Bike of my dreams
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3  Next
bladeblaster
PostPosted: 08:49 - 14 Oct 2015    Post subject: Reply with quote
So the carbs from E-bay turned up.
https://i491.photobucket.com/albums/rr279/bladeblaster/12141082_10153182941204013_1468178551592066076_o_zpsqz9sgagl.jpg
Only to find that the butterflies are fairly seized, but not sure why. So I get to stripping them down.
Then I find that 2 idle mixture screws are missing and the 2 that are there are both knackered. Managed to get one out, the other one has no chance.
So I go to plan D
I only really need the one body, so I can take the body I need and swap it with the broken body on the other set.
So I start breaking down the bank, most of the screws holding the back together are seized or already rounded off, but hopefully in here somewhere is one good set of carbs.
https://i491.photobucket.com/albums/rr279/bladeblaster/12113447_10153183531559013_595131859415084979_o_zpslhl0cir9.jpg
Took the bank to work and drilled off the screw heads on the pillar drill, separated them, only to find that the body I need is the one with the seized butterfly Evil or Very Mad
So 8 carb bodies, and no 1 good full set Brick Wall
So plan E a full set of A1/A2 carbs came up on ebay so I have bought those. Should arrive today, they had better be good.
andym
PostPosted: 09:14 - 14 Oct 2015    Post subject: Reply with quote
I'm glad I didn't go to all this trouble with my GPz project.... but then I'm also slightly disappointed Confused
I haven't really had the need to strip carbs down to individual pods, so I'll admit I haven't got a clue what I'm talking about here.... but aren't they all the same when EVERYTHING is stripped from them? Or at least in pairs anyway?
Also with the screws on my carbs, they were big enough to get a set of needle nosed mole grips on there to crack them, had to replace all the bottom ones because they were all rounded etc, the top ones I didn't even bother putting much force in to the screwdriver before going for the mole grips again
bladeblaster
PostPosted: 11:18 - 14 Oct 2015    Post subject: Reply with quote
Well they probably are, BUT removing the butterfly assembly is a no go, at least on the outside ones as far as I can see. But TBH I didn't really investigate too much as I didn't to completely knacker it. However once I know the new set is good, and I have nothing to loose, I will have a go. Thumbs Up
Undinist
PostPosted: 12:39 - 14 Oct 2015    Post subject: Reply with quote
Thank you OP, you've saved me thousands of pounds and a shedload of grief - your posts have cured me of the notion that I could one day restore a bike. I don't have the skills or patience and my 'workshop' is unbolting parts in the street and cleaning them in the kitchen.
Current bike: K1100RS. Previous: CD200, GSX250, GT550, VFR750, K100LT, K1100LT, R1100GS, R1150GS, ZZR1100, Hayabusa, RSV Mille, MV F4 750S, R1, ZX-10, KTM Adventure 950S
andym
PostPosted: 12:53 - 14 Oct 2015    Post subject: Reply with quote
Sorry OP, couple of pictures to show that you don't need a "workshop"
That's no excuse, I had a driveway and a first floor flat:
GPz being rebuilt on the driveway:
https://img.photobucket.com/albums/v320/andy36586/GPz750/enginefitted.jpg
ZXR engine being rebuilt in the livingroom:
https://img.photobucket.com/albums/v320/andy36586/Engine-rebuilt-4_zpsf10ab7ad.jpg
Undinist
PostPosted: 13:15 - 14 Oct 2015    Post subject: Reply with quote
That's impressive. But I don't have a driveway. I suppose I could designate a corner of the bathroom as a motorcycle mess. Thinking
bladeblaster
PostPosted: 14:31 - 14 Oct 2015    Post subject: Reply with quote
you def don't need a workshop, but it sure does help.
Patience, well that's definitely something you do need.
bladeblaster
PostPosted: 08:49 - 15 Oct 2015    Post subject: Reply with quote
Vincent wrote:
Those butterfly valves...........I was reading about a tool to help get them off the other day so don't abandon hope. I'll have a look for it.................
Do you have close up pics?
If they're screws...and you've rounded them off.......you're not the first Wink
The actual butterfly, as in the metal disc inside the carb is held on with 2 screws, that bit shouldn't be a problem.
The shaft that its screwed to, is blank on one end, and on the other end is riveted / peened over so it would have to be ground off that end. It may press out from the other end I am not sure. I need to have a look at an exploded diagram, and hopefully that will shed some light.
It is slowly freeing up with regular applications of penetrating fluid, I may put it back through the ultrasonic bath over the weekend.
The new carbs turned up yesterday, and they appear to be spot on. So really I am only working on the sticking one now out of interest, and if I get it fully operational I can sell it. If it ends up in the bin now, its no great loss. Thumbs Up
bladeblaster
PostPosted: 14:11 - 20 Oct 2015    Post subject: Reply with quote
Time for a Carb Saga update.
Repeated application of penetrating fluid did free up the stuck butterfly quite well in the end.
The new carbs looked really good when they arrived, so good I was considering bolting them straight on. However I didn't and I am glad I didn't, the insides we covered in rusty coloured fuel residue. Worse than that all 4 idle adjuster screws were missing their o-ring seals. The ends of teh adjusters were black as hell, must have run as lean as an anorexic bacon sandwich.
So new set stripped & cleaned, I had new idle adjuster seals that I had already bought so that wasn't a problem. So once all cleaned out, time to re-assemble.
Bottom end:-
Vernier set to 17mm to check float heights
https://i491.photobucket.com/albums/rr279/bladeblaster/12112217_10153196568834013_4964418979589696153_n_zpsqzasasar.jpg
Floats & Shut Off Valve in, first checking that the rubber pointy end is in good nick, and the spring on top of the valve is strong & moves freely.
https://i491.photobucket.com/albums/rr279/bladeblaster/12108232_10153196568419013_3674561498513765901_n_zpst7ubzzpe.jpg
Check float height, this one was low as you can see by the gap between the top of the float and the bottom of the vernier body.
https://i491.photobucket.com/albums/rr279/bladeblaster/11222547_10153196568829013_2153848052827561133_o_zpsiqqamwka.jpg
So adjust by bending the small metal tab that the float hangs off, one way or another. Low float means the tab needs bending towards the float. Its a trial and error amount, not an exact science, just keep re-fitting & checking until you get this. The float needs to be sat just on top of the valve without compressing the spring on top of the valve, when you take the measurement.
https://i491.photobucket.com/albums/rr279/bladeblaster/11148220_10153196568839013_4810299778051141949_n_zpsejz01h1m.jpg
Now back in with the various jets:-
Needle Jet
https://i491.photobucket.com/albums/rr279/bladeblaster/11167656_10153196568814013_1465843608683305132_n_zpsq4wuxamc.jpg
Emulsion Tube
https://i491.photobucket.com/albums/rr279/bladeblaster/12115559_10153196568809013_4023030134465796180_n_zpsbuezajnc.jpg
Main Jet
https://i491.photobucket.com/albums/rr279/bladeblaster/12107261_10153196569024013_1117731871199962690_n_zpsykmi5gse.jpg
Pilot Jet
https://i491.photobucket.com/albums/rr279/bladeblaster/1470113_10153196569014013_1377343245997196888_n_zpsidd59egw.jpg
Pilot Adjustment Screw, properly assembled with o-ring seal.
https://i491.photobucket.com/albums/rr279/bladeblaster/12118957_10153196569019013_5542635927046347486_n_zpss1arpti0.jpg
New seal in the float bowl.
https://i491.photobucket.com/albums/rr279/bladeblaster/12095216_10153196569009013_2536180955551177679_o_zpsqnwjwinw.jpg
Now for the top end.
Little bit of Rubber Grease to help the diaphragms seat properly.
https://i491.photobucket.com/albums/rr279/bladeblaster/887479_10153196568459013_9044056090785655878_o_zps8sbz5fsx.jpg
Diaphragm & slide back in, and top face greased.
https://i491.photobucket.com/albums/rr279/bladeblaster/12113291_10153196568439013_2167408889080786081_o_zpsbyvyqd13.jpg
Main Needle In.
https://i491.photobucket.com/albums/rr279/bladeblaster/12095106_10153196568424013_4499037246402542073_o%201_zpsvqe0uhfh.jpg
Spring seat & Spring in, taking care not to black the vacuum port with the spring seat. It has to sit with the legs either side of the hole, if its positioned with a leg blocking the hole, it knackers up the vacuum, and it will never fuel properly.
https://i491.photobucket.com/albums/rr279/bladeblaster/12095278_10153196568454013_19244337403836481_o_zpsyqshbkrr.jpg
Then tops on, and all back together, with nice new cap heads & spring washers.
https://i491.photobucket.com/albums/rr279/bladeblaster/11223925_10153196562389013_1989842155309956333_o_zpszcwbcmaw.jpg
bladeblaster
PostPosted: 16:01 - 29 Dec 2015    Post subject: Reply with quote
well after a long delay for various reasons, the rebuilt carbs are finally in, tank on, and after a bit of persuasion she fired up!!
No oil leak, no fuel leak, and no water leak. All in all very happy.
https://i491.photobucket.com/albums/rr279/bladeblaster/12402102_10153311598649013_5731123952539850697_o_zpsr37i2jtm.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/12401901_10153311597259013_1073222878668105580_o_zpsz4mnutxq.jpg
Next on the shopping list, a new rear shock.
bladeblaster
PostPosted: 19:58 - 31 Dec 2015    Post subject: Reply with quote
More progress today.
Rear suspension stripped out.
https://i491.photobucket.com/albums/rr279/bladeblaster/10381991_10153316150029013_2743669320893333527_n_zpsr7qepvpb.jpg
Excessive play in the linkages. Dogbones cleaned up nice though. Before and after:-
https://i491.photobucket.com/albums/rr279/bladeblaster/1915194_10153316150369013_7868732115725447861_n_zpsobzd8d3r.jpg
New, bearings, bushes and seals required though.
Front fairings back on as well.
https://i491.photobucket.com/albums/rr279/bladeblaster/1272823_10153316232574013_2329591955678865927_o_zpsgsijqisx.jpg
Duffman
PostPosted: 11:14 - 22 Jan 2016    Post subject: Reply with quote
Awesome thread, just joined the motorbike world and BCF and this is the best thread ive found.
i do feel inadequate though Confused
bladeblaster
PostPosted: 13:01 - 22 Jan 2016    Post subject: Reply with quote
Thanks.
Many years of trial and error, driven by necessity, and lack of funds to pay someone else to do it.
I am still learning every time I work on a bike.
chickenstrip
PostPosted: 13:06 - 22 Jan 2016    Post subject: Re: Bike of my dreams Reply with quote
bladeblaster wrote:
probably so cheap because it was advertised as needing a new starter clutch which is a big job. Easily a grand to be done in a bike shop.
So what of this? Was the seller wrong?
bladeblaster
PostPosted: 17:03 - 25 Jan 2016    Post subject: Re: Bike of my dreams Reply with quote
No he was right. Although it was working fine for a time, it is now playing up again.
It's iffy, but speaking to people the can stick when stood for a while. It def worked ok, after it had been moved around in a van a couple of times. Now its been stood idle for a few months seems to be acting up again. I am going to wing it at the moment, and just see how it goes.
At some point I am going to get another motor for it anyway, so will be a straight swap.
I want to strip and rebuild this motor with a BBK.
I have much plans for this bike.
bladeblaster
PostPosted: 15:01 - 01 Mar 2016    Post subject: Reply with quote
Out with the old rusty linkage bearings.
https://i491.photobucket.com/albums/rr279/bladeblaster/new%20bearing%204_zpslnz4h0ig.jpg
And in with the new
https://i491.photobucket.com/albums/rr279/bladeblaster/new%20bearing%203_zpsy1xgeopf.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/new%20bearing%202_zpsouy0m2aj.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/new%20bearing%201_zpshkaybvdu.jpg[img][/img]
thosoneill
PostPosted: 11:21 - 03 Mar 2016    Post subject: Reply with quote
Thanks mate for a decent thread - it's amazing the amount of wear and tear a motorcycle is subjected to - fantastic you have the ability to fault find and repair - I doubt any dealer could have done better - well done that man - fancy changing my belt and rollers Wink
bladeblaster
PostPosted: 09:33 - 14 Mar 2016    Post subject: Reply with quote
A very frustrating weekend on the GPZ Evil or Very Mad
The good news, the rear shock is in.
https://i491.photobucket.com/albums/rr279/bladeblaster/12814712_10153455965669013_5885533068047598212_n_zpsdtisqvx5.jpg
The bad news, I thought I had the circlips for the tie rods, but I didn't so I couldn't finish fitting it, needs circlips fitting then everything torqued up.
More good news, the front lines are fitted.
https://i491.photobucket.com/albums/rr279/bladeblaster/12186233_10153455997439013_5213086437354038805_o_zpsqtnpvuyr.jpg
The bad news, the reservoir screws were so chewed up they are unusable, so need new ones before I re-fill the system. So couldn't finish that job either.
To top it off tried starting her again, and come to the conclusion that the starter clutch really is totally shot, so the engine is going to have to come out after all. I know I knew but after the false hope it gave me early on, it feels like a bit of a kick in the balls.
1 step forward and 2 steps back, definitely a weekend where you question the sanity of owning a 30+ year old bike, and wanting to take a match to it Crying or Very sad
Just_James
PostPosted: 00:55 - 15 Mar 2016    Post subject: Reply with quote
Bit of a shitter with the starter clutch but it will be worth it in the end... easy for me to say as I'm not the one that has to do it Mr. Green
Really liking the detailed thread on this though, keep it up Thumbs Up
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
bladeblaster
PostPosted: 11:44 - 21 Mar 2016    Post subject: Reply with quote
A much more positive day on the bike yesterday.
Suspension linkage all back together with circlips, back wheel back in, rear caliper back on with new braided hose, front hoses bled.
She is now more complete than she has been in months. so next weekend I can start stripping off everything ready for the engine to come out .............. Rolling Eyes
https://i491.photobucket.com/albums/rr279/bladeblaster/aaa_zps4zdsejbf.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/aaaa_zpsxkyfjirv.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/aa_zpszwwfnmbb.jpg
bladeblaster
PostPosted: 17:07 - 31 Mar 2016    Post subject: Reply with quote
Everything stripped off ready to drop the engine out. Must resist the temptation to start buying new shiney bits that I don;t need like billet rad brackets, etc etc.
https://i491.photobucket.com/albums/rr279/bladeblaster/aaa_zpslpw2ndl3.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/aaaaa_zpsq49jit7c.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/a_zps2caetleg.jpg
bladeblaster
PostPosted: 12:02 - 08 May 2016    Post subject: Reply with quote
well after more delays, mostly due to traveling for work, the engine is finally out.
Now I need a free weekend to get stuck in to the gearbox.
https://i491.photobucket.com/albums/rr279/bladeblaster/13138882_10153594721389013_4204543917392536561_n_zpskhpjoenw.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/13177154_10153594721314013_7912014622369357687_n_zpsrn5idpi9.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/13179370_10153594721509013_9005478300331543586_n_zpszi7lltz7.jpg
The last post was made 7 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.81 - MySQL Queries: 17 - Page Size: 147.32 Kb
