speedy |
speedy Scooby Slapper
Iain. |
Iain. Could Be A Chat Bot
chris-red |
Posted: 17:57 - 10 Mar 2015 Post subject: |
YEIS
Had it on my RXS ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
Iain. |
STONEY! |
STONEY! Brolly Dolly
evoboy |
evoboy World Chat Champion
Posted: 23:50 - 17 Mar 2015 Post subject: |
I just purchased an Aprilia Rally for £50.
Minarelli AC engine.
Watch this space....
____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
Iain. |
Posted: 10:35 - 18 Mar 2015 Post subject: |
Excellent
Engine came out last night, new top end was fitted, new manifolds fitted and all back in without any major hassle. Popped the 21mm carb back on to check it'd fire and it runs with no greif, I'll be fitting the giant carb tonight, swapping rollers and removing the clutch weights to get the latest possible engagement.
Should be good, it certainly felt stronger from the two second blast up the ramp I gave it - shame the phone had died because the port work on the Stage 6 cylinder is insane compared to the Athena cylinder i was running. Here's a google pic of the same cylinder;
https://img34.olx.pl/images_tablicapl/195950513_3_644x461_cylinder-stage6-racing-mk2-minarelli-12mm-port-ac-czesci-motocyklowe.jpg
Iain. |
Posted: 03:00 - 19 Mar 2015 Post subject: |
Well...it starts. And runs.
https://i.imgur.com/rVgD4gS.jpg
https://youtu.be/Uoe871JcQYo
Load of used ped go faster bits listed in the for sale section if anyones interested in the old setup or bits of it.
Need to tweak transmission tomorrow and try and get it booked in at Slipstream to get the fuelling set up.
Can't wait to ride it. |
Triumph1300 |
Triumph1300 Nova Slayer
Posted: 14:41 - 26 Mar 2015 Post subject: |
Ands what's happened then? ____________________ BWJ
Back on a BMW R80RT
Punctuation - the difference between knowing your shit, and knowing you're shit |
Iain. |
Pol Anorl |
Pol Anorl Banned
Posted: 01:03 - 29 Mar 2015 Post subject: |
well? ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
Iain. |
CaNsA |
CaNsA Super Spammer
Iain. |
Iain. |
Pol Anorl |
Pol Anorl Banned
Posted: 15:54 - 01 Apr 2015 Post subject: |
pics of lady friend? ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
Iain. |
Posted: 10:12 - 17 Apr 2015 Post subject: |
Newfound powers have caused the final drive/gearbox to shit itself.
Suspect a bearings partially failed as I'm down on top speed slightly (2-5mph) & have oil pissing out all over.
If anyones got part number S6-2019501P kicking about or knows a UK supplier I'd be most grateful. Meantime I've ordered a set of seals, a gearbox gasket, the air filter that'll hopefully solve my weird fuelling issues & a CDI unit with a different timing curve on it as the original unit isn't really designed to operate past about 8,000 rpm and the motor idles around 1500-2000, the clutch doesn't engage till 7,500 and once its rolling the revs are up over 10,000rpm
Plan is now to fix gearbox, fit filter, check fuelling, and whack some even lighter rollers in it to see what happens. I'm also going to take a file to the inlet manifold and port it a bit as theres a good 2mm step on the manifold thats not going to do it any favours. Pics as soon as I can get it on the bench. |
Iain. |
Posted: 15:39 - 20 Apr 2015 Post subject: |
CDI diddn't work.
Seemed to rev limit or detonate like fuck at about 9k. Very strange, need to call pedparts technical and find out whats up with that. Soon as the old unit was plugged back in, no problems. Filter fitted, however needed more body & frame mods to make it fit in the form of me hacksawing the pillion footrest and part of the bellypan completely off.
https://i.imgur.com/Ovc2Mg0.jpg
Needs the transmission seals replacing and then a final max speed run before sale, assuming I actually get any bids from one of the 22 watchers |
Iain. |
Posted: 13:34 - 23 Apr 2015 Post subject: |
The last post was made 9 years, 50 days ago. Instead of replying here, would creating a new thread be more useful? |
