Author |
Northern Monkey |
Northern Monkey World Chat Champion
Back to top |
stinkwheel |
Posted: 13:04 - 22 May 2024 Post subject: |
Not readily. It's a light for being seen by other people, not for seeing with.
You'd probably need to convert to DC only and use an LED to get any significantly improved lighting output.
Otherwise it's just using the highest quality standard wattage bulb you can find. As I remember they have a 25/25w P36d tungsten filament as standard. They do a halogen upgrade with the same base which may be worth a try, should be a good bit brighter (or at least whiter).
Don't be tempted to up the wattage, it wont help. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
WD Forte |
WD Forte World Chat Champion
Back to top |
stinkwheel |
Posted: 14:50 - 22 May 2024 Post subject: |
Mrs stinkwheel has a YB. It's got one of those crescent shaped split single lighting coils where it taps off half the output for AC lighting with a ballast resistor and half rectifies the remainder through one of those fan-shaped diodes to charge the battery. No regulator at all. Seperate coil for the spark.
The headlight is truly crap. It also doesn't really charge the battery effectively and either kills a battery or a diode roughly every 6 months.
I stuck a C90 reg/rec on her one so now it just fails to effectively charge the battery without actually killing it. We decided the best solution to the lighting was to just not ride it in the dark.
If riding it in the dark was going to be a thing, I'd re-jig it so all the output went into the battery via the honda reg/rec, replace all the lighting with LED and rewire the headlamp switch so that was powered from the battery. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
A100man |
A100man World Chat Champion
Posted: 22:26 - 22 May 2024 Post subject: |
I've saved this one in my ebay watch list for the A100(suzuki yb equivalent), not 100% it works on AC like the filament bulb tho'
https://www.ebay.co.uk/itm/404511899614 ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
Back to top |
stinkwheel |
Posted: 23:00 - 22 May 2024 Post subject: |
I tried a positive earth LED headlamp bulb on a bike with regulated AC lighting. It lit up with the power of the sun for around half a second. Luckily it was a cheap ebay one because I had a suspicion that might happen.
I am using them successfully on Mrs stinkwheels Honda Wave but it has halfwave rectified direct lighting rather than full AC, so I'd suggest a diode would be required at an absolute minimum to make one work on a YB100. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
Easy-X |
Easy-X Super Spammer
Back to top |
Northern Monkey |
Back to top |
Northern Monkey |
Back to top |
stinkwheel |
Back to top |
