Age old Question - DI or Demin.
DaddyStu
PostPosted: 19:08 - 16 Apr 2024    Post subject: Age old Question - DI or Demin. Reply with quote
If using a concentrated coolant do you dilute with DI or demin water?
My tap water is hard in these parts. Scales up my kettle almost every week.
I have a good supply of DI water but it can strip ions from metals.
Daddystu
Zontes 125-G1 (part-ex'd). Yamaha Tracer 700.
PostPosted: 19:47 - 16 Apr 2024    Post subject: Reply with quote
Not when it gets mixed with inhibitor it wont. Used to be sodium nitrite in coolant, not sure what they use currently but it'll be a soluable salt of some sort. Suffice to say, it will be thoroughly re-ionised as soon as it hits the coolant.
I suppose in that respect DI would be better because it'll only have the ions you want in it.
PostPosted: 19:49 - 16 Apr 2024    Post subject: Reply with quote
Also, if you want distilled, the stuff that comes out of condensing tumble driers and the ice inside your freezer are both distilled water.
DaddyStu
PostPosted: 23:32 - 16 Apr 2024    Post subject: Reply with quote
Yes, although said ions will then be bound to another molecule so unavailable to carry out their protective role any further.
Might add 10% filtered tap water to my 1L DI - ionise it up a little.
Daddystu
PostPosted: 07:22 - 17 Apr 2024    Post subject: Reply with quote
Pretty sure it's fully aqueous out of the bottle.
A100man
PostPosted: 08:01 - 17 Apr 2024    Post subject: Re: Age old Question - DI or Demin. Reply with quote
Your kettle is filled AND boiled dozens of times a week. Your coolant is filled maybe once a year. Just use tap water.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 16 - Page Size: 51.28 Kb
