Author |
jimster |
jimster Spanner Monkey
Back to top |
WD Forte |
WD Forte World Chat Champion
Back to top |
Bhud |
Bhud World Chat Champion
Back to top |
Polarbear |
Polarbear Super Spammer
Posted: 03:32 - 18 Nov 2023 Post subject: |
I think thats doable if you have a nice warm garage/kitchen/livingroom to work in for the next six months. If you know it was good before it was left to stand you won't have too many horrible surprises in store.
I wouldn't put it back to standard but do something looney with it, at least cosmetically. It's not like it will ever be worth much as a standard divvy.
Perhaps you could buck the trend and make a hipster bike too good for the 'Ebays finest' thread. ____________________ Triumph Trophy Launch Edition |
Back to top |
Pete. |
Posted: 08:07 - 18 Nov 2023 Post subject: |
Tap it lightly on a non-rusty part and listen to the noise it makes - dink, dink ,dink. Go around the rusty areas and if the sound changes from dink to donk (or crunch), or if the small item you're using for tapping stops bouncing off the surface, the steel has lost it's strength.
Being a swingarm it'll be rusting from the inside as well as the outside so son't go by visual clues alone. ____________________ a.k.a 'Geri'
Back to top |
Easy-X |
Easy-X Super Spammer
Back to top |
MCN |
MCN Super Spammer
Back to top |
slowasyoulike |
slowasyoulike Scooby Slapper
Back to top |
doggone |
doggone World Chat Champion
Back to top |
stinkwheel |
Posted: 17:17 - 19 Nov 2023 Post subject: |
The hardest bit will be removing the exhaust and I'd say the collets look pretty shot, Probably need replacing.
Harpic X10 will deal with the exhaust rust (effectively muriatic/hydrochloric acid gel).
If you can get the shock apart, the spring could most likely be repainted or replaced.
Amazing what white vinegar will do for removing rust. Or a good soak in something like deox-c. If it was me, I'd get the swingarm off, knock the loose shit off with a wire weel then give it 3 days to a week in white vinegar and see where you're at.
The electrolysis method is also pretty effective.
With small fittings like nuts and bolts, I'll often soak them in vinegar to get rid of the rust then black them by heating them up and wiping over with an oily rag. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
jaffa90 |
jaffa90 World Chat Champion
Posted: 18:58 - 19 Nov 2023 Post subject: |
Go and get married and have 3 kids for an easier life. |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
jeremyr62 |
jeremyr62 Borekit Bruiser
Back to top |
WD Forte |
Back to top |
Bhud |
Back to top |
megaross |
megaross Borekit Bruiser
Back to top |
