Author |
Pete. |
Posted: 23:53 - 10 Feb 2016 Post subject: Anyone here run a cnc wood router? |
I need some parts cut from MDF. Should all come from half a sheet or thereabouts.
Is there any member here could cut me some bits then post them to me? ____________________ a.k.a 'Geri'
Back to top |
ride_to_die |
ride_to_die Crazy Courier
Back to top |
- Super Spammer
Back to top |
nowhere.elysium |
nowhere.elysium The Pork Lord
Posted: 19:28 - 11 Feb 2016 Post subject: |
How big are the pieces? I'm fairly close to Pete, so can get them to him without too much hassle. However, there are three things to consider:
One, the size of the machine - it's a 1200*1200 cutting bed, although I usually run it with a sacrificial bed of 900*900
Two, whether MDF is really the best material, because
Three, I've been signed of work for a month as a result of poor fume extraction from the laser cutters I also operate.
I also have a tiny baby CNC router at home (with a 4th axis spindle) that I'm in the process of retrofitting with USB-compliant control electronics, that can probably be pressed into doing small parts sooner than I'd originally planned for.
mpd72 - the only real way of getting the templates into a file that the CNC machines will understand is by measuring them, lots. Personally, I'd run with doing a crude measurement pass, blocking out the shape in some CAD software, and then refining it progressively - it means that you're guaranteed to have something to work from at all points in the transcription process.
As a final caveat to all of this, once I'm back at work, I'm trying to get them to buy a proper 3000*2000 CNC router, so it can process whole sheets in a single pass, as opposed to the limited scope I have at my disposal at the moment. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Back to top |
Pete. |
Posted: 19:55 - 11 Feb 2016 Post subject: |
Biggest piece would be 200x1100mm, so not that large or heavy. MDF because it has a good smooth finish and easy to hand-finish to shape.
I can't draw 3d models in CAD but I can in sketchup. Are they difficult to convert? ____________________ a.k.a 'Geri'
Back to top |
nowhere.elysium |
Posted: 20:10 - 11 Feb 2016 Post subject: |
Sketchup produces some really shonky 3D geometry. It'll work, if what you're after doesn't have any fine details in it, but it's the 3D equivalent of designing on the back of a napkin.
Provided you can save the 3D file as an .stl or .obj it should work fine, although I'd appreciate having the 2D CAD drawings to go with them, just in case there are any weird scaling artefacts to contend with.
What's the thickness? ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Back to top |
Pete. |
Posted: 20:30 - 11 Feb 2016 Post subject: |
12mm and 18mm I think. I can draw 2d cad just not 3d, or at least I haven't learned to yet. ____________________ a.k.a 'Geri'
Back to top |
BTTD |
BTTD World Chat Champion
Back to top |
Pete. |
Back to top |
BTTD |
Back to top |
ScottT |
ScottT Scooby Slapper
Back to top |
duhawkz |
duhawkz World Chat Champion
Back to top |
BTTD |
Back to top |
MarJay |
MarJay But it's British!
Back to top |
- Super Spammer
Posted: 11:22 - 12 Feb 2016 Post subject: |
jnw010 wrote: | That's why I asked what Pete was making.
It sounds like a somewhat complex 3D shape and its mirror image.
CNC is the way to go, especially if you're doing multiple items.
mpd72 was talking about fitting out a van. Seemed to me that if you're making full size templates that job would be quicker with a router using the templates and maybe a few jigs unless you're going full production of van conversion kits. |
The Vohringer gloss laminated boards are over £150 each and my routing skills are not all that.
I may go this route, but the Correx sheets I'm making the templates from are probably not strong enough to use as a bearing cutter template on a router.
As my conversion is based around a Shuttle, not a van, the interior shape is slightly different. Nobody yet makes DIY flat pack furniture for a Shuttle. If I can successfully create the CAD files and a set of furniture, there could be a market to knock out flat pack sets. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
Back to top |
nowhere.elysium |
Back to top |
ScottT |
Posted: 00:09 - 13 Feb 2016 Post subject: |
nowhere.elysium wrote: | Sounds like someone's nervous at having their job replaced by a machine. Protip: your dipshit lads are a problem because you didn't have the wit to filter them out when interviewing for the job. It's got buggerall to do with the progress of manufacturing techniques. |
My job isn't under threat from a machine, never will be, as for the 2 unable to change a lightbulb, it's not what they are employed to do, they do their real job well enough. But it's got everything to do with the fact that simple manual tasks are beyond far to many people these days. One of them has a wife and a kid, I asked him what happens when a light goes out at home, his reply "my dad comes and changes it"!!!
duhawkz wrote: |
Seriously
Go and buy a sheet of mdf and try cutting 20 identical complex shapes out of it by hand and see if they all turn out exactly the same. Then let me know how long it took you.
Then we'll try the same thing with a cnc machine and compare the results. |
If speed is the main issue then i agree with you, but people managed for 1000's of years to make identical items before cnc
For me it's a job satisfaction, being able to stand back and think I made that is a nice feeling, much more than thinking, well i switched the machine on!
I saw a post on another bike forum a few months ago, some bloke had restored a RD500YPVS in full Marlboro race rep colours, every single logo on the bike was painted on, every tiny detail was spot on, it must have taken him hours of careful masking, cutting, painting it looked amazing quality work.
I guess you would have just bought some stickers! |
Back to top |
Jewlio Rides Again LLB |
Jewlio Rides Again LLB World Chat Champion
Posted: 00:15 - 13 Feb 2016 Post subject: |
ScottT wrote: | nowhere.elysium wrote: | Sounds like someone's nervous at having their job replaced by a machine. Protip: your dipshit lads are a problem because you didn't have the wit to filter them out when interviewing for the job. It's got buggerall to do with the progress of manufacturing techniques. |
duhawkz wrote: |
Seriously
Depends who places a higher value on their time. ____________________ Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems |
Back to top |
Pete. |
Posted: 00:23 - 13 Feb 2016 Post subject: |
Ironic isn't it, that you're denegrating the use of technology in favour of a manual skill when the part I want to make is a casting pattern for a cast iron straight edge, which I need to hand-finish some parts flat, straight and parallel to better than a hundredth of a millimeter. I can't buy the tool I need so I'm going to have one cast for me and make it.
I have no woodworking skills to speak of and I can't afford to have that airborne sawdust in my workshop in amongst precision instruments that can register the bend in my workshop floor slab as I walk around, so I'm looking for the easiest way to get a pattern cut and a CNC router fits the bill. ____________________ a.k.a 'Geri'
Back to top |
BTTD |
Back to top |
duhawkz |
Back to top |
Pete. |
Back to top |
The last post was made 8 years, 72 days ago. Instead of replying here, would creating a new thread be more useful? |
