alt tab Nitrous Nuisance
Posted: 20:14 - 15 Nov 2014 Post subject: Tidying up my tail (Kind of) |
Decided to see what I could do to tidy up my number plate situation, as it's all rather bloated and excessively heavy. With some top advice from Marmalade earlier in the day, I decided to make a start when I got home. Here's what I've done so far (Will update once I do more)
https://s28.postimg.org/tisxvgcr1/2014_11_15_18_01_37.jpg
The aim is to remove a section from the bottom of the rear light, so it emits white light directly below, meaning I can remove the big unit, and shift the number plate up.
https://s28.postimg.org/cjjzg71jh/2014_11_15_18_01_43.jpg
From crafting knife, to pocket knife, to drilling and then hack sawing, I slowly got to the point where I removed the section needed.
https://s28.postimg.org/gddfpcivh/2014_11_15_18_21_45.jpg
This is the result after filing down with metal files. I then keyed the surface with some 60 grit sandpaper.
https://s28.postimg.org/s17hjw80d/2014_11_15_18_27_07.jpg
After applying a generous bead of adhesive, I placed a piece of clear plastic over the hole.
https://s28.postimg.org/9wzvliky5/2014_11_15_18_27_22.jpg
This is where I sourced the plastic from, an empty craft knife packet!
https://s28.postimg.org/psopotbil/2014_11_15_18_27_41.jpg
This is the size of the piece I managed to get out before filing.
https://s28.postimg.org/dzvhyc4gd/2014_11_15_18_53_31.jpg
Here you can see the light that's being emitted downward by the window I made.
https://s28.postimg.org/myq5p3yq5/2014_11_15_18_53_38.jpg
Another shot of the same.
https://s28.postimg.org/47o8ey45p/2014_11_15_18_53_47.jpg
And an upward shot of the window. I may well play with the reflector unit so the black shadow isn't there, unsure yet |
