Author |
loply |
loply World Chat Champion
Posted: 13:56 - 27 Apr 2016 Post subject: Downshifting technique |
Hi folks,
Just looking for some advice on shifting down on track.
I've been trackdaying/racing an SV650 the last 2 years and it's something I've struggled with. I'm going fairly well with middle of the pack laptimes at club meetings.
I always was taught to blip the throttle and release the clutch between every gear, so if I'm going down 3 gears I'll quickly do this three times:-
• Pull clutch lever
• Blip throttle
• Hit gear lever
• Release clutch lever
[Repeat x2 more times]
It sounds longwinded but in reality you can do it quickly... but I'm finding when I go faster this takes too much concentration and can cause me to very the brake lever pressure when I rotate the throttle tube, meaning I only get 'full' braking after I've finished shifting. If I go in too hot I end up struggling to get it all done in time.
What does everybody else do? I'm thinking about learning to just hold the clutch in, drop all 3 gears then release the clutch smoothly with some throttle... It's hard to change habbits though.
No slipper clutch fitted. I do sometimes get a squirmy rear end going on but not too bad usually.
Would appreciate any comments. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
Back to top |
recman |
recman World Chat Champion
Back to top |
Old Git Racing |
Old Git Racing World Chat Champion
Posted: 21:26 - 27 Apr 2016 Post subject: |
Example - On Park Straight at Cadwell. 6th gear, pull clutch in at your braking point, bang it down 4 gears to 2nd as quick as you can blipping with each change. Let clutch out carefully,i.e. don't just let it go unless you are Sam Lowes and have a slipper clutch. Bet you if you do this your braking point will be less.
If you're trying to do good times on a trackday or racing you have to be aggressive, its not the road coming up to a pelican crossing.
Word of caution, you're doing quite a lot of things here at the same time - getting the braking a late ass poss, banging it down the right number of gears, blipping whilst braking and just keeping the back wheel hovering off the road, remembering to not just let the clutch go, making sure you do the line and the apex, being aware of other nutters coming up the inside who are either better or worse than you at this.
It's not as easy as many think to get it just right, The ones who do it without mistakes every corner lap after lap win or are the fastest.
OGR ____________________ 2022 Tiger Sport 660 2019 Street Twin 2003 K3 gixxer 1000 1998 Srad 600 track hack |
Back to top |
loply |
Posted: 23:15 - 27 Apr 2016 Post subject: |
Old Git, so are you saying you hold the clutch lever in for the whole time, only releasing it once you reach the final gear?
Yet you still blip the throttle for every gear you go down? ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
Back to top |
Pjay |
Pjay World Chat Champion
Back to top |
.Bishbash. |
.Bishbash. World Chat Champion
Back to top |
Old Git Racing |
Back to top |
.Bishbash. |
Posted: 07:25 - 29 Apr 2016 Post subject: |
I have never heard that technique before, certainly haven't tried it. Is this specific to V-Twins, or all bikes? ____________________ Current bike - GSX-R1000 k8 |
Back to top |
loply |
Posted: 14:08 - 29 Apr 2016 Post subject: |
Thanks old git, I'll probably give that a try next time. Something to think about. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
Back to top |
TbirdX |
TbirdX Crazy Courier
Posted: 14:53 - 29 Apr 2016 Post subject: |
2 stroke motocross method...
throttle full open...brake,throttle full closed, clutch in, stamp down gears until you hit the right gear for exit speed, when exit speed reached, dump clutch and throttle full open.
Mechanical sympathy not a big thing in motocross ____________________ VFR800X - TTR250 |
Back to top |
.Bishbash. |
Posted: 21:29 - 29 Apr 2016 Post subject: |
Seriously, someone please tell me how that even makes sense....Educate immediately ____________________ Current bike - GSX-R1000 k8 |
Back to top |
G |
G The Voice of Reason
Back to top |
Blue_SV650S |
Blue_SV650S World Chat Champion
Back to top |
The last post was made 8 years, 38 days ago. Instead of replying here, would creating a new thread be more useful? |
