Vincent |
Vincent Banned
bladeblaster |
bladeblaster Trackday Trickster
Posted: 08:49 - 14 Oct 2015 Post subject: |
So the carbs from E-bay turned up.
https://i491.photobucket.com/albums/rr279/bladeblaster/12141082_10153182941204013_1468178551592066076_o_zpsqz9sgagl.jpg
Only to find that the butterflies are fairly seized, but not sure why. So I get to stripping them down.
Then I find that 2 idle mixture screws are missing and the 2 that are there are both knackered. Managed to get one out, the other one has no chance.
So I go to plan D
I only really need the one body, so I can take the body I need and swap it with the broken body on the other set.
So I start breaking down the bank, most of the screws holding the back together are seized or already rounded off, but hopefully in here somewhere is one good set of carbs.
https://i491.photobucket.com/albums/rr279/bladeblaster/12113447_10153183531559013_595131859415084979_o_zpslhl0cir9.jpg
Took the bank to work and drilled off the screw heads on the pillar drill, separated them, only to find that the body I need is the one with the seized butterfly
So 8 carb bodies, and no 1 good full set
So plan E a full set of A1/A2 carbs came up on ebay so I have bought those. Should arrive today, they had better be good. |
andym |
andym World Chat Champion
Posted: 09:14 - 14 Oct 2015 Post subject: |
I'm glad I didn't go to all this trouble with my GPz project.... but then I'm also slightly disappointed
I haven't really had the need to strip carbs down to individual pods, so I'll admit I haven't got a clue what I'm talking about here.... but aren't they all the same when EVERYTHING is stripped from them? Or at least in pairs anyway?
Also with the screws on my carbs, they were big enough to get a set of needle nosed mole grips on there to crack them, had to replace all the bottom ones because they were all rounded etc, the top ones I didn't even bother putting much force in to the screwdriver before going for the mole grips again |
bladeblaster |
Undinist |
Undinist Nearly there...
Posted: 12:39 - 14 Oct 2015 Post subject: |
Thank you OP, you've saved me thousands of pounds and a shedload of grief - your posts have cured me of the notion that I could one day restore a bike. I don't have the skills or patience and my 'workshop' is unbolting parts in the street and cleaning them in the kitchen. ____________________ Current bike: K1100RS. Previous: CD200, GSX250, GT550, VFR750, K100LT, K1100LT, R1100GS, R1150GS, ZZR1100, Hayabusa, RSV Mille, MV F4 750S, R1, ZX-10, KTM Adventure 950S |
andym |
Undinist |
Posted: 13:15 - 14 Oct 2015 Post subject: |
That's impressive. But I don't have a driveway. I suppose I could designate a corner of the bathroom as a motorcycle mess. ____________________ Current bike: K1100RS. Previous: CD200, GSX250, GT550, VFR750, K100LT, K1100LT, R1100GS, R1150GS, ZZR1100, Hayabusa, RSV Mille, MV F4 750S, R1, ZX-10, KTM Adventure 950S |
bladeblaster |
Vincent |
Vincent Banned
Posted: 19:56 - 14 Oct 2015 Post subject: |
Those butterfly valves...........I was reading about a tool to help get them off the other day so don't abandon hope. I'll have a look for it.................
Do you have close up pics?
If they're screws...and you've rounded them off.......you're not the first ____________________ Space Is Deep |
bladeblaster |
bladeblaster |
Posted: 14:11 - 20 Oct 2015 Post subject: |
Time for a Carb Saga update.
Repeated application of penetrating fluid did free up the stuck butterfly quite well in the end.
The new carbs looked really good when they arrived, so good I was considering bolting them straight on. However I didn't and I am glad I didn't, the insides we covered in rusty coloured fuel residue. Worse than that all 4 idle adjuster screws were missing their o-ring seals. The ends of teh adjusters were black as hell, must have run as lean as an anorexic bacon sandwich.
So new set stripped & cleaned, I had new idle adjuster seals that I had already bought so that wasn't a problem. So once all cleaned out, time to re-assemble.
Bottom end:-
Vernier set to 17mm to check float heights
https://i491.photobucket.com/albums/rr279/bladeblaster/12112217_10153196568834013_4964418979589696153_n_zpsqzasasar.jpg
Floats & Shut Off Valve in, first checking that the rubber pointy end is in good nick, and the spring on top of the valve is strong & moves freely.
https://i491.photobucket.com/albums/rr279/bladeblaster/12108232_10153196568419013_3674561498513765901_n_zpst7ubzzpe.jpg
Check float height, this one was low as you can see by the gap between the top of the float and the bottom of the vernier body.
https://i491.photobucket.com/albums/rr279/bladeblaster/11222547_10153196568829013_2153848052827561133_o_zpsiqqamwka.jpg
So adjust by bending the small metal tab that the float hangs off, one way or another. Low float means the tab needs bending towards the float. Its a trial and error amount, not an exact science, just keep re-fitting & checking until you get this. The float needs to be sat just on top of the valve without compressing the spring on top of the valve, when you take the measurement.
https://i491.photobucket.com/albums/rr279/bladeblaster/11148220_10153196568839013_4810299778051141949_n_zpsejz01h1m.jpg
Now back in with the various jets:-
Needle Jet
https://i491.photobucket.com/albums/rr279/bladeblaster/11167656_10153196568814013_1465843608683305132_n_zpsq4wuxamc.jpg
Emulsion Tube
https://i491.photobucket.com/albums/rr279/bladeblaster/12115559_10153196568809013_4023030134465796180_n_zpsbuezajnc.jpg
Main Jet
https://i491.photobucket.com/albums/rr279/bladeblaster/12107261_10153196569024013_1117731871199962690_n_zpsykmi5gse.jpg
Pilot Jet
https://i491.photobucket.com/albums/rr279/bladeblaster/1470113_10153196569014013_1377343245997196888_n_zpsidd59egw.jpg
Pilot Adjustment Screw, properly assembled with o-ring seal.
https://i491.photobucket.com/albums/rr279/bladeblaster/12118957_10153196569019013_5542635927046347486_n_zpss1arpti0.jpg
New seal in the float bowl.
https://i491.photobucket.com/albums/rr279/bladeblaster/12095216_10153196569009013_2536180955551177679_o_zpsqnwjwinw.jpg
Now for the top end.
Little bit of Rubber Grease to help the diaphragms seat properly.
https://i491.photobucket.com/albums/rr279/bladeblaster/887479_10153196568459013_9044056090785655878_o_zps8sbz5fsx.jpg
Diaphragm & slide back in, and top face greased.
https://i491.photobucket.com/albums/rr279/bladeblaster/12113291_10153196568439013_2167408889080786081_o_zpsbyvyqd13.jpg
Main Needle In.
https://i491.photobucket.com/albums/rr279/bladeblaster/12095106_10153196568424013_4499037246402542073_o%201_zpsvqe0uhfh.jpg
Spring seat & Spring in, taking care not to black the vacuum port with the spring seat. It has to sit with the legs either side of the hole, if its positioned with a leg blocking the hole, it knackers up the vacuum, and it will never fuel properly.
https://i491.photobucket.com/albums/rr279/bladeblaster/12095278_10153196568454013_19244337403836481_o_zpsyqshbkrr.jpg
Then tops on, and all back together, with nice new cap heads & spring washers.
https://i491.photobucket.com/albums/rr279/bladeblaster/11223925_10153196562389013_1989842155309956333_o_zpszcwbcmaw.jpg |
bladeblaster |
Vincent |
Vincent Banned
Posted: 19:26 - 29 Dec 2015 Post subject: |
'Seriously considering getting one of these...... ____________________ Space Is Deep |
bladeblaster |
Posted: 19:58 - 31 Dec 2015 Post subject: |
Duffman |
Duffman Renault 5 Driver
Posted: 11:14 - 22 Jan 2016 Post subject: |
Awesome thread, just joined the motorbike world and BCF and this is the best thread ive found.
i do feel inadequate though |
bladeblaster |
chickenstrip |
chickenstrip Super Spammer
Posted: 13:06 - 22 Jan 2016 Post subject: Re: Bike of my dreams |
bladeblaster wrote: | probably so cheap because it was advertised as needing a new starter clutch which is a big job. Easily a grand to be done in a bike shop. |
So what of this? Was the seller wrong? ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
bladeblaster |
bladeblaster |
Posted: 15:01 - 01 Mar 2016 Post subject: |
thosoneill |
thosoneill Renault 5 Driver
Posted: 11:21 - 03 Mar 2016 Post subject: |
Thanks mate for a decent thread - it's amazing the amount of wear and tear a motorcycle is subjected to - fantastic you have the ability to fault find and repair - I doubt any dealer could have done better - well done that man - fancy changing my belt and rollers |
bladeblaster |
Posted: 09:33 - 14 Mar 2016 Post subject: |
A very frustrating weekend on the GPZ
The good news, the rear shock is in.
https://i491.photobucket.com/albums/rr279/bladeblaster/12814712_10153455965669013_5885533068047598212_n_zpsdtisqvx5.jpg
The bad news, I thought I had the circlips for the tie rods, but I didn't so I couldn't finish fitting it, needs circlips fitting then everything torqued up.
More good news, the front lines are fitted.
https://i491.photobucket.com/albums/rr279/bladeblaster/12186233_10153455997439013_5213086437354038805_o_zpsqtnpvuyr.jpg
The bad news, the reservoir screws were so chewed up they are unusable, so need new ones before I re-fill the system. So couldn't finish that job either.
To top it off tried starting her again, and come to the conclusion that the starter clutch really is totally shot, so the engine is going to have to come out after all. I know I knew but after the false hope it gave me early on, it feels like a bit of a kick in the balls.
1 step forward and 2 steps back, definitely a weekend where you question the sanity of owning a 30+ year old bike, and wanting to take a match to it |
Just_James |
Just_James Could Be A Chat Bot
Posted: 00:55 - 15 Mar 2016 Post subject: |
Bit of a shitter with the starter clutch but it will be worth it in the end... easy for me to say as I'm not the one that has to do it
Really liking the detailed thread on this though, keep it up ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125 |
bladeblaster |
bladeblaster |
Posted: 17:07 - 31 Mar 2016 Post subject: |
bladeblaster |
Posted: 12:02 - 08 May 2016 Post subject: |
The last post was made 8 years, 33 days ago. Instead of replying here, would creating a new thread be more useful? |
