Iain. |
Iain. Could Be A Chat Bot
Fladdem |
Fladdem World Chat Champion
Posted: 00:19 - 05 Dec 2014 Post subject: |
BoatIain, is it really you? Will the thread continue? ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
Iain. |
Posted: 00:31 - 05 Dec 2014 Post subject: |
It is indeed me Mr Putin.
Thread will indeed continue, hopefully my normal account will be re-activated once Stinkwheel reads the rules he's supposed to be there to enforce & stops making them up as he goes along. |
Fladdem |
Posted: 00:37 - 05 Dec 2014 Post subject: |
Did your post about excessive moderation just get excessively moderated down, or did you do that out of choice? ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
bikertomm |
bikertomm World Chat Champion
Iain. |
CG Sam |
CG Sam Crazy Courier
SQL |
SQL World Chat Champion
CG Sam |
andyscooter |
Iain. |
Just_James |
Just_James Could Be A Chat Bot
Posted: 17:26 - 28 Jan 2015 Post subject: |
Was wondering if anything was happening with this, glad to see you're back on with it |
stevo as b4 |
Posted: 18:51 - 28 Jan 2015 Post subject: |
+1! Good to hear the beast will live on again, it looked in decent condition and you brought it for next to nothing so it makes sense to get her back on the road.
Is that kit a 50 or 70cc top end? |
evoboy |
evoboy World Chat Champion
Posted: 20:30 - 28 Jan 2015 Post subject: |
The HP kit is near on the same as the HPR but with less aggressive porting. Its still single ring so will have around the same service life as the HPR.
The CPH crank will be fine. I had one of Pedstops own brand 'Sticky parts' ones in mine. It stood up to the stupidly high revs no problem.
Stock carb will kill it. A 17.5mm or a 19mm would improve it greatly, junking the airbox is also a must. It'll only become difficult to jet when you stick bigger than a 21mm on it. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
speedy |
speedy Scooby Slapper
Iain. |
Posted: 22:15 - 28 Jan 2015 Post subject: |
Crankcases split and cleaned
https://i.imgur.com/qbW8Uqu.jpg
Made a plate to blank the oil pump off as this will be going premix.
https://i.imgur.com/7WK0koO.jpg
And a dead crankshaft.
https://i.imgur.com/vI7xrRk.jpg
HP kit has slightly less agressive porting, whilst it is single ring its also lower compression hence predicting a slightly longer service life. Will pick up some spare rings/small ends/gasket sets then compression test it every 1500miles. Soon as it drops, fresh ring.
Will do the carb, but at a later date when I have more money! Unfourtunately living costs are high and wages low |
Iain. |
Iain. |
Posted: 09:24 - 31 Jan 2015 Post subject: |
Put some miles on the motor.
Seems I have a range of around 15miles on a tank of fuel as it ran out. Will have to install a 2nd tank.
https://i.imgur.com/PJ1Yc9z.jpg
Kickstart doesnt work, also having hot start issues - new carb will have manual choke. I suspect the auto choke is confused by the lack of airbox and freezing temps. Need to have a look at the plug and see what the jettings up to, its very close but not 100%
Still,
https://i.imgur.com/82oLhoI.jpg
Only need to find another 8mph |
stevo as b4 |
Posted: 01:45 - 01 Feb 2015 Post subject: |
Iain, are you at 70cc now? otherwise I'm never gonna believe those healthy speeds your reaching now?
I know Evoboy and other's that know their 50cc tuning have commented on the quality and design of the Chinese engines, being quite a long way behind the Piaggio motors, but I am fairly impressed with the inlet port, and reed valve area, and the short straight manifold it has too.
The 50 and 100cc Honda/Peugeot engines have in comparison a tiny inlet port into the crank case, and a nasty restrictive manifold with a tiny 2petal reed block.
If you get that thing to a real 68mph on the flat, that's all my 11.8bhp 100cc SF2 was doing, so it's not far away as it is! |
evoboy |
Posted: 21:58 - 01 Feb 2015 Post subject: |
Not bad considering its still freshly built.
I still have that clutch here if your still interested in it.
Itll go much better with a larger carb. The tank range should improve too...
The chinese motors are just a copy of the Minarelli AC lump used in the Yamaha range ( Early aerox and neos ). Its just the bearings and gearbox components are much cheaper made.
Whats it revving too? ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
Iain. |
evoboy |
Posted: 12:30 - 02 Feb 2015 Post subject: |
Iain. |
mudcow007 |
mudcow007 World Chat Champion
stevo as b4 |
Posted: 20:12 - 02 Feb 2015 Post subject: |
The issue with the std carb being restrictive is an interesting one, and I can see Evoboy's point and reasoning why a good kit is held back by a small carb.
I know it's a different motor and probably different situation altogether, but I did not really think the 21mm carb conversion on my SF100 was worth the hassle it caused with jetting/filters and bogging down. The mods on my 100cc that really worked were:
1, exhaust
2, bit of porting to the std iron barrel
3, More compression. (This mod made more difference than any of the others at lower speed)
based on my limited 2stroke tuning experience I would always look for more compression as an early mod, as in this case I felt the improvement straight away. But then again it melted the piston 100miles later. |
The last post was made 9 years, 130 days ago. Instead of replying here, would creating a new thread be more useful? |
