DuNnInG_2K5 |
DuNnInG_2K5 Nova Slayer
jayjayspeedfi... |
jayjayspeedfi... Derestricted Danger
sagiliam |
sagiliam Could Be A Chat Bot
GeorgeCBR |
GeorgeCBR Scooby Slapper
andys675 |
andys675 World Chat Champion
mattsprattuk |
mattsprattuk Super Spammer
Posted: 00:42 - 30 Apr 2007 Post subject: |
i think he's one of the 'if it sounds good then it must be fast' crowd
the kind that drive 0.6 litre 2cv's with baked bean cans welded to them ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
mattgirv |
mattgirv Trackday Trickster
Posted: 01:15 - 30 Apr 2007 Post subject: |
Yeah a friend of mine took a saw to the end of his exhaust. It is a tad louder.... Apparently it now reaches 150mph, though there are no clocks. Go figure |
mattsprattuk |
Posted: 03:06 - 30 Apr 2007 Post subject: |
mph is meters per hour in his case right? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
mattgirv |
Posted: 04:11 - 30 Apr 2007 Post subject: |
Nah in all fairness it is a 600, a CBF600 to be precise, but it is still fairly ridiculous |
jayjayspeedfi... |
Sean101 |
Sean101 L Plate Warrior
Sean101 |
truslack |
truslack World Chat Champion
Sean101 |
truslack |
Sean101 |
Catalyst |
Catalyst World Chat Champion
Posted: 12:57 - 28 May 2007 Post subject: |
why buy a sport exhaust with restrictors in?!??! The whole point of buying an exhaust is to get one without them in, hahahahaah ____________________ |--Previous--|:2007 Aprilia SX50...--Current--|: 2007 Kawasaki ER-6N
SlimRick - I can cook really well - but it's a useless skill, as I'm not a woman and it's their fucking job! |
Sean101 |
ms51ves3 |
ms51ves3 Super Spammer
There is a gap of 7 years, 319 days between these two posts... |
Liam_K |
Liam_K L Plate Warrior
Posted: 11:01 - 21 Apr 2015 Post subject: Reversing the restriction.. |
Hey dude...
You know what you are talking about so here goes. I bought a bike two years ago here in Spain, a 2004 Speedfight 2 LC and it was derestricted. All good except now I have the national bike test and it is going to fail. I got the plate that was taken out of the variator kit, refitted it and while the top speed is less now (60km from 90km) the acceleration seems to be almost quicker to me and I guess that it is still too fast for 49cc. Having read your post, I see that the previous owner chopped the exhaust so that explains why it is still too quick. Is there anything I can do short of buying a new exhaust?
Thing that makes me wonder is...he obviouisly did this years ago and it passed numerous tests since then, so how was that? Is it ok for the 49cc level with just the polate back in and the exhaust still hacked?
One more thing: I didn´t change the variator rollers. Should I, and which ones will slow it down a bit?
Thank you very much... andys675 wrote: | ok, i'm gonna post this so you don't screw it up because you're going to mess with it anyway aren't you?
if you remove the washer from the variator all you will do is derestrict the drive train, not the whole bike, therefore your engine will not rev higher this only allows the wheels to spin faster
on a new speedfight they don't have a washer in the variator, its the backplate of the variator you have to remove, (so there's no back on the variator), then you have to remove the exhaust, and you will find a secondary blanked off chamber by where the exhaust bolts onto the head, (this chokes the engine, therefore restricting its revs), you can either get it chopped off and welded up as if it was never there, or stick it in a vice and crush it, i recommend if you crush it that you do it a couple of inches away from where it welds onto the main part of the exhaust or you can break the weld, and you will have to get it welded anyway
if you do it this way you will not need to mess with different variator rollers
if you change the exhaust, good luck! it will then need rollers and a bigger main jet in the carb (as you will have done away with the catalytic convertor) , so don't bother as it will take an age to set up properly
you must do both of these together, remove the backplate to derestrict the drive speed, and crush the exhaust secondary chamber to derestrict the engine
don't use an air gun to get the variator off, you'll eventually screw up the thread on the end of the crank doing it like that!
oh yea, i'm a fully qualified peugeot scooter mechanic with all the certificates from peugeot uk (three cross m/c) so this is the only post you can believe, I know it might not be the sensible thing to do letting you know how to deresrict your ped, buy i'd rather you do it properly as I know you're going to mess with it anyway
PS after you're done, please bear in mind, the lighter you weigh the faster it will go, in my experience if you're 8 stone it will go into the red on the speedo, the bit after it ends at 55mph, if you weigh 16 stone you'll be hard pushed to see 50mph, its due to the power to weight ratio |
andys675 |
Liam_K |
The last post was made 9 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
