98 Db trackday with aftermarket cans?
Dr. DaveJPS
PostPosted: 19:49 - 05 Jul 2014    Post subject: 98 Db trackday with aftermarket cans? Reply with quote
Hi All,
I'm considering attempting my first trackday later this month, however I've recently had to change to a set of aftermarket exhausts (as the Y-piece cracked). I've kept the baffles in, but i'm worried it won't past the noise test... so i have a couple of questions:
a) what happens if you fail a noise test, do you get the money refunded?
b) the pipes are meant to be road legal and comply with all the EU directives, what's the reckoning they'll pass a 98Db limit?
c) has anyone tested their own bike and if so how have you tested it (my phone tops out at 84Db)
Thanks for your help.
(FYI the bike is a KTM 950SM with Leo Vince carbon exhausts)
www.davejps.com
P.
PostPosted: 08:25 - 07 Jul 2014    Post subject: Re: 98 Db trackday with aftermarket cans? Reply with quote
You won't get your money back.
Don't need to be road legal as its not a road, but some race cans are far too loud.
I'm on track Wednesday with 2 bikes, both will get checked but our limit is like 102 and both are baffled, I'd be wary of a 950 twin with after market cans, it is likely to exceed such a low limit.
Fowlersrs
PostPosted: 08:57 - 07 Jul 2014    Post subject: Re: 98 Db trackday with aftermarket cans? Reply with quote
What exhaust setup is on the daytona bud? I've got standard setup on mine ATM but the headers have been decatted and had the exup removed, even this I'm concerned won't meet a 102 limit!
P.
PostPosted: 09:25 - 07 Jul 2014    Post subject: Reply with quote
Scorpion can, unsure if its a full system but definitely can, which is loud but will pass a piece of piss.
Dr. DaveJPS
PostPosted: 13:11 - 07 Jul 2014    Post subject: Re: 98 Db trackday with aftermarket cans? Reply with quote
Cheers Paddy, that's what I suspected.... I'm going to borrow a sound tester from work and see what I get!
www.davejps.com
Llama-Farmer
PostPosted: 13:40 - 08 Jul 2014    Post subject: Reply with quote
You won't get money back, you'll just get told sorry.
Not only do you have to do stationary ACU noise limit, but they have trackside ride-by limits and if you're too loud on those they'll pull you back in too.
Usually you can buy additional baffles/packing on the day to try quiet it down. Warm engine/exhaust can sometimes make it a bit quieter too.
Mine when cold at 5000 rpm reads 97db on my phone, but don't know how accurate that is. And as an IL4 it gets tested at 7000 I think anyway. Should be under the 102dB of most days I plan on doing.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
PostPosted: 15:08 - 08 Jul 2014    Post subject: Reply with quote
Testing revs depends on cc and number of cylinders. My 954 gets tested at 5k for instance, whereas my R6 was tested higher than that.
Slacker24seve...
PostPosted: 17:22 - 08 Jul 2014    Post subject: Reply with quote
Taking the baffle out and lock wiring steel wool to it takes a few dbs off, from experience.
Banger rallies are ace
Llama-Farmer
PostPosted: 22:51 - 08 Jul 2014    Post subject: Reply with quote
Should have clarified by saying IL4 600.
Slacker24seve...
PostPosted: 07:29 - 09 Jul 2014    Post subject: Re: 98 Db trackday with aftermarket cans? Reply with quote
If it's a 13> with the short exhaust, Castle Coombe advise on their website that it may not pass as stock.
If it's an 06-12 I use my standard can on trackdays and it's never even been tested with FE, Phil Bevan or No Limits.
P.
PostPosted: 12:31 - 09 Jul 2014    Post subject: Reply with quote
At Brands now. The daytona was 101, the sv was 98db?
PostPosted: 16:09 - 09 Jul 2014    Post subject: Reply with quote
If you want to test it yourself remember that there are a couple of different 'scales' for decibels. Make sure you get a noise test meter that uses the appropriate one (ie, dba or dbc). The difference is (I think, hopefully someone can give more details) how they bias the levels of different frequencies.
map
Mr Calendar
PostPosted: 16:19 - 09 Jul 2014    Post subject: Reply with quote
Isn't there a few iPhone/Android apps that show/measure noise decibel scale?
Would that be good enough ballpark to relieve any worries (or confirm them)?
Llama-Farmer
PostPosted: 00:33 - 10 Jul 2014    Post subject: Reply with quote
"Decibel" on the iOS app store is pretty good.
I meant to test the reading on my friends SV650 race bike when he was getting it officially noise tested, and compare readings from my phone with the reading from the calibrated meter, but by the time I got my phone out he was already done Laughing
Dr. DaveJPS
PostPosted: 13:08 - 28 Jul 2014    Post subject: Reply with quote
The issue is most of them run through the phone microphone which is normally geared to clip out at 80db.
In the long run I decided against the track day, mainly as I don't have a tacho (950 sm's were never fitted with them)
www.davejps.com
P.
PostPosted: 13:38 - 28 Jul 2014    Post subject: Reply with quote
Such fanny Mr. Green
Just rev it a little, say no rev counter, can't be that loud etc etc.
You'll be gravy, come to Brands Wink
Bendy
Mrs Sensible
PostPosted: 13:50 - 28 Jul 2014    Post subject: Reply with quote
Paddy. wrote:
The daytona was 101
The last time I had that bike tested it was 103 one day and 105 the next. Consecutive days at Cadwell with the same testing gear and the same tester. So the noise test seems to involve sticking you finger in the air and guessing.
P.
PostPosted: 14:22 - 28 Jul 2014    Post subject: Reply with quote
Bendy wrote:
Paddy. wrote:
The daytona was 101
Laughing I'm assuming it is just a wild stab at it most days.
PostPosted: 19:49 - 28 Jul 2014    Post subject: Reply with quote
Can also vary dramatically when someone near by decides to rev their bike when yours is being tested.
Fizzer Thou
PostPosted: 10:08 - 08 Aug 2014    Post subject: Reply with quote
I know that the ACU have a preferred method of noise testing but found this instead which I thought was useful when comparing different bikes
https://www.msvtrackdays.com/bike-testing-noise-limits
Always have a 'Plan B'
Diggs
PostPosted: 17:39 - 17 Aug 2014    Post subject: Reply with quote
My experience here is that scrutineers apply a bit of leeway depending on the bike and punter. I turned up to a Cadwell trackday 3 years ago with a Gixxer 750 that produced 108db. The limit was 105db, but they let me through because it was an old bike (1991) and I am an old giffer (45 at he time). The rationale was that a coffin-dodger on a bike that really should be in a museum wouldn't rev high enough on the track to exceed the db limit...
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
NooBish-AbbZ
PostPosted: 08:39 - 24 Aug 2014    Post subject: Reply with quote
I was looking at a website last night and Croft Circuit which isn't too far from me has a noise restriction of 88Db!?!? My music is louder than that when I'm sat in my room. Disclaimer - Even when it's not particularly loud
SV650S - Feb '14-March '19
XJ6N- Apr '19 -Present
thomp1983
PostPosted: 01:58 - 19 Sep 2014    Post subject: Reply with quote
just pop to your local track when there's something on and they'll happily check for you aslong as iit's not a driveby only circuit like Donnington. my 916 did 104db at cadwell with 50mm open cans and link pipe
Blue_SV650S
PostPosted: 14:04 - 03 Nov 2014    Post subject: Reply with quote
Big pot engines (singles and twins) are always going to struggle on a noise test!
Remember db is on a logarithmic scale, so 99db isn't just 10% louder than 90db!
The last post was made 9 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.28 - MySQL Queries: 16 - Page Size: 132.26 Kb
