Suzuki GSXR 600 1998 (No electrical power at all)
N345H
PostPosted: 20:03 - 19 Sep 2015    Post subject: Suzuki GSXR 600 1998 (No electrical power at all) Reply with quote
Ok, bike has been running perfectly. I got home and the wife wanted to "turn the bike around" so stupidly I let her. As she was turning at about 1mph the bike fell on the right side. It was on the ground for less than 1 minute but now, there is no electrical power what so ever, zilch.
Any sugestions besides divorce? Sick
Thanks
mudcow007
PostPosted: 20:24 - 19 Sep 2015    Post subject: Reply with quote
kill switch?
fuse by the starter?
check all other fuses too
battery connected?
RhynoCZ
PostPosted: 20:49 - 19 Sep 2015    Post subject: Reply with quote
As I know Suzuki, take the driver's seat off and check everything is connected under there. I helped a lad with a SV650 last year, the wiring under the seat was a joke, and one connector shook out of it's socket.
He didn't even have to drop it to get no power, in the ON key position. Thumbs Up
EDIT: I think it was the wire to the main 30A fuse, but not sure. It should be near the battery. Thumbs Up
N345H
PostPosted: 21:06 - 19 Sep 2015    Post subject: Reply with quote
Thanks for the replies.
I will have a thorough check over tomorrow when it's day light.
Thanks again
Major Doss
PostPosted: 03:47 - 20 Sep 2015    Post subject: Reply with quote
If this model is fitted with a 'tip over' sensor, they are filled with the grease that is missing from everywhere else that actually needs it. Clean/reset/or remove. Thumbs Up
Pete.
PostPosted: 07:12 - 20 Sep 2015    Post subject: Reply with quote
The tip-over only stops the engine, doesn't cut power to the bike.
a.k.a 'Geri'
N345H
PostPosted: 11:10 - 20 Sep 2015    Post subject: Reply with quote
Ok, so, bike partialy stripped this morning. There are no obvious "loose" wires. I have checked that the battery is correctly fitted, all fuses are correct and not blown and as far as I can see no loose connections.
However, on further investigation, when turning my key to "On" I can hear a clicking noise coming from, what I presume to be the "Turn Signal Relay". Would this cause No Power?
Many thanks
Update
*Took out turn signal relay, give it a friendly tap, replaced it and I got "some" power to the dash then went dead again*
RhynoCZ
PostPosted: 11:37 - 20 Sep 2015    Post subject: Reply with quote
That is odd, was the wiring factory stock, before it happened?
N345H
PostPosted: 12:18 - 20 Sep 2015    Post subject: Reply with quote
Yes, everything is stock
mudcow007
PostPosted: 12:25 - 20 Sep 2015    Post subject: Reply with quote
look for any "cut" wires...
i was suffering form electrical issues the other week, turned out my tank had cut into the main loom an was shorting its self out
if it was a short, i would expect you to be popping fuses though
RhynoCZ
Well, then I'd just disconnect every wire and clean the connectors properly. If that won't help, then I'd check the whole frame and check the earth points are intact. I'd also check if I get DC current somewhere else but on the battery terminals. All that, knowing the fuses and battery are alright.
This must be something silly, I can't imagine dropping a motorcycle would damage something essential. Confused
Did you find the main fuse? It should be 30A, not sure, it's the one right before the starter solenoid. That's the fuse that lets the current from the battery to your whole motorcycle. Disconnect the connector and fuse and clean it there. I could as simple as that.
This is where the main fuse is (very close to the battery, since there's very high Amperage during the starting procedure): If you get DC current past this point, move on, and on and on, until you get to the ignition switch barrel, where a loose wire could also occur.
https://i.ebayimg.com/00/s/MTIwMFgxNjAw/$T2eC16d,!zcE9s4g3h-5BQ6JhGU9Nw~~60_35.JPG
N345H
PostPosted: 13:00 - 20 Sep 2015    Post subject: Reply with quote
Right, problem solved. I semi took the left side fairing off so I could get inside and look at the wireing running down there. Loose conection.
Something so small took nearly 2 hours + to rectify. Still, time for me to get out today before the rain kicks in.
Thanks ever so much for your help and input Thumbs Up
RhynoCZ
PostPosted: 15:03 - 20 Sep 2015    Post subject: Reply with quote
I told you, it was gonna be a silly thing. Thumbs Up
The last post was made 8 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.14 - MySQL Queries: 16 - Page Size: 79.45 Kb
