Author |
WD Forte |
WD Forte World Chat Champion
Posted: 01:51 - 20 Mar 2017 Post subject: This week I are mostly been making grommets |
Whilst removing the side panels on the old thing I was reminded the few remaining grommets were hard and knackered
and some remnants held in with hot glue.
https://i.imgur.com/zTsDq3e.jpg
The only fully intact one was hard and cracking so just for the hell of it I decided to have a go at making some new ones
from silicone.
Well silicone with baking powder and carbon black to be precise
Baking power to accelerate the cure and carbon black for well... blackness.
Perhaps they are still available from say CMSNL, but I fancied having a go at some DIY ones anyway
Taking measurements from the last intact one, I milled out some 10mm cast acrylic I had knocking about
as a mould
( TIP: Cast acrylic chips out nicely in the mill, extruded acrylic is a friggin nightmare as it melts easily and can clog the bit)
https://i.imgur.com/vTfKx44.jpg
I decided to make the lower part of the mould out of a lump of pine and
two short peices of 10mm tube to help keep it registered
I couldn't be arsed to mill the pins to a taper so stepped them and later rounded them off with
sandpaper
https://i.imgur.com/u1xILJd.jpg
I used linseed oil on the wood cos I had some anyway and thought it might act as a mould release
https://i.imgur.com/KcY6Xip.jpg
Right, time to give it a go.
I donned the old marigolds and mixed up the jollop and squeegee'd it in to the mould
It went off in about an hour, ( more baking powder quicker curing BTW)
https://i.imgur.com/aTQ1qqb.jpg
They didnt stick to the perspex much or the wood at all and were relatively easy to remove
https://i.imgur.com/klvc7YS.jpg
the pics flatter, they're from test 1
I didn't get in all the underneath corners so it was a partial success
next I tried filling the low section first then fitting it to the jig but found this tended to lift the
silcione as it was pressed down and cause voids
borrux!
later I used just the acrylic part and filled it with silcone then used a pencil dipped in linseed oil
to form the tapered hole
This caused a slight swelling on top due to the displaced silcone but that didn't bother me
as the upper and lower 'lips' were perfectly formed.
I'd stopped taking pic by now but machined out the perspex so the lower lip was fatter and wider
and the upper one was wider as well
Silicone is softer than rubber and if too thin would push up out of the side panel too easily
fattening them up a bit solved this
Anyway I now have a complete set of side panel wubbers
https://i.imgur.com/wBmZtnc.jpg
https://i.imgur.com/UcbgahV.jpg ____________________ bikers smell of wee |
Back to top |
ride_to_die |
ride_to_die Crazy Courier
Posted: 12:43 - 20 Mar 2017 Post subject: |
Excellent work ____________________ I'm not here for a long time, I'm here for a good time. |
Back to top |
davethekwak |
davethekwak Nitrous Nuisance
Posted: 12:53 - 20 Mar 2017 Post subject: |
Nice one.
Some may (will) say why go to all that bother. Some just don't understand the fun to be had trying stuff ____________________ ZX6R G2 (1999) & ZX6R F2 (1996). I like ZX6! |
Back to top |
There is a gap of 2 years, 205 days between these two posts... |
WD Forte |
Back to top |
Easy-X |
Easy-X Super Spammer
Posted: 20:57 - 11 Oct 2019 Post subject: |
A gold star for a thread resurrection that was worth reading for a change ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
WD Forte |
Back to top |
Islander |
Islander World Chat Champion
Posted: 21:28 - 11 Oct 2019 Post subject: |
You do know you could have bought them for pennies locally, don't you? |
Back to top |
UnknownStuntm... |
UnknownStuntm... World Chat Champion
Back to top |
pepperami |
pepperami Super Spammer
Back to top |
WD Forte |
Posted: 17:43 - 14 Oct 2019 Post subject: |
It's currently putting the lotion on its skin or else it gets the hose again
https://imgur.com/u3rtrH1.jpg ____________________ bikers smell of wee |
Back to top |
The last post was made 4 years, 222 days ago. Instead of replying here, would creating a new thread be more useful? |
