DT 125 brake light...
Mr.Ormes
PostPosted: 12:15 - 23 Mar 2011    Post subject: DT 125 brake light... Reply with quote
Hi all, As I have done an electrical engineering apprenticeship I am really embarrased by having to ask this, but I fear its something i have overlooked. 2 years ago i compleatley dismantled my DT and never got round to putting it back together untill a few weeks ago. all back together now and i had to re-wire some of the loom due to corroded conections etc. I thought all was working fine untill i just went and booked an MOT.....
I put a new bulb in my rear light to notice that one of the filaments is constantly on (think its the brake light), and makes no change when i press either front or back brake. checked connections and earths but I'm sure theres something im not thinking of.
Thanks in advance.
Edit: I just remembered I had to use a different front light swich as the last one broke, I will check that first.
Edit2: I just checked the front brake swich, that was not seated correctly so that solved that problem, BUT. the second problem is when i turn my headlights on, the rear light doesnt light up. Middle Finger
DT 125 1995
Thumpstar 120
Suzuki ZR 50
jimbothe
PostPosted: 12:30 - 23 Mar 2011    Post subject: Reply with quote
R.E. your edit 2
Hi don't know if this helps you but I had the same problem on a DR650rs
Turned out to be a loose connection in the switchgear.
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
Mr.Ormes
PostPosted: 13:34 - 23 Mar 2011    Post subject: Reply with quote
1samarg wrote:
R.E. your edit 2
Checked that and it was all fine,m Thanks though!
However, I have solved it. somehow the lrear casing was affecting the bulb, when the casing was off the light worked, fixed this now though, think it was on slightly wrong!!
DT 125 1995
Thumpstar 120
Suzuki ZR 50
jimbothe
PostPosted: 14:34 - 23 Mar 2011    Post subject: Reply with quote
Glad you got it sorted Thumbs Up
The last post was made 13 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.33 - MySQL Queries: 16 - Page Size: 42.7 Kb
