Author |
mentalboy |
mentalboy World Chat Champion
Back to top |
Jay2903 |
Jay2903 Scooby Slapper
Back to top |
Jay2903 |
Back to top |
mentalboy |
Back to top |
mentalboy |
Back to top |
Jay2903 |
Back to top |
Jay2903 |
Back to top |
Jay2903 |
Back to top |
bikenut |
bikenut World Chat Champion
Back to top |
mentalboy |
Back to top |
Jay2903 |
Back to top |
bikenut |
Back to top |
mentalboy |
Back to top |
Jay2903 |
Back to top |
Jay2903 |
Back to top |
Jay2903 |
Back to top |
mentalboy |
Back to top |
Jay2903 |
Back to top |
bikenut |
Back to top |
mentalboy |
Back to top |
bikenut |
Back to top |
mentalboy |
Back to top |
Jay2903 |
Back to top |
Jay2903 |
Posted: 04:35 - 07 Dec 2016 Post subject: |
[/quote]
Valves may well clash but never 'tangle' with pistons, hence why one turns a camshaft slowly using a hand tool when one is working on the valvetrain. Turning in this fashion means that you can feel if there is contact and thus avoid damage. It does not matter if the two come in contact with each other using this method SO LONG as one is not a muppet and actually stops turning in that direction.
It doesn't matter whether it's a 4 stroke 125, a GT550 or a V8 Ford this applies to any vehicle (even better if you have a non interference head). Turning the camshaft is not the issue but the speed at which it is turned and not forcing it when there is resistance - which could mean any number of things, not just piston valve interference.
I feel that this thread is becoming derailed. My quals are more than 35 years both tinkering and being paid to tinker on engines some small (eg Stihl certified repair technician, amongst others) and some that are bloody huge or expensive, or sometimes both, but mostly bike engines. I built my first engine when I was 13 (a BSA C15 that came in a mess of boxes), I'm about to strip the heads off my 4.0l V6 SOHC Ford (see if google will tell you how many mechanics you can find that are willing to tackle that particular model!!!) and you won't find me regurgitating 2nd-hand googlefu - any OP can find that kind of info. If you look hard enough you might even find a couple of my rebuild project threads on BCF.
How about you Bikenut? Care to share your extensive mechanical background with the folks of BCF?[/quote]
wow thats quite the portfolio.
Being a 20yr old with nearly 7 years experience as a bicycle mechanic but only moderate skill in sorting carbs and electical problems learned from fixing up an old cg 125 i shall be taking your advice on board.
(however i was i did know to turn it by hand to see if pistons where hiiting valves) |
Back to top |
bikenut |
Posted: 21:33 - 07 Dec 2016 Post subject: |
how you getting on jay ?
If pistons set half way up the bores, a d one camshaft is removed, then it is safe to rotate the remaining camshaft, but do not rotate the crank in this state.
pictures equal a thousand words, hope they upload to here.
So, the picture of the valves is from a haynes gt750 manual but the proportions will be about the same for the 550.
The chain picture suggests that the cam chain may "dangle" out of harms way, but may still bunch up and/or get caught up with the primary chain, so why take the risk.
Can you rotate the cams in situ with the pistons at half stroke ?
nope, valves run real risk of "tangleing" with each other, more damage.
As you know the whole world views what seen on here.
So, with pistons are half stroke ( so no danger of valves meeting pistons, which is why I said that ), and cam chain removed from cams, choose a cam to rotate., for valve clearance measurement and possible adjustment via the under bucket shims.
The non rotating cam will have a valve open.
As the chosen cam is rotated and opens valves, eventually it will open a valve next to the non rotating cam already "open" valve.
The valves are "inclined" in the 550 and 750, as shown in the picture.
The rotating cam will be difficult to rotate in control as fighting spring pressure, and, can become uncontrollable due to "whip" ( due to the force of a closing valve spring tending to "rotate" the cam, with some force ).
The valves dont have to open much to become "TANGLED" !! with expensive results, which is why I said to remove one of the cam shafts to enable the other to be rotated safely, for valve working clearance measurement and adjustment via the under bucket shims.
Jay, set pistons at half stroke paying particular attention to the cam chain, which can be tied up out of the way, just like you did when you did the head off and on.
Select the buckets that are going to be used for say the inlet valves and place near there holes.
With only the inlet cam in situ, gather all the shims and select the thinnest 4 for temporary fitting to ascertain the correct shim size for setting the valves working clearance to spec. RECORD THE THICKNESS ETCHED ONTO THE SHIM AND TO WHICH VALVE AND BUCKET THEY ARE BEING FITTED TO.
Fit the shims, buckets and cam, take care and tighten cam caps to torque.
Now you can safely turn the cam and measure each gap RECORDING the data.
Remove cam, buckets and shims. The buckets will be refitted to the holes they have just come out of, do not mix them up !
Now you can calculate the required shim for correct valve working clearance. The 750 has quite a wide tolerance, which may be the same for the 550. Aim for the "middle" valve, 3 to 7 thou, so set to 5.
When the correct shims have been selected, keep them in order, ie valve to bucket to shim.
Next, repeat the exercise with the exhaust cam etc..
This is the quickest way for your predicament.
When entirely happy, refit everything being particular about the cam chain and its proper fit on the crank, the "sag" between cam sprockets and the tensioner.
If the cams are timed correctly it is safe to turn the crank with the cam cover ( it has a between cam sprocket rubber "chain sag" slipper ) off, but only in proper direction of rotation and very very slowly. Valve clearances can be measured and recorded in this state.
If yours has the cross wedge cam chain tensioner, you will have noticed it auto adjust when the cam cover was taken off. You will know that the tensioner has to be removed and "cocked" before cam cover is refitted, then "released" to auto adjust when the cam cover is fitted properly.
Hope this helps. ____________________ nuts about bikes |
Back to top |
The last post was made 7 years, 141 days ago. Instead of replying here, would creating a new thread be more useful? |
