Decent trail bike mirror reccomendations?
PostPosted: 19:47 - 10 Sep 2007    Post subject: Decent trail bike mirror reccomendations? Reply with quote
The mirrors on my 404 are as poor as I expected they would be.
Can anyone recommend any decent ones?
I was wondering about the style that have a fairly wide-angled mirror mounted directly on the handle bar. Does anyone know where to get these?
I have ridden plenty of bikes in the past fine without mirrors, however for various reasons I think they’d be quite useful now.
byke95
PostPosted: 21:17 - 10 Sep 2007    Post subject: Reply with quote
Motrax bar end mirror(s)? £30-35...
I've had them fitted to supermotos and nakeds and really do like them - the sacrifice of having them stick out a bit (meaning you're a bit wider) is more than made up by the superb view - I only fit the right hand mirror these days and can see everything behind me including my tail unit! They can fit into and around 7/8 bars.
[They can 'blur' under heavy acceleration but many bike mirrors suffer from that...if you were to get them be sure to remove the mirrors and put some silicon behind it, they're known to vibrate out]
PostPosted: 21:32 - 10 Sep 2007    Post subject: Reply with quote
I put GPz305 mirrors on my MZ Baghira. They are rectangular ones that mount on the bars and had a good, wide field of view. They also have reasonably short stems and so remain inboard of the bar-ends meaning they don't hit the ground if you drop the bike.
https://i48.photobucket.com/albums/f216/stinkwheel/Glentrool_2005_15.jpg
PostPosted: 23:05 - 10 Sep 2007    Post subject: Reply with quote
When you say around, could they be fitted inside the grips instead?
I never liked the look of bar end mirrors, but that doesn't bother me that much.
Definitely wouldn't be very good off roading sticking out the side, but should be fine on the road.
Stinkwheel - ones I have at the moment are similar dimensions, but too light and don't have enough adjustment. Those do seem to have a weighted bit lower down which should help damp vibrations.
I had similar on my original KLR650 mirror and it seemed to work much better than cheap aftermarket ones.
I presume the ones on the CCM, if they're original, were chosen for weight especially as it's the 'enduro' version (119kg claimed dry weight is pretty decent for what it is).
PostPosted: 00:15 - 11 Sep 2007    Post subject: Reply with quote
They were pretty solid items it must be said, they had a dirty great threaded lump at the base where they screw into the clamps and the balljoint meant you could point them pretty much anywhere you wanted.
There is also the plus point that GPz305s generally blew up WAY before the owner had time to crash them so there should be loads of good mirrors floating about in breakers yards.
PostPosted: 00:41 - 11 Sep 2007    Post subject: Reply with quote
Sounds very much like my KLR mirror.
I had wondered about making a weighted block with a thread to screw the mirrors in that would bolt into the normal thread for the mirror.
Idea is to damp out vibrations.
byke95
PostPosted: 21:40 - 13 Sep 2007    Post subject: Reply with quote
No underneath the grips as such...they can either be used as the bar end (the mirrors come clamped to an attachment that slides into the handlebar, much the same as other bar ends) or (by removing 'attachment') clamped to another bar end e.g. renthal.
PostPosted: 21:45 - 13 Sep 2007    Post subject: Reply with quote
Ah, ta.
I ended up getting a Zefal Spy Mirror which is doing the job quite well, so far.
byke95
PostPosted: 22:14 - 13 Sep 2007    Post subject: Reply with quote
Looks good, and much less than the likes of Motrax and Oberon. Does it suffer from much vibration under acceleration?
PostPosted: 22:16 - 13 Sep 2007    Post subject: Reply with quote
Unbreakable chromo-plastic construction.
That's quite a rash statement in my oppinion.
The last post was made 16 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 66.52 Kb
