imagejpg1-35.jpg
Knacker
PostPosted: 16:47 - 19 Oct 2014    Post subject: Reply with quote
Shall have an exciting update in about 2 hours Very Happy
Knacker
PostPosted: 18:51 - 19 Oct 2014    Post subject: Reply with quote
B e a u tiful!
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/imagejpg1-36.jpg
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/imagejpg6-3.jpg
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/imagejpg3-5.jpg
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/imagejpg5-3.jpg
Awsome!
50 Ponds.
Caliper arriving shortly and mudguard and rear tail bit ordered.
Knacker
PostPosted: 11:33 - 22 Oct 2014    Post subject: Reply with quote
Caliper arrived today and was suprised at how good it was for £20
bit grubby but as can be expected with ebay.
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/B224849C-2062-4180-B7E7-94FC3489AFA8.jpg
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/3D3254DB-9720-48CA-AF66-030DA8DB17E6.jpg
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/DD3051B3-7378-4333-9C12-9AD65997B081.jpg
So got the brake cleaner out and cleaned all the crap off and regreased the slide pins and shall be fitting it tonight with new pads and fresh brake fluid which will be squeezed through my Fireblade MC.
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/9B3AD311-15A0-4BA8-B0B2-430C72D90FDA.jpg
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/ABA93E79-0404-4C5B-AF4E-90640AF977EB.jpg
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/AA1BC662-0C36-4F54-8585-7CBD3731C410.jpg
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/12BA26DA-78C1-4499-A87A-DA02E59C1AC5.jpg
Just_James
PostPosted: 23:10 - 22 Oct 2014    Post subject: Reply with quote
Knacker wrote:
Looking good Thumbs Up
Are they original? 50 ponds for the lot seems a bargain Thumbs Up
Knacker
PostPosted: 10:24 - 23 Oct 2014    Post subject: Reply with quote
I wondered this and compared them to my old knackered 1 and have exactly the same markings and says made in Japan but I think they are in way to good condition to be nearly 30 years old but as long as the tank doesn't leak I couldn't give a .....
I thought I already had a new filter in the bike but it would appear I did or Iv lost it so I replaced old with new Shocked
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/BC9A4F19-3DA9-4C7C-824C-554AE5E5DC98.jpg
Fitted the MC and Res this morning was up and out in the garage by about 7:40am Laughing
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/975F8FEC-0305-4575-8A34-799C0F127C6B.jpg
also bolted the calliper on with new pads although didn't get round to bleeding them before I had to leave for work.
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/8994FD88-0F33-4EFC-9901-770DC4640266.jpg
Now all I have to do is drop the fork legs in the Yokes a tad and go over every bolt and check they are all done up, put some air in the tyres and its MOT time Dance!
Knacker
PostPosted: 19:18 - 26 Oct 2014    Post subject: Reply with quote
Right well I bled the brakes put some air in the tyres and faffed about dropping the fork legs into the yokes.
There must be an easier way than how I did it but it's done now and checked all the nuts and bolts.
Also picked up the matching Mudguard and tail section.
To cut a long story short had a little ride round on it and booked it in for its Mot which won't be happening until next next Tuesday as we're now going away on holiday for a week.
Both Gsxr's have now been demoted to the back of the garage until next year.
Knacker
PostPosted: 18:03 - 04 Nov 2014    Post subject: Reply with quote
Well took it for it's MOT and unfortunately it didn't pass Crying or Very sad
Had 6 problems
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/5B8C720D-786C-42D7-B85F-FFB578849D74.jpg
Done 4 them, had to order a new Clevis pin and then need to adjust the steering head bearings.
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/imagejpg1-39.jpg
Was great to have a little ride around it on though Laughing
Waiting to get it MOT'd before I fit the mudguard as you can guarantee 1 of the bolts will snap or worse.
Knacker
PostPosted: 17:57 - 18 Nov 2014    Post subject: Reply with quote
I know to most this wasn't the most exciting of Projects but I'm glad to have made this thread.
First of all I'd like to thank my mother for not swallowing me, I'd like to thank the Lord Jesus Christ for his insight, and of course myself because nobody congratulates themselves these days.
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/imagejpg1-40.jpg
It Haz pass!
Just_James
PostPosted: 11:05 - 19 Nov 2014    Post subject: Reply with quote
Well done that man Thumbs Up
The last post was made 9 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.87 - MySQL Queries: 17 - Page Size: 140.11 Kb
